3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Handheld Air Conditioner Unit
Jambo Instructabrarians!
Picture this: It's 87 degrees and scorching outside, you desperately want a Slurpee, but the nearest 7-11establishment is about about 5 blocks down. You could go out for a walk, but the heat is so intense you don't think you can make it there and back. You might be able to take a drive, but- wait a minute- car's impounded. So what do you do- risk burning to a crisp for a delicious drink, or struggle through this insane weather, Slurpeeless?
Thankfully, you may never have to face this dangerous predicament again! Good News, Everyone! I just finished putting the latest touches on my newest Summer Mattraption- my brand new Executive Style Handheld Air Conditioner! Portable and eco-friendly, this useful device promises to keep you cool with only 4 AA batteries and ice water!
Author's Note: I recently took this with me when I went on vacation to Hawaii and, I don't mean to brag, but it worked phenomenally.
Step 1How It Works:
How It Works:
If you've browsed our fine selection of Summer Instructables, chances are you've probably seen CameronSS's amazing 12V Air Conditioner.   The concept is simple: a bilge pump transports cold water from an ice cooler, and is then pumped through a wound coil of copper tubing, which surrounds the circumference of an electric fan.  Thus, when the bilge pump circulates the flow of ice water around the metal copper tubing coils, the cold air is sucked around them and produces and Eco Friendly blast of cold air.
Now imagine that same concept, except 70% smaller.
Instead of using a bilge pump, I opted out for a miniature water pump from a desktop fountain, a stainless steel 1 ltr Thermos instead of an ice cooler, and a mini plastic handheld fan.  The final result?  A conditioner that is as classy as it is portable.
147 comments
1-40 of 147next »
Aug 29, 2011. 8:33 PMmktrost2 says:
So all of you that think Shift is wrong and a fool? You should not put down ideas that may come from the person who may make it possible someday to reach the stars or could double human life span? Maybe you should say that is really cool, neat, boss, trick or whatever term that encourges him to make more things. Support & help him and others that are really thinking. GEEKS RULE!
Mar 17, 2012. 8:06 PMmr fat says:
Hammers rock! This is an excellent project now all I have to do is find a pump.
Dec 19, 2011. 1:48 PMBruce1212 says:
Cool!..haha, I think that should be a standard issue for those living in hot climates, (texas..ahem!). Those should be standard medical devices for people that have to sit in a waiting room where the AC is broken, like I had to do last week.
Sep 30, 2011. 6:00 PMacostanza says:
Couldn't you, in theory, even add a bit of salt to the water to get the water down below 32 degrees making it a bit cooler?
Aug 27, 2011. 11:39 PMromoshka says:
As to the cooling vest idea - I was in the process of building a prototype of such a device for use by motorcyclists when riding long distances in hot climates. Just as I finished the prototype one of my MC mags had an ad that there was a commercially available device - almost identical to mine - now available for sale at a very reasonable rate. Day late and a dollar short...again.
Aug 4, 2011. 2:30 PMCamButton says:
Awesome cooler brother. I think it could be easily adapted for use with body armor. Imagine Joe or Jane cooled through an ice water vest with cool air blowing on their neck and face. Have a good one. Cam
Aug 22, 2011. 7:59 PMimark77 says:
they actually make a medical device which has a reservoir for ice water, housed in a pump unit. and has a detachable vest with tubing in it.
yeah it's real, at this point it's old news to me, as I saw this when I was 7 or 8 years old.
it was at a family members house, he had something related to agent orange if I remember right.
Aug 13, 2011. 10:18 AMbabykidlet says:
What you have created is a hand-held chilled-water air handler.
The 'chilled water' comes from the icy cup reservoir. It is pumped thru the copper coil to cause a lowering of the air temperature blowing thru by absorbing some of the heat in that air, effecting true air conditioning.
If the dew point is such that moisture condenses on the coil, you also have dehumidification taking place in the air stream.
This is indeed a miniature version of a system used quite widely in large buildings like schools and office towers. Kudos!
Aug 7, 2011. 9:21 PMmlevin says:
What's the model of that fan? Can't seem to find it anywhere.
Aug 6, 2011. 10:32 PMslothman says:
could this idea use dry ice and last all day. or would it get so cold you could not touch it. or would it freeze. ?
Aug 4, 2011. 5:28 PMpiper1234 says:
if it avoids you a heat stroke it should be at hand
Aug 2, 2011. 6:37 AMlloydrmc says:
Couldn't this be considered "green" since it doesn't use fluorocarbons? And that it keeps you cool while walking, instead of driving while using the air conditioner in the vehicle?
And I'm still waiting for a technical explanation as to why making ice is 98%+ wasteful of electrical energy. Is refrigerating food "wasteful" as well? How about all that electricity used to treat and distribute potable water?
