3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Handmade Hot Process Soap
This is how I make my homemade soaps that I sell at PoseyCorner.com. There is no real secret to it. Soap has been made like this pretty much for centuries just with different tools.
Fair warning- After I made my first batch of soap, I was hooked. I went out and got more Lye. I ordered more Scents and colorants. Oh boy it can get expensive if your not watching yourself.
Warning: This process involves using Sodium Hydroxide. Otherwise known as Lye. AKA: Drain Cleaner! Use safety precautions! This stuff burns severely when active.
I am going to pretty much walk you through how I made my latest batch of soap. This one I decided to make a round Melt and Pour bar in Orange. I am not going to cover all of that. I just used some Orange Oxide to color some M&P Soap and Poured it into a ½” PVC Pipe.
Hot Process is almost the same as Cold Process. HP just takes it a step further with cooking it the rest of the way.
Step 1Tools
Tools
Tools:
A Scale that reads in Ounces to at least 1 tenth of an ounce. (Example - 1.4 oz)
Electric Stick Blender – You could use a Plastic or wooden Spoon to stir with but you will get tired of that.
Glass Measuring Cups
2 Plastic Measuring Cups – these will be used for the lye and lye water only.
Steel Table or Teaspoons – Used only to scoop out Ingredients out of the containers or Mixing up the coloring. I do not touch the lye with them.
Bamboo Skewers – I use one to stir up the lye into water
Parchment Paper – to line my mold
Wooden Mold – I made myself. You can use other things so you can search for it and get creative.
A Crock Pot – Mine I believe is a 5 Quart. With as small a recipe I use, the soap does not rise out of it during the gelling phase.
Plastic Serving Spoons – Plastic is key. You cannot use Aluminum where it can contact Lye. You will waste the batch that way.
Safety Glasses and Chemical Resistant Glove – In case lye wants to splash on you. You will know when it does.
Bottle of White Vinegar – This helps make the lye inactive if it spills on you or something. I also use some in my Lye and Lye Water Cups before cleaning.
3 comments
May 21, 2011. 6:50 PMerajala says:
Thank you for sharing your process! I successfully made my first batch of soap using your instructions!
May 21, 2011. 8:29 PMerajala says:
I was getting concerned that it was taking too long to get to trace, but I just needed to be patient! It took about half an hour for me.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:poseycorner(Posey Corner)
