Handy Batch File
Published
Introduction: Handy Batch File
About: I'm a freelance web developer. I love to make websites, whether this is a normal site, a blog or a WordPress-driven website. As a web developer, I'm constantly improving my knowledge and I use modern tools a...
In this Instructable I'm going to show you a Batch File that I created for you people.
so let me explain what this Batch File does. The script let's you generate backups of your files, check your network connectivity, close your not needed Windows services, delete temp files, history and cookies and at last it can show you your computer information.
The reason I made this is because I wanted to give you something awsome and that you can easly modify by your self.
Step 1: Basic Information
* If you don't want the information skip to the next step
Batch files allow MS-DOS and Microsoft Windows users to write a series of commands to run in order upon their execution for automating frequently performed tasks. For example, a batch file could be used to run frequently utilized commands, delete or move a series of files, and other jobs.
Step 2: Setting Up the Menu
If you are copying the code below make sure not to copy my explanation with it. I will put the explanation in the code only when it is new.
::The @ disables echo for that one command.
@ECHO OFF
::Clear the screen/window
CLS
::Executes the code from here. This is also called a "label"
:MENU
::Empty rule
echo.
::Display text on screen
echo  -----------------------------------
echo             Windows Tool
echo  1. Generate Backup of Files (enter 7 to see information)
echo  2. Check Network Connectivity
echo  3. Close Not Needed Windows Services (enter 6 to see services)
echo  4. Deletes Temporary Internet Files, History and Cookies
echo  5. Show Computer Information
echo  Help
echo  Exit
echo.
::Sets M to the given input from the user
SET /P M=Choose and then press ENTER:
:: Note - list ERRORLEVELS in Decreasing order
::Checks if M is equal to the variables given below
IF %M%==exit GOTO End IF %M%==help GOTO Help if %M%==about GOTO About IF %M%==7 GOTO BackupInfo IF %M%==6 GOTO ShowServices IF %M%==5 GOTO GetComputerInfo IF %M%==4 GOTO DeleteCache IF %M%==3 GOTO CloseSomeServices IF %M%==2 GOTO CheckNetworkConn IF %M%==1 GOTO CreateBackup
Step 3: Setting Up the Functions
FIrst we're going to create all of the function that we need for this batch. In the next step we will fill them in with the correct code.
:About
echo.
echo ----------------------------------------------------------------- echo About echo ----------------------------------------------------------------- echo.
GOTO MENU
:Help
echo.
echo ----------------------------------------------------------------- echo Help echo -----------------------------------------------------------------
echo.
GOTO MENU
:BackupInfo
echo.
echo ----------------------------------------------------------------- echo Backup Information echo -----------------------------------------------------------------
echo.
GOTO MENU
:CreateBackup
echo.
echo ----------------------------------------------------------------- echo Creating Backup, please wait... echo -----------------------------------------------------------------
echo.
GOTO MENU
:CheckNetworkConn
echo.
echo ----------------------------------------------------------------- echo Checking connection, please wait... echo -----------------------------------------------------------------
echo.
GOTO MENU
:TRYAGAIN
echo.
echo Failure! echo.
echo.
:TRYIP
echo.
:TRYROUTER
echo.
echo Failure! echo.
echo.
goto :FAILURE
:ROUTERSUCCESS
echo.
echo Failure! echo.
echo.
goto :FAILURE
:NETDOWN
echo.echo  Failure!
echo.
echo.
goto :FAILURE
:SUCCESSDNS
echo.
echo Failure! echo.
echo.
goto :FAILURE
:SUCCESS
echo.
echo Success! echo.
echo.
goto MENU
:SUCCESS2
echo.
echo Success? echo.
echo.
goto MENU
:FAILURE
echo.
echo Failure! echo.
echo.
goto :MENU
:ShowServices
echo.
echo ----------------------------------------------------------------- echo Services That Will Be Stopped echo -----------------------------------------------------------------
echo.
GOTO MENU
:CloseSomeServices
echo.
GOTO MENU
:DeleteCache
echo.
echo ----------------------------------------------------------------- echo Deleting Internet Cache... echo ----------------------------------------------------------------- echo.
GOTO MENU
:GetComputerInfo
echo.
echo ----------------------------------------------------------------- echo Show Computer Information (%computername%) echo ----------------------------------------------------------------- echo.
