Introduction: Handy Polarity Checker
Picture of Handy Polarity Checker
Electrical polarity (positive and negative) is present in every electrical circuit. Electrons flow from the negative pole to the positive pole. In a direct current (DC) circuit, one pole is always negative, the other pole is always positive and the electrons flow in one direction only. In an alternating current (AC) circuit the two poles alternate between negative and positive and the direction of the electron flow reverses.
A light-emitting diode (LED) is a semiconductor device that produces light from electricity. LEDs last a long time and do not break easily (compared to incandescent lightbulbs). They can produce many different colors. They are efficient - most of the energy makes light, not heat.
An LED is a type of DIODE that makes one color of light when electricity is sent through it in the expected direction (electrically biased in the forward direction). This effect is a kind of electroluminescence.
A diode is an electronic component with two electrodes (connectors). It allows electricity to go through it only in one direction.
Today, the most common diodes are made from semiconductor materials such as silicon or sometimes germanium.
This polarity checker is super handy,and can indicate the polarities of a battery or it maybe LEDs etc.
The indication is done by blinking of led.
Step 1: Components Required
Few LEDs.
Few Resistances 330 ohms-1k ohm.
Battery we have used a 9V.
Female Connectors.
Breadboard or a PCB depends how you want to make it.
Couple of wires.
Step 2: Whats Happening
Picture of Whats Happening
Connect the circuit as shown in circuit diagram..
Power Supply Polarity Checker
There are two LEDs both connected as the mirror of each other.Now as you might already know that LEDs are just simple diodes.Depending upon how you are connecting the LEDs one will become forward bias ie. it will allow current flow through it, and the other will become reverse bias ie. no current flow.The only purpose of connecting a resistor is to save the LED from fusing.The diode then forward biased will conduct current this is how the particular LED will glow.Indicating the polarity of the battery.
LED Polarity Checker
An extremely simple circuit,but still.
The positive terminal of the power source is connected to the resistor and so to the connecting port,the negative terminal to the other connecting port,thus completing the circuit.Now if someone inserts for example a LED,it wont glow until the diode inside it is forward biased,for this the positive leg of the LED has to be inserted in the port connected to the positive terminal of the battery.Now you can find the terminals even the legs are even.
Step 3: Final Product
Picture of Final Product
After soldering it on a PCB it should look something like this.The casing is just to make it look more professional.
Treker2 (author)2015-08-13
You should consider getting a 3d printed/laser cut enclosure for it!
ukdiveboy (author)Treker22015-10-07
Here's the one i made in a 3D housing:http://www.thingiverse.com/thing:152024
GrinninSam (author)2015-08-15
This is a really cool project! I made a little board for this, that can be built up with either through-hole parts, or surface mount parts, take your pick. The layout and other files can be found on my new website solderguy.com/forums/topic/interesting-project-share/
If you build it let me know what you think! Thanks Erfinden, you guys rock!
nwonharp (author)2015-08-14
Actually you can get an LED that has a red and a green LED in the same package , I have used them before . It has two leads coming out of it , the LED's are connected internally like your circuit . If you connect it one way , the red one will light , the other way will light the green one . If you connect it to AC ( not the mains , of course ! ) , they will alternately light , and due to our persistence- of-vision , it will appear to be yellow ! You still need to have the proper resistor in series for whatever voltage you are working with to limit current .
Cheers , take care , and have a good day !.... 73
Erfinden (author)nwonharp2015-08-14
thnkx for ur suggestion
bdavisacc (author)2015-08-14
Good idea. I would recommend at least a mild warning about how high of a voltage you think is allowable/safe with this.
Erfinden (author)bdavisacc2015-08-14
ya. its just for small dc batteries and leds.
will work on big ac polarity checkers too..thnkx
GrinninSam (author)bdavisacc2015-08-14
Good point. If you plugged this into an ac outlet, it would get very unhappy! ;-)
Awesome! Fun little build
About This Instructable
3,705views
75favorites
License:
Bio: We are 4 Electronics Engineer working towards the betterment of new technology and bring to you the basic as well as advanced instructables one can ... More »
More by Erfinden:Interfacing SIM900A GSM Modem with ArduinoHandy Polarity CheckerMagic Wand  POV Message Display using Bluetooth Module
Add instructable to:
