Remove these ads by
Signing UpStep 1How it was before...
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
To put things straight, there is one tool : a Level !! Most of them have at least two bubbles, to check horizontality or verticality.
To be sure it is well-anchored, you must check if the cabinet you are trying to hang up is designed for. Kitchen Units are designed so screws through the back of the cabinet will effectively hold. Here, the back is a thin wood plate that would never hold anything. I asked technicians in Home Depot : Their advise was to use their EZ anchor stuff, plastic screws to anchor in the wall, in which you put your classical iron screws. This is the easiest way. Otherwise, if you want a very strong anchor, you might look for the stoods into the wall, and exploit them. As this is something I do not master at all, I wont post something like that.
I'll try to add my procedure on how I put the screws...
