3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Handheld Van De Graph Genarator
Build Your easy to make Van de graph generator thats portable!
Step 1Materials
Materials
Stuff from think geek ( and your fridge):
Soda can
Fun Fly Stick http://www.thinkgeek.com/geektoys/science/af4c/
Alligator clip
Xenon tube (optional i used this to make sparks)
34 comments
Oct 17, 2010. 10:14 AMgb123 says:
Im so confused!!... where does the bottom comb go? where does the wire go? It it grounded?
Feb 7, 2010. 4:51 PMSNiPERSeyes says:
its not graph its graff!!!!!!!
Aug 18, 2010. 5:22 PMH20 says:
its graaff
Aug 18, 2010. 6:06 PMSNiPERSeyes says:
thanks you!!!! sorry forgot the a in my rage....
Dec 5, 2009. 5:28 PMmathman47 says:
Can't we be nice to everyone?  No matter, but please, everyone, use a spell checker.  Some of you are coming across like 8th graders as far as spelling and grammar goes.  I thought this Instructable was for actually building a VDG, not just attaching a larger wand to a generator.  Could you try that (actually building the generator) next, or maybe buy a kit to put together.  Still, I applaud your efforts.  At least you took the time to build this and make an Instructable about it.
Mar 10, 2009. 3:14 PMHunter4000695 says:
If you attach the clip in the can you can get a bigger spark.
Dec 5, 2009. 4:12 PMtoddjwood says:
The Van De Graaff takes advantage of the Faraday Ice Pail effect, meaning that if the charge is applied to the outside of a conductor it can only charge to the input voltage, but when applied to the inside of a conductor the charges move to the outside and can collect to a higher voltage than the input voltage.
Check out the Van De Graaff Group on Yahoo. http://tech.groups.yahoo.com/group/VanDeGraaffGenerator/ for a wealth of Van De Graaff information
Nov 23, 2009. 5:37 PMthestyrofoampeanut says:
 does anyone else realize he took a pre-made van de graaf and just put a can on the end for a bigger discharge area?
i was looking for a way to build one not buy one but i guess he doesnt actually say how to build it
 whoops i meant graaff
somebody probly wouldve got on my case for that....
Apr 26, 2009. 2:01 PMXellers says:
This probably generates more than 500 - 1000 volts... And can you take clearer, more accurate photographs. No pictures of sparks give us no proof that you actually made this work. Also, if you know that its "graaf", and not "graph", then please change it.
Nov 8, 2009. 4:23 PMwoody558 says:
Actually it's GRAAFF not graaf.
Dec 4, 2009. 2:16 PMtoddjwood says:
Not true, taken with a standard Digital camera under normal lighting conditions.
I had a few misses but not to many.
Dec 5, 2009. 2:56 PMtoddjwood says:
Sorry, no trick photography, no video frames, the Van De Graaff was discharging multiple times per second so I am sorry to say that you are wrong.
You can see the arc meanders through the air, if it were a long exposure then there would be multiple arcs in the pic, and there is clearly only one; also there is only one point of origin and one destination again if it were a long exposure the would be mutiple. I don't want to argue but I have built and photographed many Van De Graaffs and you can capture the discharges here is an earlier one of mine. In this one you can see me taking the picture if you still have any doubts.
Be happy
Sep 26, 2009. 10:51 AMXellers says:
Incorrect, you can take a long exposure photograph.
Sep 27, 2009. 11:52 AMXellers says:
First of all, I don't know where you're getting the "0.001 second" statistic, but I suspect that it is wrong because this depends upon the voltage, current, humidity, and gas that you are creating the spark in. Additionally, long exposure would work, as the camera keeps the shutter open the entire frame, so that if you did this in a dark room, almost all of the light that it would capture would come from the spark.
Sep 28, 2009. 2:32 PMXellers says:
I think that you need to understand a bit more physics before you start to tell me how long the tube is actually emitting light for. When electricity passes through the xenon flash tube, it ionizes the xenon particles, which eventually causes them to emit light (a better explanation of this can be found here, I will not repost it: http://www.powerlabs.org/plasmaglobes.htm) I honestly do not understand your comment about electricity traveling at the speed of light and the relation of this to the time that the tube emits light for. Please take some pictures, and stop creating silly explanations for your inability to do so. If you are simply too lazy to take decent pictures of this project, then please admit it.
Apr 14, 2009. 4:19 PMTitanTechRobotics says:
Isn't it van de graff and not van de graph if im wrong the my science book is lying to me (I wouldnt be surprised if it is)
May 10, 2009. 3:09 AMApple Rule says:
nice instructable
Mar 19, 2009. 3:37 PMHunter4000695 says:
Yes If you solder a wire that would work. But you Would need to cover all the pointy ens.
Mar 18, 2009. 4:33 PMHunter4000695 says:
Did you check out the link that I left? It explains the law pretty good. A question? Where did you get the efficiency number from? Also, the clip is connected directly onto the outside of the can so it becomes a part of the outside of the can. It does not do what you described. p.s. You are not being rude, we are just having a respectful differing of opinion.
Mar 17, 2009. 5:38 PMHunter4000695 says:
yes but the teeth will provide points for the electrons to discharge it will limit the amount of charge on the can. why do you think they dont make commercial made ones with anything but a rounded sphere dought. i know what you are thinking. you would hear or see the discharge of the teeth when you are running it. but the same thing that happens inside the VDG is happening with the teeth. its making a corona, just one you cant see.
Mar 16, 2009. 3:09 PMHunter4000695 says:
Check out this site
http://amasci.com/emotor/icepail.html
you need to read the last parograf is.
The when the clip is on the out side this affect is in possible.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:itsthatsguy
