Step 4Fitting the fixture
iImage Information
This step is pretty self explanatory. Unscrew the ring around the bit that holds the bulb (technical term, I know) and fit the colander on it. Screw the ring on as tight as it will go, and hold the whole thing up by the cord to check that the lamp hangs straight. If it doesn't, make sure it is not snagged on a thread. If it doesn't, there will probably be some wiggle room in the hole, and you will be able to straighten it by loosening the ring and repositioning it slightly.
