loading
Step 1: Ingredients
Picture of Ingredients
For this Hack you will need.
1. Rotera candle lantern
2. Hemma hanging lamp base
3. Ikea size light bulbs (they come in a two pack)
4. In line lamp switch (I got this from the hardware store)
5. Small size wire nut 16 – 22 (also from the hardware store)
Also it is handy to have these tools at hand
Rotary grinding tool
Drill
Center punch
Hammer
Screwdriver
Wire cutters
Exacto knife
Now lets get to it!
Step 2: Separate the top of the lantern from the base
Picture of Separate the top of the lantern from the base
 To separate the top you need to grind away the ring on the inside that clamps the top onto the rim of the base.  This was the toughest thing since my rotary tool couldn’t reach the interior very well.  I only ground about half of the ring off and I could twist them apart.
Step 3: Grind it open
Picture of Grind it open
 The next step is to grind the openings large enough to fit the lamp socket through.  I noticed that the entire unpainted portion seemed to be the same size as the socket, so I ground it all away.  On the top of the lantern I used the center punch to set a dent in the middle of the top.  I used the drill to start the hole then my grinder to remove the rest of flat portion on the top.
Step 4: Wiring
Picture of Wiring
 Now that all the grinding is done it is time to wire it all up.  Since I am using the lantern as a reading light hanging next to the bed, I cut the cord about eight inches from the socket to place the switch within arms reach.  I used the exacto to strip the outer black casing from the two wires inside, to be sure not to cut the smaller insulation around the wires inside I only scored the casing, and pulled it apart with needle nosed pliers.   Then strip the ends of the black and white wires so they are ready for the switch.  At this point thread the top of the lantern over the socket and make sure it fits down to the keeper ring and the wire comes cleanly out the top.  Inside the switch wire the black wires to the screw leads that connect to the switch.  Since we cut the cord we need to re connect the neutral wire back together.  I found that the grey 22- 16 Wire Guard brand wire nuts fit inside the switch and make a clean look.  Then just screw the switch back together and the wiring is complete.
(I know that when attaching a wire it should always wrap clockwise around the screw,  I fixed the wire after I took the picture.)
Step 5: All together now
Picture of All together now
 Slide the socket into the lantern base and tighten the keeper ring from the inside, install your light inside the glass, close the door, plug it in, and turn out all the lights in the room.  Turn on your new light and marvel at your finished Ikea hack.
Great work and thanks for visiting.
tenebres3 years ago
I am trying to make this, but I am finding it hard to because some of the information isn't specific enough for me. I went to home depot to get a rotary grinding tool, and they had a selection of 4 so I need to know the size of the one you used, secondly what was the size of the drill bit you used to drill through the top, and lastly ikea has a million light bulbs so I have no idea what the exact type is that you bought. This information would be very helpful, thanks!
play to learn!
I love IKEA hacks! In general the whole flat pack assembly idea is more than inspiring. Same here! Lovely lantern assembly hack! cheers!
i bought those from d dubai ikea store..nw i knw hw 2 use them indoors safely.
Sermos4 years ago
Looks awesome!
