3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Handheld LED Tester
Handheld LED Tester
Here is a little back story for this quick and very useful project.  I am in the process of designing and building a small indoor green house, which will have LED based grow lights in it.  I bought a couple of LED grow light boards from homegrownlights.com, so I needed to install 256 LEDs per board and having a total of 10 boards to populate with some 2,560 LEDs, I wanted a way of testing the LEDs before I went through the process of soldering them in.  I had a couple requirements as I went into building my tester.  First it had to be easy to use.  Second it had to be simply and compact once built.  Third it had to be cheap, but would last a while for other LED projects.  So here is my design, it's quick, clean, and easy to use.  I was able to test 2,000 LEDs in about an hour and 15 minutes.
Step 1Parts + Tools
Parts + Tools
Parts:
- Small project box (3"x2"x1")
- A piece of 2-sided copper clad PC board (2"x2")
- CR2032 Button Battery holder
- Small peice of wire (not in picture)
Optional potentimeter to be able to turn voltage down for LEDs that require lower voltages.  I built it to test 3-4VDC LEDs, so running just a 3VDC button battery worked for me, but I am going to add the adjustability later.
(I bought everything at Radio Shack.  I'm lucky enough to live in a college town with a large engineering school, so the Radio Shack actually still carries components.)
10 comments
Oct 28, 2010. 3:24 PMWo0kiE says:
nice idea...
you could also use a much smaller project box or use a smaller battery and place a similar device in an old usb flash drive housing which would also give you an end cap....
just a thought.
Oct 19, 2010. 3:17 PMGrumpyOldGoat says:
Good way to test a lot of LEDs.
THANKS!
Now, about your grow light... What colors are you using?
Will there be an instructable?
Oct 20, 2010. 6:23 AMGrumpyOldGoat says:
I would have thought there would be some yellow involved as well.
I asked the nice workmen at the highway traffic light maintenance place about some replaced signal lights.
I have plenty of extremely bright red, green and amber LEDS as well as some awesome diffusers and lenses.
While I was in the neighborhood, I also dropped in next door at the highway stripe painting division.
I also picked up a half gallon of the glass beads they use to make the reflectivity of the stripes.
Good sources of neat stuff found no place else.....
Sep 19, 2010. 5:29 AMagis68 says:
I prefer to use normal batteries that button cells. The reason is the Amps. The AA or AAA batteries has more Amps.
Sep 20, 2010. 7:13 AMagis68 says:
correct, good job!
thnx for the reply
Sep 17, 2010. 2:39 PMrocketman221 says:
Good idea. I've just been using coin cells to test LEDs for years. This looks like its a bit faster to use.
Sep 17, 2010. 2:13 PMgodofal says:
nice idea!
i would like to add that with small currents like coincell batteries, you never need resistors, shown in the LED trowies.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:apo1l0