And, for that matter, how it is that a Zen fountain pump exhausts the batteries in an hour? Mine has a battery life comfortably measured in days.. Does making unsubstantiated claims count as fact now?
Aug 3, 2011. 6:47 AMJamie508 says:
I'll try and be helpful on the ice energy topic. In order to understand why making ice is an expensive / inefficient process, you need to approach the problem from a thermodynamics sense. http://en.wikipedia.org/wiki/Heat_pump_and_refrigeration_cycle
If your seriously interested, this would be a worthwhile place to start, while I have taken courses in thermodynamics, I would not be qualified to talk in depth on the subject and am worried I would mislead you.
Aug 3, 2011. 7:48 PMlloydrmc says:
Jamie, I appreciate your viewpoint and approach, not to mention your humility. I hope I do not come across as arrogant or sarcastic (or untrainable).
What BobCat is saying is that, somehow, having air cool air blown over you is somehow 98% less efficient than DRINKING ice water, which somehow magically cools your body's core temperature (one wonders why it is NOT accepted First Aid practice to give cold liquids to heat stroke or heat exhaustion).
As for the efficiency of the process of making ice, (or lack thereof), isn't it all relative? My Hotpoint/GE Eco-options refrigerator is EPA rated to use about $34 worth of electricity a YEAR. Of course, putting some room temperature water in an ice tray in the freezer will cause the compressor to run longer to compensate. But how much? Would it even be measurable? Would it be more than it would take to compensate for having to take a minute to dig through the freezer to find an item that is "hiding"?
Let's say that BobCat is right, and blowing cool air is somehow 98% less efficient than drinking cold water. Could an entire tray full of ice (let alone what will fit in a 1/3 liter cut) cost even a penny to freeze in an efficient, modern refrigerator? If it costs a penny to make the ice for the cooler, then who cares if it takes 1/50 of a cent to make the ice to cool down an equivalent amount by drinking ice water?
Aug 4, 2011. 1:27 PMApprenticeWizard says:
You do not give ice water to someone with heat stroke because doing so can cause cramping, nausea, and shock.
Aug 4, 2011. 5:14 PMlloydrmc says:
You DO give liquids to someone with heat exhaustion, but not cold liquids, nor is that how you help them cool down.
Aug 1, 2011. 10:53 AMvinayakbhat82 says:
Nice idea, but would this rather be an air cooler and not an air conditioner??
Aug 4, 2011. 1:37 PMApprenticeWizard says:
Semantics. Your air conditioner cools air by blowing it over a tube of cold fluid - same as here. The difference is that your AC creates the cold fluid (by compressing a gas - removing heat energy from it), whereas this works from a fixed cold reservoir.
Aug 1, 2011. 12:15 PMJayefuu says:
+1 Not an air conditioner, OR green.
Aug 1, 2011. 12:24 PMJayefuu says:
Sorry, that came across awfully negative.
Like others that have commented I think you'll "turn off" many people that come visiting this 'ible by your use of green and air conditioner.
Cool? Yes! Cooling? Very! Air conditioner? No. Green? Definitely not.
Your 'ible's well written, but it plays for views (hey, I've done the same myself, I don't blame you) and doesn't seem honest. It'd read a lot better if it didn't claim to be what it isn't.
Aug 1, 2011. 2:34 PMJayefuu says:
Fair enough, you could have used a TEC and claimed it was 90% efficient AND green, that would have been worse.
I respect your opinion, but it seems like you justified it being green to greenwash rather than it actually being green. I don't think it'd be constructive to argue about it, so let's leave it at that, or maybe we should work together on a cooler that's greener?
Ice wristbands? Something to cool your wrists or another close to the surface vein to truly cool you rather than the air blowing at your face? I'd be willing to bet that a battery powered TEC in contact with your skin would be more efficient than freezing ice and blowing cooled air at your face.
All arguments aside, as I said before, I don't think what you did is a bad idea, it looks neat, the 'ible's well written and the product's cool, I just disagree that it's green or "eco". Green would be rubbing water on your wrists and arms so that evaporation does the hard work, or staying in the shade. Not using power to freeze water and then using batteries.
Aug 2, 2011. 11:58 AMTECHMASTERJOE says:
about 4 years ago i did something like this but i made 2 loop of copper tube add a thin copper plate in a way so it clipped over the back of my neck it worked real well but ICE was a no go in the long run i used a 200watt TEC and a set of lipo witch is far from green but it added more rounds of golf it avg well over 112F here so green was not what i wanted...................
but a good 25~100watt TEC a copper pate and a small old P3 cpu heatsink might do the trick. add a pwm power management with temp feedback and you might have a real cooling system..............
i can see TEC with power management in direct contact like this, green as over time your using far less total power then the ice water setup even just making the ice uses more power..................
a good 4500ma lipo/nimh can run a 50w TEC like this for days if power is done right....................
and yes the best way is stay out of the sun.
