3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hanging Toilet Paper -- rebar and PVC
One shouldn't have to be a contortionist to reach the toilet paper.
The toilet in this small bathroom was not located for convenience.  To the left there no wall to mount a roll to, only a rubbery shower curtain.   To the right of the toilet there will probably be another curtain.
The solution I came up with was to hang the roll from the pipes that the curtains slide on.  Rebar makes good hook material.  I used one piece of rebar to make the hook and the rest of the holder body, except for the PVC pipe that the toilet paper roll turns on.
Step 1Bend the Rebar
Bend the Rebar
I bent the rebar with just a big pair of pliers.   The PVC spindle has holes drilled in it so that two parallel areas of the rebar will impale it and hold it in place.  By sliding the spindle up the parallel sections, it eventually slides off one end, which allows the replacement of toilet paper rolls.
The central PVC "spindle" doesn't spin, but the friction against the cardboard core of the roll is not great, and the roll does turn fairly easily.
One section of the rebar is bent so that it protrudes in back, beyond the radius measurement of the roll.  That section rests against the wall in back of the roll, or against the curtain, and holds the paper away from the wall or curtain.
1 comment
Jun 4, 2010. 11:50 AMJayefuu says:
Yet another quality PVC build Thinkenstein! Awesome. :D
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
341
Author:Thinkenstein
I'm a refugee from Los Angeles, living in backwoods Puerto Rico for about 35 years now and loving it. I built my own home from discarded nylon fishnet and cement.