GOTO MENU
:End
Step 4: Filling Up the Functions
Now let's fill them in! insert the code below under the the last echo with --------
:about
echo This batch file was created by Kevin Tipker in June 2016
echo and is free to use and modify on your own risk. Please be very echo carefull if you don't understand what you are doing echo. echo You can find more of my work in the link below. echo - https://www.instructables.com/member/Kevin+Tipker
:Help
echo * To run this bat file without any problems you need to be a Administrator
echo and execute it as Administrator echo. echo 1. Generate Backup of Files (enter 7 to see information) echo - Check if there is a map called Backup in C:/ If not create it echo. echo 2. Check Network Connectivity echo - Make sure to use LAN echo. echo 4. Deletes Temporary Internet Files, History and Cookies echo - The history, cookies etc files are located in echo C:\Documents and Settings\username\Local Settings\Temporary Internet Files
:BackupInfo
echo This process will make a backup of the following files:
echo - My Documents echo - Favorites echo - Email and contacts (MS Outlook) echo - Backing up email and address book (Outlook Express) echo - Registry echo. echo * NOTE: There is a change that not everything will be backed up echo and that is because you maybe not have MS Oulook or Outlook Express
:CreateBackup
:: variables
::this has to be above the title rule (see image 5)
set drive=C:\Backup set backupcmd=xcopy /s /c /d /e /h /i /r /y
echo - Backing up My Documents...
%backupcmd% "%USERPROFILE%\My Documents" "%drive%\My Documents"
echo - Backing up Favorites... %backupcmd% "%USERPROFILE%\Favorites" "%drive%\Favorites"
echo - Backing up email and address book (Outlook Express)... %backupcmd% "%USERPROFILE%\Application Data\Microsoft\Address Book" "%drive%\Address Book" %backupcmd% "%USERPROFILE%\Local Settings\Application Data\Identities" "%drive%\Outlook Express"
echo - Backing up email and contacts (MS Outlook)... %backupcmd% "%USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook" "%drive%\Outlook"
echo - Backing up the Registry... if not exist "%drive%\Registry" mkdir "%drive%\Registry" if exist "%drive%\Registry\regbackup.reg" del "%drive%\Registry\regbackup.reg" regedit /e "%drive%\Registry\regbackup.reg"
echo. echo Backup Complete!
:CheckNetworkConn
ping -n 1 www.google.com >nul
@echo off IF NOT ERRORLEVEL 1 goto :SUCCESS IF ERRORLEVEL 1 goto :TRYAGAIN
:TRYAGAIN
echo - Let me try a bit more, please wait...
@echo off ping -n 1 www.google.com >nul IF NOT ERRORLEVEL 1 goto :SUCCESS2 IF ERRORLEVEL 1 goto :TRYIP
:TRYIP
echo - Checking DNS...
echo - Lets try by IP address... @echo off ping -n 1 216.239.37.99|find "Reply from " >NUL IF NOT ERRORLEVEL 1 goto :SUCCESSDNS IF ERRORLEVEL 1 goto :TRYROUTER
:TRYROUTER
echo - Lets try pinging the router....
ping -n 2 192.168.1.1|find "Reply from " >NUL IF NOT ERRORLEVEL 1 goto :ROUTERSUCCESS IF ERRORLEVEL 1 goto :NETDOWN
:ROUTERSUCCESS
echo - It appears that you can reach the router, but internet is unreachable.
:NETDOWN
echo - It appears that you having network issues, the router cannot be reached.
:SUCCESSDNS
echo - It appears that you are having DNS issues.
:SUCCESS
echo - You have an active Internet connection
:SUCCESS2
echo - You have an active internet connection but some packet loss was detected.
:FAILURE
echo - You do not have an active Internet connection
:ShowServices
echo - ActiveX Installer (AxInstSV)
echo - BitLocker Drive Encryption Service echo - Printer Extensions and Notifications echo - Print Spooler echo - Optimize Drives echo - http service (for problems with localhost servers like XAMP)
:CloseSomeServices
::You can add diffrent services here just search them up on google
net stop AxInstSV
net stop BDESVC net stop PrintNotify net stop Spooler net stop defragsvc net stop http
:DeleteCache
::This is not everything you can use there are some more that you can use to delete internet files from your pc
echo - Starting process...
RunDll32.exe InetCpl.cpl,ClearMyTracksByProcess 8 RunDll32.exe InetCpl.cpl,ClearMyTracksByProcess 2 RunDll32.exe InetCpl.cpl,ClearMyTracksByProcess 1 echo - Done!
:GetComputerInfo
REM set variables
set system= set manufacturer= set model= set serialnumber= set osname= set sp= setlocal ENABLEDELAYEDEXPANSION set "volume=C:" set totalMem= set availableMem= set usedMem=
echo Getting data [Computer: %computername%]... echo Please Wait....
