3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hang Up Your Old Vinyl Records!
A few months ago I came across a huge load of my dad's old records and decided to hang them up on an empty wall in my room. I first tried using tacks on the outside of the record sleeve to hold them in place which failed miserably. Next, I tried using "Earthquake" antique and glassware putty and woke up with a pile of records on top of me that had fallen overnight. Finally, I went off to Home Depot and found someone who kind of knew what they were talking about.....
Step 1Getting The Tile Trim
At Home Depot I found an employee who recommended using some plastic tile trim for the project. So, I picked up about ten pieces of 1/4" x 6' of QEP Black Plastic Tile Trim: http://www.qep.com/index.php?q=node/381 , which ended up running me only about $30, much cheaper than any of my other options. The tile trim also has very convenient holes which I put standard wall screws through to hang the trim.
44 comments
1-40 of 44next »
Mar 25, 2012. 2:38 PMjm728 says:
Hey! Just completed our album art wall using this instructable and totally love it!! Thanks for the great idea!
Mar 17, 2012. 8:00 PMiop23 says:
Is there another way without have to drilling the wall?
Feb 15, 2012. 5:52 AMgerdarules says:
Thanks for the great idea, I redid the design a little bit to make it easier to play the records that are on display.
Mar 1, 2012. 8:39 AMtogepi258 says:
For this, did you just use the same tile trim, but only on the bottom? I'm thinking of doing this instead. Thank you =)
Feb 28, 2010. 1:03 PMmga12 says:
Great instructable! I didn't have as much wall space so I cut the tile trim in half and only did three rows but I think it turned out pretty sweet!
Apr 23, 2011. 7:43 PMratch333 says:
So where did everyone get the trim? I went to home depot last night and they didnt have the kind that was in the instructions above. Any help would be greatly appreciated. The trim seems perfect but If all else fails, I guess the ikea option is all I have left.
Thanks!
Nov 22, 2011. 6:26 PMKoelker12 says:
http://www.homedepot.com/h_d1/N-5yc1v/R-100122327/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
I used this stuff. It was in the aisle with all the tile, grout and mixes, on the very end.
You could always use their store check to see if they have any in stock first
Nov 1, 2011. 3:32 PMKoelker12 says:
Hey man, I just wanted to say thanks, this was a great idea and I just did it in my apartment. Here's a pic.
Nov 22, 2011. 1:00 PMtdogg241 says:
Hey, where did you get the tile trim? I asked about it at Home Depot and got a blank stare. What they showed me doesn't seem like it'll work; it's pretty different from what's shown in the instructable.
Nov 22, 2011. 6:25 PMKoelker12 says:
I used this stuff
It was in the same aisle as the tile, grout and stuff. At mine it was right on the very end of the row.
Aug 21, 2011. 1:33 AMtcoatsworth says:
i have wanted to hang my vinyl albums (300) on my wall for years....this idea was brilliant.....worked perfectly..except i had to use a 10mm piece of "tile edging above each album to stop them tipping forward........not too much trouble....two lengths of "tile edging"...a tube of "grip fill"....spirit level...tape measure and a pencil...£10 the lot...looks great.....and i can change them any time.....and i done the same for my cd's (500)....just used a bigger tile edge......
Aug 9, 2010. 11:28 AMRivalee Redesign says:
Great solution! I did a similar project but really wanted to be able to take out the records and play them easily, so I used two pieces of trim to build out a little ledge so that they lean back just enough not to need a top rail. Plus that let me paint the trim because I love color - just don't paint the inside of the rail so that your record sticks to the paint over time!!
Jan 5, 2011. 12:00 PMsnelpiller says:
I also wanted to be able to get to my records easily, I see you used trim, I bought my shelfs at IKEA x)
they are very thing tho, only sticking out about 6cm
Dec 30, 2010. 12:57 PMrockgardner says:
Records are more than just the material they're made from, much like books are more than just paper and ink. Please respect the potential value of what you may be destroying. And by value, I don't mean monetary value. Great efforts are being made by many people to locate and preserve rare and nearly extinct recordings. This is for archival purposes, not for profit. Where would we be if we had used the musical transcripts of our classical forfathers for paper mache'? So please do your research. And if you're one with a valuable collection, please inform your loved ones or note it in your will. And fyi, there is a rebirth of interest in vinyl recordings, both new and old. More new recordings were sold on vinyl in the past ten years than since the 80's.
Nov 30, 2010. 2:30 PMmrb400 says:
Thank you!
Sep 5, 2010. 10:45 AMrudykazoo48046 says:
Very interesting!
Jul 13, 2010. 1:01 PMTabbyDeAnne says:
This is a great idea! I have a collection of about 300+ records (I love the sound of records) and have put them in the record frames which holds only one at a time. I have been looking for a way to display my favorites and this is a fantastic starting point for me! Wonderful job! It looks easy to slide out a record if I want to listen to it. Awesome!
Jul 9, 2010. 8:17 AMxtian5 says:
...and then your dad walks in and says, "Oh my god! What the f--- did you do with my records!"
