Hanging a Monitor on a Wall Revisited
23,812
28
14
Published
Introduction: Hanging a Monitor on a Wall Revisited
I was inspired by this instructable: https://www.instructables.com/id/Hanging_a_Monitor_from_a_Wall/ but when visiting the hardware store for the parts I found something better and I wanted to share.
As with the linked instructable, I was looking for a way to hang my side monitors on the wall to free up some desk space underneath. I already have 2 22" monitors mounted using VESA swivel arm mounts but they cost me over $80 for the pair, even when ordering online. Since the 2 monitors I wanted to mount directly on the wall were smaller (and less expensive) 17", I thought something homemade would do the trick.
Step 1: The Tools/Materials
The main item that makes this different from the instructable I read earlier is the picture hanging system I found. This was at a True Value hardware store, I'm sure other hardware stores would also carry similar systems.
Aside from the system, you will need something to fasten the mount to the wall. I didn't want to have to worry about finding a stud and hoping it was near where I wanted to put the monitor, so I grabbed these special screws for mounting things in drywall. They're rated at 50lbs each, and since my monitors are cheap I'm not worried about them falling (not that I think they would).
Lastly, you'll need bolts to attach your monitor to the picture hanging bracket, and screws to attach the bracket to the wall. The whole set up set me back about $14.
As far as tools go, the plastic mounting screws are self tapping, but I drilled pilot holes to be safe. A cordless drill does wonders here, and a vice helps for punching holes in the picture mounting kit.
Step 2: Prep the Monitor
Prepare your monitor next by removing the stand. I recommend putting the screws back in so you can put the stand back on later should you decide you need to.
Step 3: Modifying the Hardware
Now that we have everything ready, you need to modify the hardware to be able to use it. Line up the "picture" piece of the kit with the back of your monitor, and mark where the holes need to go. Technically you don't need to be exact here, but I would eyeball it and try to get close. Then punch the holes in it with your drill. I would use a vice to hold the piece in place, if you have it.
Once you have the holes drilled, go ahead and screw it on. I used washers for added support, but they probably aren't necessary.
Step 4: Mount Point
Next we need to figure out where to put the wall piece of the kit. To do this, I laid it on the monitor as it would be on the wall, and made a mark. Then I measured the distance from the top and side to determine where it goes.
Step 5: Wall Mount
Since I was putting this monitor next to another, I measured down the distance I measured from the top of the monitor, and then over from side the distance I measured from the side of the monitor. This will tell you where the corner of the bracket goes, so you can then put the bracket on the wall, tweak until it's level, then mark where the holes are.
Drill the holes, put in your mounting system, and screw the bracket to the wall.
Step 6: Finish Up
Now just set your monitor on the wall and you're set!
I really like how this worked out, the system is very forgiving horizontally, if you need to slide it over to the left or right you can very easily, and they also come off very easily as well. Hopefully this will help others looking for a cheap alternative to more expensive VESA mounts.
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    14 Comments
    I just followed this instructable successfully -- thank you Wint. I used the Ever Straight Hanging System ($3) which is similar to the product above, only made of plastic. I used the 5" hangers rated for 40 lbs and so far they are holding my 17" and 19" flat screens without a hitch. The screen naturally hangs slightly tilted down so I shimmed behind the bottom to make the screen parallel with the wall surface. Also, I used drywall anchors instead of the panel nails they include in the package.
    there's a true value here where I live, but everybody calls it bobs mart for some reason
    wow...
    i love you set up!!!
    what do you do for a living?? so many monitors!!!
     I'm a programmer by trade, I have 4 computers at my desk, a gaming PC, a Windows 2008 server, a Mac mini, and a Linux box :)
    I'm actually back down to 2 monitors, two 24" screens on adjustable arms, but the way this instructable works makes it easy to tear them down and put them back up with a minimum of work.
    lol i didn't notice before that you had psp's hangs on the wall lol good job same method?
    I would turn the 17" monitors on the sides 90 degrees so that the buttons on both monitors would be farthest out on the sides. That would give all the monitors about the same height. And isn't it annoying to have the frame line in the middle? Isn't that where your cross air will be if you play first person games and where your character will end up if you play third person games(like split in 2)? Maybe not all, but in many games. To fix that you could of course buy on more 22" inch monitor to have in the middle. But if you did you would probably end up with to many screens and would probably have to skip the 17:s. Or you could just adjust the picture, but then it wouldn't be symmetrical. But that's just what I think. Really nice setup. Jealous =P.
    I also see how you hang your PSP's on the wall. You can use THOSE as additional displays ALSO! See this.
    Ahh! Too many monitors!
    you can never have too many moniters
    Instead of for virtual desktops/workspaces in Linux, I could have four REAL desktops/workspaces.
    Nice monitor setup. WANT!
    Thanks :) I seem to be getting quite a collection of games.
