3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Handyman's Valentine gift - Screw-Nut rings pair - Home made in 15 mins
Handyman\
Still not get a Valentine gift ready for your love? Here's one you can make in 15 mins. Actually it's one pair - for you and your loved one.
It's a pair rings of screw and nut. Perfect for DIYers, and perfect fits for lovers. The idea comes from A Perfect Fit. The original is from Kiley Granberg. The original rings are made from 24-karat gold, starting about $2,500!
Don't worry, if you don't have that much money like me, I've made an alternative costs only about 25 cents. And if you're handy enough, it won't take you more than 15 mins.
OK, let's get started. Valentine's Day is not far away.
Step 1What you need?
What you need?
Materials:
- 1 x Brass screw and nut, #6, available from hardware store.
- #14 copper wire, 6" long. I took a ground wire from the #14 cable.
Tools:
- solder iron and solder (avoid Pb, use lead-free solder. Thanks worldgnat)
- vice
- hacksaw
- steel wool, hammer, pliers
85 comments
1-40 of 85next »
Feb 13, 2010. 6:51 AMyeah i know says:
Is this implying something? LOL
Feb 7, 2012. 12:17 PMimshanedulong says:
That's what I was thinking...
Jun 6, 2010. 6:45 PMraja681 says:
by #14 copper wire would 14 be the gauge
Dec 13, 2011. 9:38 PMjdavis65 says:
Yup yup. #14 is 14 guage
Feb 18, 2010. 6:04 AMgibson_se says:
When you cut the screw, you will mess up the thread a bit. It might be a good idea to do a couple of test fits before giving the gift and trying them on "for real", so you don't have to deal with messy threads with your significant other.
May 4, 2011. 12:53 PMalterator says:
to not fu** up threads while cutting, screw the nut all the way to the end, then cut it and take the nut off. this way the threads will straighten out. afterwards -- smooth sharp edges down.
Dec 17, 2010. 7:40 PMmikesnyd says:
If you have a jewelers saw you could save the cutting of the screw till the end. After its all soldered up screw em together and with the excess sticking through cut it off with the jewelers saw. When you unscrew them it will bend the cut end back into the right thread. Justa little sanding or light filing to remove the fine edge and you will be ok.
Jan 13, 2011. 6:56 AMAuzzieGuy42 says:
You could make the original rings out of old coins.
Although I'm unsure how the soldering of the nut and bolt would go..
Jul 24, 2010. 9:55 PMarb1ter says:
im either gonna make this or a silver ring out of quarter for my girlfreind for valentines day im cheap, she knows it, she loves me
Mar 23, 2010. 5:36 PMWarlrosity says:
I like the pun
Feb 13, 2010. 11:33 AMcollin14 says:
hey has anyone considered to make these into brass Knuckles?
Feb 13, 2010. 6:24 PMsanty22 says:
 You can wear 4 screws, a little bit longer, and you got yourself some extreme pain.
Mar 9, 2010. 4:59 PMdoughnutguy1 says:
>:D
Feb 16, 2010. 4:35 AMShroomy says:
Hello guys and ladies..I have noticed that everyone knows Pb ist poisionious, Very good! but oxidated copper is really harmfull too ! ( thats why in old times people coated the copper cooking pots with "tin-coat"... Please remember this fact too.. Thanks..  Best choice is Brass for me..I was seeman and brass is everywhere.. :D.. God speed all of you and your hand-craft !
Feb 14, 2010. 2:29 PMWhackmaster says:
My local Target store has 10K plain band rings for $20-50, depending on size and frills.  I would think a pawn shop would have a variety of plain band rings for $10-20.  That would be a bit more expensive than a small strip of copper wire, but it would be much more durable and have no deleterious health consequences or funny green discoloration.
BTW, solder designed for electronics work is not intended to provide much of a mechanical bond.  In my experience you could expect the nut or bolt to fall off within weeks of regular wearing... faster if you are very active.  "Silver solder" designed for plumbing would provide a slightly stronger joint.  As previously allude to, avoid any solder with ANY lead (Pb) in it as lead is fairly toxic and would absolutely absorb through your skin.
Feb 12, 2009. 2:45 PMWeissensteinburg says:
Nice job. If you wanted a thicker band, like the actual ones have, conduit or some similar pipe would work.
