Handy Tricks 7: Bike Mods and Projects
Step 14Welding Clamp Without Marring Paint
Star says:
I've been learning a ton of stuff from Mars lately at MITERS:.
Need to weld your new chop-tacular? Where do you clamp onto the frame without screwing up the
paint job?
THE PEDALS! It works!
7 comments
Oct 28, 2009. 12:02 PMHughBothwell says:
I would recommend finding a junk seatpost. Drill a hole through it side-to-side about two inches from the top, stick a bolt through, and weld it in place.
Now remove your seat, stick the ground-post in, and clamp your ground on the bolt. Voila! Nice clean ground without paint damage.
Oct 1, 2009. 3:12 PMMT-LB says:
one of the first things in the manual for my welder says "do not run circuit through bearings"
Oct 14, 2009. 7:59 AMBidul says:
+1
Even if it seems to be a great idea at first sight, heavy current isgoing to "solder" balls in the ball-bearing.
Use any other paint-free metalic area on the frame (seat support, for instance)
Aug 14, 2009. 12:29 PMcsorrows says:
To put it simply, DO NOT DO THIS!
Oct 5, 2008. 2:37 PM79spitfire says:
Do not ground the welder like this, it will cause pits in the bearings and lead to an early failure of the bearings.
Jul 28, 2008. 2:41 AMPierce14u2 says:
You may not want to place the welding ground there due to chances of melting the bearings if there is not alot of contact points for the elecricity flow. I have melted Bearings that way before but I think my main issue was that I didn't have the bearingins in tight so there was even less contact points.
Jul 4, 2008. 12:53 PMjoetinker says:
Em, prolly not a good idea if you value you're ball bearings...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1190
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