but it's 10am at my house I'm in doors and it's 102deg so far today so i know my A/C will be on soon.................
check out custom computer cooling sites for TEC's you can get good ones cheep..................
like frozencpu.com
use a 6-8cell NiMh pack you can get them some what cheep now days as people go LiPo (NiMh live longer and have just as much power)
lipo are about 1/3rd lighter and smaller that's all......................
and hey people don't point out flaws unless your going to post ways around them. cooling the air is the lest efficient way direct contact is best.
just use a mini fan for your face if you need more air in your cooling setup 95% of the cooling is just sweating plus a fan ice is doing almost nothing take a before and after temp with pump on and off at best it's a 2 deg temp drop if that just not a lot of surface area on the tubes to cool the air .................
hint: if you apply anything to cold to the top of your skin your body will reduce blood flow around it so remember cool not cold.
(stay with in 20degs of body temp)................
i hope this gives you ideas for the next one good luck.........
Aug 2, 2011. 12:06 PMTECHMASTERJOE says:
cool the left side of your neck more then the right if you cool the right side to much you will get massive headaches when the cold blood hits your brain.
i learn this the hard way lol..
Aug 2, 2011. 12:08 PMTECHMASTERJOE says:
last tip ditch the long sleeves that will help to
Aug 2, 2011. 12:16 PMl8nite says:
actually long loose sleeves help keep you cool, I wear loose, long sleeved, light colored,shirts as much as possible when I need to be outside in the heat, a wide brimmed straw hat, while far from a fashion statement also helps keep you cooler with a combination of shade and evaporation
Aug 6, 2011. 12:37 AMgemtree says:
Many years back when I was doing yard work, I learned that long sleeve white cotton shirts bought way larger than fits and a long head scarf that was wetted and tied to my head that covered the back of my neck was THE best thing I could do for myself. Long brim straw hat over that. Oh, and totally cut out caffeine when I knew I would be working in the heat. I may go back to doing that again.
Aug 3, 2011. 4:30 AMTECHMASTERJOE says:
that works for you i guess. I'm stuck with long sleeves as i had skin Cancer. i do see now that shirt is "under armor" and is made to wick heat/ sweat away. i have a few my self. they help a lot if your in direct sun light witch you will never find me. i hate the sun witch the only time i'm awake to reply is late (now 3:23am).
i always hated long sleeves never owned a shirt with them tell about 13 months ago when i found out i had cancer
(i have beat it so I'm good just not aloud to be in the sun at all)
Aug 3, 2011. 11:54 AMKrimm says:
I get the concept from your video. But I was wondering if you could tell a difference in temperature? Like I was waiting for you to hold up a digital thermometer. I'd love to see what kind of temps your getting from the ambient air then from in front of the fan. Just to keep it a little bit interesting. good creativity overall. thanks.
Jul 31, 2011. 10:59 PMVenemot says:
You guys think 80 degree fahrenheit is hot....You should check out Pakistan....Here normal summer temeperature is 104 degrees....Thats about 40 degree celsius...and this temperature doesnt bother most of us Pakistani's....the temperature which bothers is 50 degree celsius......aroud these times humidity is extremely highi.e. 70 to 80 %....now that is hot...!!!!!!
Aug 3, 2011. 4:39 AMTECHMASTERJOE says:
it was 114 today with monster storms humidity around 75% and this was the coolest it has been in weeks 3 days ago was record at 127 and 66% humidity so ya i do know what hot is and agree 80 is nothing to need a fan for
(my house don't not have a/c. i do have a small window one in my room but i don't like to pay the power bill for using it so i don't)
power here is really high just using my gaming rig all day can drive power up an extra 40$ for the month avg bill is 385$ US that's only a fridge and a new 55" LCD
(my rig eats up 1600~1700watts at full power)
Aug 3, 2011. 4:46 AMTECHMASTERJOE says:
i had to replace my 2 year old vizio 42" because the heat warped the tv screen LOL.
the new 55" is a MUCH better vizio LED 3D setup that uses cheep glasses i got most of mine from the movies (the RealD glasses)
Colors really pop on it compared to my Nvidia glasses and asus monitor.
Aug 2, 2011. 10:58 PMjendamage says:
Today in texas it hit 110 degrees , im pretty sure your "air cooler" would not have any affect as the ice would melt in 5 mins! :(
Aug 1, 2011. 7:49 AMjcosta-1 says:
I agree...surprisingly it's been close to 50 degrees Celsius for most of the past week here in Toronto CANADA...it was hotter here than in the Carribean!!
Aug 1, 2011. 9:00 AMVenemot says:
what 50 degree celsius....in toronto...unbelievable....!!!!
Jul 31, 2011. 11:07 PMcasemill says:
Same here in Texas. It's 104 today. Will be 106 tomorrow. Not a problem. We know how to handle it.
1-40 of 147next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
137
Author:SHIFT!
"Almost Toast"
