3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Handmade Knife
Handmade Knife
In this intructable, I will be showing how to make a fairly simple yet professional handmade knife using 5 basic steps
1 design
2 shape
3 heat treat
4 sharpen
5 finish
When it comes down to it, the actual list of materials in the knife consist of
Steel (1/8" 0-1 in my case) and paracord. I did however use other things like plastic and glue so I will cover that when we get to it
Equipment list
Band saw
Grinder/sander
Vise
Drill press
Clamps
Kiln w/bucket-o-oil
Step 1Design
Design
This step was the easiest; I knew I wanted to make an interesting knife so I started drawing lines until I came up with this guy here. After a little talk with a guy that has made knives for years (my Dad) we changed the design a little, you can see the final design just under the knife.
after the design is printed and cut out, its glued to a piece of plastic in order to make a permanent template, in this case I used an old knife design my dad had laying around.
When the glue dried i used a band saw to make quick work of the excess plastic and then cleaned it up using a sander
21 comments
Nov 2, 2011. 9:23 PMblack hole says:
Could you post something on making a kiln? The heat-treating part of knife making has always been a problem of mine.
Nov 15, 2011. 9:07 PMblack hole says:
Yeah, it was mostly because I didn't have a kiln. So far, all that has happened when I try to heat treat is part of the blade gets to the right temp and then when I try to heat the what's left, the first part cools down. Of course, I'm just using an old (think 30+ years old) propane torch, so that must be a big part of the problem.
I'll poke around and see what I can see.
Thanks for the help,
black hole.
Nov 15, 2011. 6:22 PMblack hole says:
Thanks ; )
Apr 25, 2011. 5:02 PMspark master says:
this thing took out my urls
so add the
for DOT and ad the W's to see the holster
tandyleatherfactory DOT com/search/searchresults/44451-01.aspx
do the same for the sheath kit
tandyleatherfactory DOT com/home/44123-00.aspx
Apr 24, 2011. 9:31 AMspark master says:
SWEET.
I would make wooden grips for it, or bone (or bone over mahogany or a fine grained dark wood). Your dad taught you well cause this is a beaut!! Deserves a fine sheath or scabbard. For scabbard use wood core and thin leather then outside leather and belt loop (I like a safety belt loop, to keep knife in when walking).
again a very very very sweet piece of metal craftwork.
Apr 25, 2011. 4:58 PMspark master says:
heck if this is an old post and you do not have a sream of "WOW can I have one too!!!" then the instructables robot is not doing his job. Your machining was a masterful manipulation of steel. I am not a collector, nor an iron monger/blacksmith. I have made two knives a spoon gouge and a couple of scribes for bone work. I carve when possible and make walking sticks. I am a Boy Scout merit badge counselor for wood carving and leather badge. Simple sheaths are easy and Tandy Leather Craft sells nice kits.
Forget the tooling it is harder then it looks. I modified a kit sorta like this
for a leftie shooter, all the guys at the range loved it. I made it simple for him, I only put his intials on it and then made it totally black (was ehh to me), he loved it.
Two thin pieces of mahogany or maybe ebony , full lenght and two bone inserts even if you just put fancy initials and maybe a cross hatch (knurled?) look would be incredible.
Another , perhaps simpler thing would be same wood then you cut a border with a U gouge around the perimeters and epoxy in a copper or brass wire, (think black ink drawing then you fill in color, like a kids coloring book), if you use yellow bronze wire it will stand off more.
as far as sheaths go a nice one can be made with old leather from a couch and wooden paint stirring sticks, very thing (delaminated) wood paneling. I made one for a scout who made a knife. It was a scabbard since it had a hard sided case covered in whatever I had (bone color, stained sorta brown). It had a curved blade as well and it6 needed to "slide" around the pivot, with out slicing open the sheath. Ergo the paint stick frame. The wood frame, ( a real thick separator piece think washer) was strong enough to withstand removal and insertions. Leather good leather is hard to get nowadays. If you can find a real cobbler (shoemaker), buy heavy duty replacement soles (full sized for size 12. use them for sheaths and attach a belt loop, simple loop stiching is fine but secure it at least two place with rivets.
finally if you make it leather lined, leave suede side to the blade and before gluing/sewing rivetting, rub in generous amount of polishing compound where ever the knife can be. Then any rubbing is a buffing. If they make other compounds that are better in absorbing water or O2 use that.
I wish I had taken pics as I did that.
ciao
Feb 6, 2011. 9:08 AMBrad I. says:
I like your knife a lot. Thanks for the detailed instructions. I want to make one and hand carve a handle. Luckily, my sister owns a kiln for her glassworks ;)
What recommendation do you have for wood. And where can I get steel blanks like what you have? It's tempting to cut up a lawnmower blade.
Feb 7, 2011. 9:49 AMBrad I. says:
Gedian. Thanks for the great tips. I think you're right about the blade blanks. It's a lot of trouble to make a knife to have it mess up due to recycling old parts probably doesn't make sense. I'll also look into that stabilized wood.
Dec 10, 2010. 3:05 AMjimwi says:
Very Nice and great job. I really like the shape but love the simplicity of the handle. I thought of a way to rap the handle with one piece of cord . If you thread the cord threw the second hole first and down to the first hole second, hope that made sense? Then rap the handle you don't have to tie the start ends in and if you ever need to use the cord you will have a nice long piece. Keep up the good work. JIM.
Dec 2, 2010. 4:19 AMDELETED_kage_no_akiri says:
(removed by author or community request)
Nov 30, 2010. 2:30 AMEmcySquare says:
Very Nice indeed I'm starting out some knife making myself.
We must admit that having all the needed tools like the sander and the kiln is a hell of a head start since those are very expensive and uncommon tools to have.
So far so good!!
Keep it up and post your next productions !!
Nov 30, 2010. 10:35 AMgeneral-Insano says:
one thing i learned from grinding with the belt grinder is to sand a notch into wood that you want to use to hold the metal
Nov 30, 2010. 10:23 AMzorba365 says:
cool ... nice knife
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:gedion4000
