This new design has separate handles that hook on to either the top or the bottom of the jar. The wire for the handles is a little thicker, and since there is no flexing of the material I expect to never have problems with them breaking.
This new design also has a little water catch attached to the jar mouth, to catch drainage drips. The jars are big pickle jars, and the water catch is a nut container lid.
I also use the jars, in the mouth-up position for making rejuvelac. http://en.wikipedia.org/wiki/Rejuvelac
Remove these ads by
Signing UpStep 1Bending the Wire Cradle
I used two pieces of galvanized tie wire 7 ft. long to make the cradle that holds the jar.
Right under the mouth of the jar, there is a neck area which provides a secure place to tie onto with the wire. The jar can't escape once it is held around the neck.
Find the midpoint of the first wire wrap it around the neck of the jar and twist the wire ends around each other several times. Repeat with the other wire, putting the twists at the opposite side of the jar.
Take one wire from each pair at either side and join them by twisting. Take the remaining two wires and twist them together at the opposite side of the jar.
Repeat that process again further down the jar.
Turn the jar upside-down. Take the paired wires from both sides and join them together over the bottom of the jar as shown. Pull them tight as you twist and pinch them. Cut off the excess wire.
The jar is now securely held by the wire cradle.
The jar handle, which will be made next, has two hooks that can grab onto the wire cradle either at the top, or at the bottom of the jar.
comment
Add Comment
Add Comment
