Introduction: Handmade Wooden 9 Blocks Wall Clock
Picture of Handmade Wooden 9 Blocks Wall Clock
It is my second wooden wall clock.
Step 1: What Do You Need
Picture of What Do You Need
1. clock mechanism
2. some wood
3. drill with a drill bit paddle (pic.3)
4. wood stain
5. nails
6. glaze with mettalic effect/ optional wax
7. sander
Step 2: Preparation of Wood Blocks
Picture of Preparation of Wood Blocks
First made a solt in the center wood so that the clocks mechanism can fit in.
I didn't had right tool to do a hole - firs I made a hole using a drill bit.
Then I cut off requred wood blocks- 9 sections.
Next sanding the blocks.
Arranged them into square and marked them which one goes where.
Paint wood stain.
Step 3: Fixing Wood Blocks
Picture of Fixing Wood Blocks
Prepare nails: cut the head.
Next: painted and dry blocks connect with nails- like a picture.
Step 4: Surface Finish
Picture of Surface Finish
I used to finish the surface - wax timber.
After applying waxes and dry (min. 2 horus) polished used plastic brush.
Because of the unsatisfactory effect- I painted metalic glaze.
Then I installed a clock mechanism- in the central block.
Step 5: Assembly Clockwise Adn Done
Picture of Assembly Clockwise Adn Done
At the end - mount clockwise and ready.
ClenseYourPallet (author)2016-12-15
Great looking clock. I really like the way you attached the blocks
About This Instructable
877views
37favorites
License:
More by michu19753:Circular Saw ClockClutch Pressure ClockStorage of Things (5 or 6 Minutes Make)
Add instructable to:
