3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Handmade Flipbook
Step 7Clamp and Drill
Clamp and Drill
Square up your stack and clamp them tight - wrap the photos if you like, but I knew I'd be tossing the first and last one anyway, so I just pushed on.
Now, I don't have a paper drill bit - I wish I did and I'm seriously considering purchasing one. But for this I had to use a standard electric drill and a 1/4" bit. It cut through the paper just fine BUT...
As the bit goes through each piece of photo paper, it messes up the paper just a bit and causes a slight raise in the paper. A 1" thick stack of photos all of sudden becomes a 1.5" stack on the end that's drilled because all those little holes add up quick.
I ended up just sanding them down with some sand paper - not the greatest solution, but until I get a paper drill bit (not sure they even make them in 1/4" or 3/16") this is all I could do. You can see the scratch marks in one of these images. And notice how the numbers were damaged by the drilling - move the number down to where you won't drill and/or write the number on the back of the photo before they get out of order.
When done, my stack was STILL a little too thick for the 1-1/4" screw posts I purchased to connect through the stack and both sides of the leather binding. So I had to thin out the stack. To keep the animation fluid, I avoided pulling out sequential images; I ended up having to pull out about 15 of 101 images to get the thickness right - I just went through my stack and pulled out those images that were very close to the image before or after it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:jktechwriter
