3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hanging Shelves Made From Longboards
This is my first instructable, so bear with me. Any suggestions to improve it are very welcome.
I recently decided to get rid of my old DVD/Media shelves as I was tired of them and they took up too much floor space. After pondering a bit about a solution, I found this instructable:
www.instructables.com/id/Industrial-looking-hanging-media-shelves/
Inspired by that design and also by not wanting to buy the tools to crimp cable ferrules, I came up with the idea of using shaft collars instead of crimp on cable ferrules. I then went even further and decided to incorporate my favorite activity, longboarding, by using longboards for the shelves. Read on to see how it all came together!
Step 1Materials and Tools
First off, a materials list. I bought the cable and shaft collars from www.mcmaster.com. Part numbers are listed at the beginning of each item.
*Part # 3458T979 - 1/8" Diameter Stainless Steel Cable
*Part # 9414T3 - 1/8" ID Shaft Collar
*Wood For Shelves - I used blem longboards, you can use plywood, pine boards, etc..
*Various Screws
*Wood Stain (I used black leather dye and Wipe-on Poly)
Now the tools list. It doesn't take much, but a few more specialty items are needed and are noted below.
*Pencil or Pen
*Tape Measure and/or Ruler
*Drill and/or Drill Press
*3/8" Forstner Drill Bit (Needed to recess holes for shaft collars)
*1/16" Allen wrench/driver (To tighten shaft collar set screws)
*Screwdriver
*Sander and/or Sand Paper
*Table Saw and/or Skill Saw (Only needed if you are making your shelves.)
*Bolt Cutters (Needed to cut the cable. Regular hand cutters won't cut it.)
*Level
*Stud Finder
18 comments
Jan 4, 2012. 1:19 PMao'barr says:
i want to make
Mar 11, 2010. 6:26 PMHoboWhisperer says:
You've gotta love McMaster.  They sell absolutely everything.  And they've had one of the best web interfaces in existence for the last 6 years at least.  It's almost as good as wandering through a Hardware store thinking "I need a thinggy that kinda looks like..."
Mar 12, 2010. 8:20 AMHoboWhisperer says:
Yeah, I just checked - they only send them to their current customers.  I'm surprised they don't give you the option to buy one!  That's the only product that they don't stock :)
Feb 26, 2010. 7:57 PMxavier_bustos says:
Excellent idea, congrats. I built something similar based on your instructable. Still have plenty of free place. Thanks.
Feb 20, 2010. 10:10 AMdugitup says:
 mountain bike brake cables might work nicely.  The head of the cable is turned 90 degrees so it wouldn't fit quite as perfectly in the recess, but nobody's going to see it.
Jan 28, 2010. 7:45 PMSCUBASTEVEAU says:
 Why not put trucks on with 2 screws and put the cable through the other holes and collar below the trucks? and use boards with artwork on the bottom, for a teenage bedroom. Cool idea though! Re your disclaimer about weight i was wondering if a blob of Epoxy below the collar would help, though it would make it difficult or even impossible to adjust after that.
Just some ideas, but love it
Jan 28, 2010. 4:04 PMbeahelf says:
 Hi I have used leftover laminate flooring for the same kind of treatment. Good instructable.
Jan 28, 2010. 7:39 AMabraxas1 says:
Wow, really nice looking shelves. great finished product.
it's a much nicer solution then crimping, but i'm a little worried those set screws won't loosen up someday. cable compresses and all.
it would be great if that little block of ply on top could be aluminum and if the cable wasn't cut there, but just looped though. then would hardly need the set screws at all. but need a little machining for the block to loop the cable through.
great idea, gonna do this in the back office. Thanks!
m
Jan 28, 2010. 11:24 AMkenbob says:
Excellent instructable - good directions, good photos, good results.  Lots of variations could be done on this theme.  And, you can vacuum under the shelves!
Jan 21, 2010. 1:26 PMZaphod Beeblebrox says:
AWSOME!!!! you work at the longboardstore!!! that is so cool! and awsome shelves too!!!!
Jan 21, 2010. 12:23 PMBiggieSOMD says:
You get to work at TheLongboardStore? You are a lucky person, I wanna try and make some of these out of my old broken boards. Would an old evo provide bookends for the shelves also
Also, you guys are my goto source for everything, just wanna thank you all for nothing but awesome service
Jan 21, 2010. 11:16 AM_mattb says:
Nice idea with the collars!  Adjustable..easy to attach..
No doubt one of the best sets of shelves on instructables.
Jan 21, 2010. 7:56 AMDoctor What says:
 Those look great!  Very modern look.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:NitroRustlerDriver
