Hanging Candle Holder by Thinkenstein
Featured
Candles illuminate a room best from overhead.  To reduce the risk of fire and to protect the flame from wind I put the candle in a jar.  A wire handle holds the jar.  A heavier wire is bent to hold the candle.
The candle is lit outside of the jar and is then lowered into place.
Step 1: The Candle Holding Wire
One piece of fairly stiff wire is bent to hold the candle and suspend it from the lip of the jar.  I start bending at the end that holds the candle, and do the end that hooks on the jar last, to adjust the height of the candle off the bottom of the jar.
It is bent in such a way that three parallel sections of the wire dig channels into the candle when it is pressed in place.  That holds the candle firmly.
I bend the hook at top a little tight to grab the jar lip securely, instead of letting the candle dangle loosely.  The object is to hold the candle in the center of the jar and not let it flop against the jar wall.
londobali says: Jan 20, 2013. 5:10 AM
Lovely..
Thanks for sharing!
Wilmette says: Dec 4, 2012. 3:50 PM
Injustice did a redneck handle holder. Put sand in a Mason jar and stickthe candle in Yours is nicer
Ninzerbean says: Apr 17, 2012. 7:18 PM
These look so professional I could easily see them in a boutique-y type store. Now I know what I will be doing with all the old blue canning jars I have collected.
Thinkenstein (author) says: Apr 19, 2012. 7:41 AM
The colored jars should make great lights.
poofrabbit says: Apr 16, 2012. 7:16 PM
This is very cool, I'd love to see these glowing at night!
Thinkenstein (author) says: Apr 17, 2012. 11:14 AM
Got to make them first! Go for it!
Frish says: Apr 16, 2012. 8:22 PM
Looks like every earthquake kit ought to have wire.
And Jars! Not to mention candles...
Thinkenstein (author) says: Apr 17, 2012. 11:12 AM
Throw in a box of matches and I"ll take it!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