Apr 23, 2010. 12:14 AMverdilicious says:
i really want to try to find a way to do this where i can easily take my records down to play them.  i've been trying to think of a way even before i found this instructable, but i cannot seem to come up with any good ideas.  how long does it take you to get a record out if you need to?
Dec 11, 2008. 5:02 AMvinyl_rhino says:
This is awesome, I've been trying to think of a way to get my records on the wall without damaging the covers, I think I may try this. One question though. Does this leave "track" lines on the top and bottom of the album cover? It seems like if the tile trim is really tight, it would leave a little indentation in the album cover.
Feb 28, 2010. 1:09 PMmga12 says:
I tried it and the trim isn't too tight that it would leave a mark, the tile trim actually seems like the perfect thing for the job.
Aug 11, 2009. 9:40 AMjonesygirl07 says:
Awesome wall! I have the actual lps on my wall randomly placed and every time some one walks into the living room they are always impressesd. And i have several "worth money" lps but with the sentemental value behind them i could never sell them for any amount of money lol. I think it is cool to hold on to these records not only cuz they are from a past generation but to keep that era of music alive. there will never be that kind of music again :(
Apr 24, 2009. 3:35 AMartist without a medium says:
Awesome...We made our own Tiki Bar a while back. Have over 150 Tiki mugs, sets of salt-n- pepper shakers, coconut monkeys, wooden tikis, etc., and around 25 records so far. Framed 4 of the records just for the art of the Covers (frames cost around $10.00 each unless found on sale). But couldn't afford 20 more frames, and it's a pain if you want to actually listen to them to remove from frame everytime. So I'll definenately be using your idea soon. Thanks
Mar 7, 2009. 2:09 PMliquifury says:
This is awesome! Thanks! I have been looking for a way to hang all my 80's hair bands LP's on my wall. Cheap and easy way to put them up! Now it is just convincing my wife it looks good ;-)
Aug 29, 2008. 3:58 PMbeahelf says:
This is cool! I also have had success with J-Rail for siding and end caps for paneling. These come in longer Lengths for longer walls and they come in Colors as well as wood grain.
Aug 9, 2008. 9:36 AMeter says:
Great idea, I have many off the orig. Beatles / Grand Funk / James Taylor / etc. just sitting in a box in the basement collecting dust. This will be a great way to display. The wife and I may have a spat or two where I am going to hang it, may be in the basement. Thanks again for sharing.
Jun 24, 2008. 11:48 AMBuzzKilling says:
This post made me signup to comment. Then as if the site knew why, I see this box telling me to be nice. So I will be nice. A quick trip to the used record store will get you that entire wall for about $20. There is nothing there that stands out as being worth anything. You dont know if those are even first pressings. People love to say nay. Thats a great thing to do with those albums. It is so common to think that because something was made before you were born, its worth something. If anyone wants to buy large crates of 78's from the early 1900's by all means get in touch. Nice job with the wall. All good bands, good albums, nothing collectible there. No worries.
Jul 20, 2008. 8:38 AMjaneoblivian says:
He's right about those albums in your photo. Not worth much more than $20. Go to any used record store and they are going to have an excess of these albums. Value is all about rarity. ($$ value, of course, not sentimental). Anywho, I like your 'structable. I'm probably going to try it in my new apartment... but what a pain it'll be if I want to play one of them! :) maybe just a single row will work for me.
Jun 24, 2008. 8:55 AMJeremy B says:
Very cool. I have been looking for a cheap effecttive way to display all my old record covers, and buying a bunch of frames was just out of the question ($). Thanks for the tip!
Apr 20, 2008. 1:18 PMTrans_Am says:
All those wonderful albums... sitting... wasted. People would pay good money for those records.
Jun 17, 2008. 7:43 PMbumpus says:
they aren't necessarily wasted, he turned them into a Vinyl Quilt of sorts, instead of having them sit in a box somewhere collecting dust. lemon-aid outta lemons
Apr 21, 2008. 8:15 PMwolfmanthe says:
I've been looking for a way to do this. Excellent albums by the way.
Apr 21, 2008. 11:15 AMdrummonkey92 says:
wow ur dad has great taste in music
Apr 20, 2008. 8:21 PMPatrik says:
Very nice solution! One thing you may want to consider is some kind of plastic sleeves, so the covers don't get bleeched by the light. Even if they don't get direct sunlight, just a few months of exposure can make a significant difference in the intensity of teh colors...
Apr 20, 2008. 5:16 PMLinuxH4x0r says:
cool, I wish I had that many awesome records
Apr 20, 2008. 4:43 PMbeauwalker23 says:
wow, you have alot of money on thatt wall.......can i have them!!
Apr 20, 2008. 2:49 PMGorillazMiko says:
That's so cool! But a lot of these are worth so much. It looks like you like all the music I like. :-) GO FRAMPTON! +1 rating. (added to favorites)
Apr 20, 2008. 1:00 PMGypsyman says:
do you know how much some people would pay for a few of those records?
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:bonzo363
