Hanging Light Bulb Vases
Introduction: Hanging Light Bulb Vases
What You Need: 5 light bulbs, screw driver, gardening wire, knife, hot glue gun, and real or fake flowers.
Step 1: Opening the Light Bulb
For this step I took the knife, poked a hole through the base of the light bulb and cut around until the top part was off.
Step 2: Emptying the Light Bulb
Now that the top part is off, get your screw driver and break through the glass that was under the base. Once you do this remove the filament, wires and stem.
Step 3: Hanging the Light Bulb
To get the wire through the light bulb poke a small hole on the base with your knife and use the wire to make a knot. Evenly space out each bulb and continue to tie each bulb until you don't have any left.
Step 4: Flowers
Cut the flowers at a length that will fit your light bulb just right. After this, take the combinations of flowers you want in each bulb and use your hot glue gun to glue the stems so they stay the way you positioned them.
Step 5: Placing the Flowers
If you are using fake flowers place the flowers in each light bulb. If you are using real flowers fill the bulb with water and then place the flowers. If you are using fake flowers but want to create the illusion that they are real you can also add water.
Step 6: Hang Your Light Bulb Vases
Now that you are done the last thing to do is to find a place where you think it'd make a pretty decoration. If you don't know where, you can always take two nails and place it somewhere plain and boring to jazz it up.
Step 7: Have Fun Making Your Own Hanging Light Bulb Vases!
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    I must admit, I did not expect to like this. But I was REALLY IMPRESSED!!! WELL DONE! I do have one question though . . . I don't suppose you could give me/us a ruff idea of the distance you allowed between each bulb in the final product? I realize you could have as much or as little space as you wanted but, personally, I liked your finished piece so much I'd like the chance to see that distance before I go adding or subtracting the distance on my own. You really did a nice job on the tutorial as well! Thank you for sharing it with us all!
    Very cool! I like the idea of using old light bulbs for this. Pretty cool!
