Introduction: Halloween Skull Hanging Lamp
Picture of Halloween Skull Hanging Lamp
It's almost that time of the year, and in the spirit of truly terrifying (and affordably priced) props, here is my own DIY skull lamp. Use it to cast a little light onto those dark corners of your favorite haunted mansion!
Step 1: Get Inspired by the Totally Awesome Designer Edition...
Picture of Get Inspired by the Totally Awesome Designer Edition...
So, have you seen this pic floating around the net lately?Gorgeous, right? We have artist Alex Garnett to thank for them...but at almost $200 a pop and sold out on Etsy, they are waaayyy out of my reach.Luckily, it's almost Halloween (yay!) which means...skulls galore! I was downtown today with my friend Claire and stumbled across some cheapie plastic guys that are going to do the trick for me to help get me through until I make enough money to either buy the real thing, or figure out how to cast these suckers in something other than plastic. Stay tuned...I do want to try to cast one and then see if I can do a cold porcelain mold on that and see how that turns out...but that's later...for now, we'll just stick to the cheapie process!
Step 2: Your Materials List
Picture of Your Materials List
YOU WILL NEED: PLASTIC SKULL -- You can pick these up either at any Halloween store, Michael's during the Halloween Fall season, or online through Ebay all year long. My cost: $8.98 each (x4) = roughly $40 after taxes.
NOTE: I'm gonna STRONGLY suggest you do NOT use foam skulls. Sure, it's tempting. They're super cheap...easy to modify, and readily available. They're also NOT SAFE and when they get too hot, can emit toxic fumes. Remember, this is Halloween...we love scary...but not real scary.
LIGHTING KIT: I got a pre-fab kit from Lowe's called the Candelabra Base Switch Cord. It came with an 8 foot cord, light socket and rocker switch all pre-assembled. This version is really bare bones (ha, no pun intended) and the cheapest option I could find...you can get much fancier with swag kits, etc...but for this attempt, I went cheap. My cost: $5.98 (x4) = 23.92
LIGHT BULBS: We need light! Make sure if you get the Candelabra base listed above that you make sure you get the right size bulbs...both wattage size and base size. Candelabra bulbs have a much smaller base than regular bulbs and you don't want to buy the wrong ones and have to go back. I found a 4 pack of Soft White Energy Efficient bulbs on sale at Lowe's for $13.98. Score!
PENCIL: To trace around your light socket.
DRILL WITH 2 BITS: You'll need a small bit to drill your pilot holes and a second, larger bit to make your socket hole. I got lucky and had a circular bit in my kit from a door install I did a few years ago, but you can use any drill bit and I'll explain that trick later in step 4.
Step 3: Getting Started
Picture of Getting Started
Okay, now you've got your supplies...let's get started! The first thing I did was take the jaws off of all my skulls. It's a personal preference...you can leave them on or remove them...but I liked the look off. They were attached with a dot of glue on the inside that just popped off as soon as I unscrewed them. Super easy!Now that the jaw is gone, I no longer have a full skull...just the cranium. Save the jaws...I don't know what I'm doing with mine yet, but I'll figure something out.
(OPTIONAL): Luckily for me and this project, the bottom of the skulls was just a gaping hole so I didn't have to do any additional base removal to allow light to shine out...but if your cranium has a "bottom," now is the time to remove it. You'll want to not only do that to let out light but also heat as this is just a plastic skull and any light bulb is going to get warm (we'll talk about that more later)...
Step 4: Use Your Pencil!
Picture of Use Your Pencil!
Trace the socket of your light fixture at the point on your skull where you want to suspend it from. I chose the center of my skull rather than further back like in the original because of the way the opening on the bottom is positioned. At this point, it's totally up to you and where you want to put it.
Step 5: Drill, Drill, Drill...
Picture of Drill, Drill, Drill...
Drill a tiny pilot hole in the center of your marked circle. This will help make cutting your hole out much easier in the long run. Once you have your pilot hole drilled, switch to your larger drill bit. Like I said above, I got lucky and I had a hole bit from a door install earlier that just happened to be the absolutely perfect size for the skulls. If you don't have one, you can skip drilling your pilot hole and use your regular drill bit to drill circles along the line of your socket hole.
Drill them close together but not so close as to overlap and try to stay just INSIDE your circle...it's better to make the hole too small and enlarge it than too big. Measure twice...cut once. If you've done them close enough, you can either literally punch out the plastic with a little force, or use nippers or a small hand saw (or even an Exacto knife or blade if your skull material is softer...very carefully) to pop out the hole.
If you've made the hole the right size, the candelabra socket should fit perfectly in it. Just snap it in place using the side wings to secure it to the sides of your hole.
Step 6: Let There Be Light!
Picture of Let There Be Light!
Screw in your bulb. Make sure to check that the bulb is sitting in the center of the skull and not touching any sides. Traditional bulbs get very hot...and although the new energy efficient bulbs are a bit cooler...they still get pretty toasty ...and you don't want to melt anything or start any fires.
** Personal side bar ** Ideally I'd like to revisit this project after the holidays and see what I can do about switching out the setup I have now for ultra cool (both in temp and look) LEDs...but that's another day. For now, we'll stick with this. I am using 13W CFL bulbs in "soft white."