REM Get Computer Name FOR /F "tokens=2 delims='='" %%A in ('wmic OS Get csname /value') do SET system=%%A
REM Get Computer Manufacturer FOR /F "tokens=2 delims='='" %%A in ('wmic ComputerSystem Get Manufacturer /value') do SET manufacturer=%%A
REM Get Computer Model FOR /F "tokens=2 delims='='" %%A in ('wmic ComputerSystem Get Model /value') do SET model=%%A
REM Get Computer Serial Number FOR /F "tokens=2 delims='='" %%A in ('wmic Bios Get SerialNumber /value') do SET serialnumber=%%A
REM Get Computer OS FOR /F "tokens=2 delims='='" %%A in ('wmic os get Name /value') do SET osname=%%A FOR /F "tokens=1 delims='|'" %%A in ("%osname%") do SET osname=%%A
REM Get Computer OS SP FOR /F "tokens=2 delims='='" %%A in ('wmic os get ServicePackMajorVersion /value') do SET sp=%%A
REM Get Memory FOR /F "tokens=4" %%a in ('systeminfo ^| findstr Physical') do if defined totalMem (set availableMem=%%a) else (set totalMem=%%a) set totalMem=%totalMem:,=% set availableMem=%availableMem:,=% set /a usedMem=totalMem-availableMem
FOR /f "tokens=1*delims=:" %%i IN ('fsutil volume diskfree %volume%') DO ( SET "diskfree=!disktotal!" SET "disktotal=!diskavail!" SET "diskavail=%%j" ) FOR /f "tokens=1,2" %%i IN ("%disktotal% %diskavail%") DO SET "disktotal=%%i"& SET "diskavail=%%j"
echo. echo ----------------------------------------------------------------- echo Computer Information echo ----------------------------------------------------------------- echo - System Name: %system% echo - Manufacturer: %manufacturer% echo - Model: %model% echo - Serial Number: %serialnumber% echo - Operating System: %osname% echo - C:\ Total: %disktotal:~0,-9% GB echo - C:\ Avail: %diskavail:~0,-9% GB echo - Total Memory: %totalMem% echo - Used Memory: %usedMem% echo - Computer Processor: %processor_architecture% echo - Service Pack: %sp% echo -----------------------------------------------------------------
Step 5: Finished!
You have finished your batch file! I hope I was clear enough with my explanations and otherwise dont be scared to ask me anything. In the future I will update the script some more and maybe even add some more functions.
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    4 Comments
    @ECHO OFF
    CLS
    :MENU
    ::Empty rule
    echo.
    echo Windows Tool
    echo Help
    echo Exit
    echo.
    :About
    echo.
    echo About
    echo.
    echo.
    GOTO MENU
    :Help
    echo.
    echo Help
    echo.
    echo.
    echo.
    echo.
    GOTO MENU
    :BackupInfo
    echo.
    echo - My Documents
    echo - Favorites
    echo - Registry
    echo.
    echo.
    GOTO MENU
    :CreateBackup
    echo.
    :: variables
    set drive=C:\Backup
    echo.
    echo.
    GOTO MENU
    :CheckNetworkConn
    echo.
    @echo off
    :FAILURE
    echo.
    GOTO MENU
    :TRYAGAIN
    echo.
    echo Failure!
    @echo off
    echo.
    echo.
    :TRYIP
    echo.
    @echo off
    :TRYROUTER
    echo.
    echo Failure!
    echo.
    echo.
    goto :FAILURE
    :ROUTERSUCCESS
    echo.
    echo Failure!
    echo.
    echo.
    goto :FAILURE
    :NETDOWN
    echo.
    echo Failure!
    echo.
    echo.
    goto :FAILURE
    :SUCCESSDNS
    echo.
    echo Failure!
    echo.
    echo.
    goto :FAILURE
    :SUCCESS
    echo.
    echo Success!
    echo.
    echo.
    goto MENU
    :SUCCESS2
    echo.
    echo Success?
    echo.
    echo.
    goto MENU
    :FAILURE
    echo.
    echo Failure!
    echo.
    echo.
    goto :MENU
    :ShowServices
    echo.
    echo.
    GOTO MENU
    :CloseSomeServices
    net stop AxInstSV
    net stop BDESVC
    net stop Spooler
    net stop defragsvc
    net stop http
    echo.
    GOTO MENU
    :DeleteCache
    echo.
    echo - Done!
    echo.
    GOTO MENU
    :GetComputerInfo
    echo.
    REM set variables
    set system=
    set manufacturer=
    set model=
    set serialnumber=
    set osname=
    set sp=
    set "volume=C:"
    set totalMem=
    set availableMem=
    set usedMem=
    REM Get Computer OS
    REM Get Memory
    SET "diskavail=%%j"
    echo.
    echo.
    GOTO MENU
    :End
    I got it working. You really should post the text all in one block, not taking the code out of the functions. I had to do so much copying and pasting and removing extra headers because of the messed up way you shared this. Thanks, though.
    None of this works.
    192.168.0.1 is quite a bit more common for routers than 192.168.1.1.
    Shouldn't your script just simply look up what the gateway is and ping that?