Feb 12, 2009. 2:58 PMj626no says:
i actually thought for a more handmade feel, you could just use thicker copper wire and hammer it flat. just a thought.
  • my only concern is that the copper would make the wearer's finger turn green...perhaps try a more expensive metal to avoid this.
Feb 12, 2009. 5:33 PMsmurfsahoy says:
Your skin doesn't know how much a metal costs... There are cheap metals that do not stain your skin. Aluminum, for example, or stainless steel. Depending on the product you buy, these could easily be even cheaper than copper. You can also just put some kind of clear enamel or similar onto copper jewelry to prevent this. It will be shiny and have a different look, but if that's okay...
Feb 13, 2010. 2:01 AMporcupinemamma says:
ummm ...you might want to skip the aluminum.  I've heard it's not good to cook with aluminium pots, so I'm thinking wearing it on your skin might be unhealthy too.
Feb 16, 2009. 9:58 PMj626no says:
sorry. i didnt mean expensive like that...copper is actually a rather expensive metal. poor diction on my part. i have actually posted an instructable on making an aluminum ring by hand. Aluminum ring
Feb 12, 2010. 1:09 PMMrPumpernickel says:
Really, aluminium isn't really good for making jewelry either. The long term health hazards of long term aluminium exposure can have detrimental effects on your nervous system and brain affecting things like memory.
There are better metals to make jewelry from, the problem is really the combination of being both malleable and safe. Silver, if you use the right alloy, is pretty awesome at that though, and is not ridiculously expensive.
Sep 28, 2010. 10:53 AMsugarsong says:
This isn't a proven fact, so far as I know. My phsychology teacher explained that there is a correlation between aluminum and certain health issues, but correlations do not prove cause and effect. For instance, there may be a correlation between six year olds being hit by cars and their haveing had peanut butter and jelly sandwiches for lunch. Correlation, not cause and effect. But maybe there are some new studies out that I havent heard about, entirely possible. If so, that would be good to know:) Thanks for looking out for everyones health:)
Feb 12, 2009. 10:41 PMthepelton says:
If you are looking for alternative metals, do not use nickel. It can cause a rash.
Feb 12, 2010. 8:51 AMknottynaz says:
NICE! This will be an unusual gift to give to my hubby. Thanks for something fresh
Feb 12, 2010. 6:08 AMNKumiko says:
One thing you can tell your lover = "Screw you!"
lawl. sounds like a break up message xDD
Great idea!! I love it!
Feb 11, 2010. 5:56 PMbonecholampworks says:
Wonderful!!!
Feb 12, 2009. 9:44 PMbowmaster says:
So is the nut the guys and the bolt the girls? Or the other way around?
Feb 11, 2010. 2:34 PMRedBinary says:
 I've seen that book && always wonder "Why encourage them to reproduce?"
Feb 13, 2009. 8:32 PMbowmaster says:
So the not is the girls? I just thought that the nut might be the guys.
Feb 14, 2009. 7:44 AMjongscx says:
Without being too explicit.... The nut is the receiver and the bolt is the emitter...
Feb 21, 2009. 1:46 AMstatic says:
That or use plumbing terms. Female thread, male thread.
May 14, 2009. 6:46 PMmg0930mg says:
Yeah, cause that didn't confuse anyone... /sarcasm
Feb 11, 2010. 1:30 PMjessandstavro says:
So clever! Even if you didn't have the original concept, the 25cent version gets extra points!
Feb 11, 2010. 8:42 AMDystonia says:
Now for the final touch -have them gold plated !
that would be neet !
Feb 11, 2010. 8:22 AMcal-mi says:
You should get lead-free solder that is suitable for water supply piping (and jewelry) at hardware or plumbing supply store.
Feb 11, 2010. 7:51 AMchoch says:
If you want a better band use Brass instead of Copper. The easiest way is to go to a welding supply shop and buy a brass brazing rod. It  usually comes coated with flux but it taps off very easily. Using finer brass wire but twisting several strands would also make it look very professional.
Feb 11, 2010. 7:02 AMShippingGuy says:
Very Cool Idea!
Definately a Heart Winner!
Mar 2, 2009. 8:49 PMTwicebak3dpotato says:
Am I the only one thinking this? "WONDER TWIN POWERS; ACTIVATE!"
Feb 11, 2010. 6:35 AMbethiekat says:
.....TOTALLY what I was thinking too. Really.
1-40 of 85next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:Taotaoba