Flip the switch, step back and enjoy! That's all there is to it!
Step 7: Final Wrap Up
Picture of Final Wrap Up
I'm using these for a Halloween party I'm throwing this year (stay tuned...MANY more tutorials coming from that) and will be hanging them from the tree in the back yard to illuminate the common area. Each skull throws out a nice pool of light and spaced out, will be a great addition to the "atmosphere." I might either paint or wrap the white cords in black material to help hide them at night...the white isn't my idea of perfect, but was the only color available at Lowe's when I went today and I'm too impatient to order black or go to a different store...so for now, they're white...but no matter what...LOVE HOW THIS LOOKS!
TOTAL COST FOR MATERIALS: Each skull cost me roughly $20.
TOTAL TIME COMMITMENT: Less than 1 hour from start to finish doing all 4 skulls. (Honestly, writing this tutorial took more time than assembling the skulls.)
So there you have it. Skull pendant lamps for a fraction of the cost of the originals. You can personalize them any way you'd like...maybe some dripping blood? A new coat of paint? I might go back and darken the eyes so they really stand out, but for now...I'm happy with the results.
** Remember, these are made out of PLASTIC so please, be EXTREMELY careful and make sure to keep an eye on your light to ensure it's not melting/smoking. I would suggest going straight to LED lights if you can afford them and ABSOLUTELY if you insist on ignoring my warnings and use Styrofoam anyway.
And regardless of what type of skull you use...as this does involve heat emitting items (your light bulb), make sure to keep an eye on this once you plug it in...at least for the first few times just so you get a good idea what it does when it's been on for a bit. And please, please please please...do not leave this light on unattended...Halloween is meant to be scary...but not THAT scary!
glen.ryerson.1 made it! (author)2014-09-26
I made a larger one and kept the jaw on. The skull didn't have a hole in the bottom so I cut one out with a rotary tool and spiral cutting bit. I used an led bulb so it wouldn't build up heat. The skull was available at target for $10.
I love it! It looks incredible and I'm really digging the chain you have running along the cord. Very very cool and so excited...you're the first person to make any of my Instructables! Woohoo!!!
Thanks. You got me inspired. I also really like the tablecloth you did, I was thinking it would make a great material for a leather face costume. The latex veins are a cool idea for zombie make up as well. You could color them green or with glow in the dark paint and imply the virus is flowing through the blood system.
Izzy23g (author)2014-10-05
this is so rad... color lights would make this even radder lol
ThisIsMyNameOK (author)2014-09-21
"Hey, I bet I could make some of these out of cold porcelain.....
Oh. Well, I guess I'm not the only one."
These look really nice. Good job. :-)
So, I took another one of my skulls and made a mold of it using latex and plaster cloth and I want to give this a try with cold porcelain like I mentioned in the actual Instructable. I found a recipe online for cold porcelain and figured I'd run it past you as you've used this material before and I know there are variations on the recipe: http://www.figurines-sculpture.com/cold-porcelain-...
If you have another recipe you prefer and have used before, let me know as this is new territory for me and I'm not sure how it'll turn out yet and would love your expert opinion!
Can't wait to try it, but it's probably gonna have to wait until after Halloween...too many other projects going on right now!
Correction: I used white vinegar as my preservative, instead of lemon juice or citric acid. And I have some that is 6 months old and is still perfectly fine.
Here is another great site with info about CP. Check out the tutorials by Marisol Romero too. I used her method for cooking my CP, but not her recipe.
http://coldporcelaintutorials.blogspot.ca
Thank you, I'm flattered, but I'm no expert. I only started using cold porcelain about a year ago, and my first few attempts were complete disasters.
To explain my earlier comment, I was just amused by the fact that as I was reading your Instructable, I was thinking about making one out of cold porcelain, maybe 2 seconds before reading that you were planning to do exactly that.
I love Sangeeta. Her work is so awesome. Way better than anything I could ever do. And her recipe was the first one I tried. I watched the video twice, meticulously copied out the ingredients, did everything exactly like she did..... And ended up with a chunk of rubber that was no good for anything except maybe a doorstop. I think the problem was the microwave. Maybe mine is a higher power than hers or something? Anyway, to make a long story short, it is a good recipe and I used the exact same ingredients for the one really good batch I made. The only difference is I cooked it on the stove. I may have used slightly different measurements, I can't remember. I'll have to try to dig up the notebook I wrote it in
The quality of the ingredients matters, especially the glue. Use a really strong glue, such as carpenters glue or tacky glue. Definitely do not use "school glue". And do cook it. Some recipes will tell you that you don't need to, and it's true, you don't, but cooking it will give you a much stronger clay that will hold its shape better.
If you have any more questions or just want to chat about it, let me know. ?
Kumar.sajan.793 (author)2014-09-04
http://facebookjokesindia.blogspot.in/ nice
Mo0k (author)2014-09-03
Scary but cute.
About This Instructable
9,731views
220favorites
License:
Bio: Just a writer living in Hollywood making ends meet by doing costume design and props on the side!
More by Tye Rannosaurus:Monkey Brain Forbidden Fruits Edible Tide PodsBrainwashed - Homemade Fizzing Bath BombPumpkin and Applesauce Puppycake (dog friendly)
Add instructable to:
