It's a pair rings of screw and nut. Perfect for DIYers, and perfect fits for lovers. The idea comes from A Perfect Fit. The original is from Kiley Granberg. The original rings are made from 24-karat gold, starting about $2,500!
Don't worry, if you don't have that much money like me, I've made an alternative costs only about 25 cents. And if you're handy enough, it won't take you more than 15 mins.
OK, let's get started. Valentine's Day is not far away.
Remove these ads by
Signing UpStep 1What you need?
- 1 x Brass screw and nut, #6, available from hardware store.
- #14 copper wire, 6" long. I took a ground wire from the #14 cable.
Tools:
- solder iron and solder (avoid Pb, use lead-free solder. Thanks worldgnat)
- vice
- hacksaw
- steel wool, hammer, pliers
Although I'm unsure how the soldering of the nut and bolt would go..
BTW, solder designed for electronics work is not intended to provide much of a mechanical bond. In my experience you could expect the nut or bolt to fall off within weeks of regular wearing... faster if you are very active. "Silver solder" designed for plumbing would provide a slightly stronger joint. As previously allude to, avoid any solder with ANY lead (Pb) in it as lead is fairly toxic and would absolutely absorb through your skin.
There are better metals to make jewelry from, the problem is really the combination of being both malleable and safe. Silver, if you use the right alloy, is pretty awesome at that though, and is not ridiculously expensive.
lawl. sounds like a break up message xDD
Great idea!! I love it!
http://www.amazon.com/Sex-Dummies-Dr-Ruth-Westheimer/dp/1568843844
that would be neet !
Definately a Heart Winner!
