Happy Hack Light Switch
87
Posted
Introduction: Happy Hack Light Switch
For the last 2 weeks we have worked on a school project called "Happy hacking". With this project we tried to make a "Happy hack" for a public space. Well, what is a "Happy hack"? In our case we needed to make something positive based on a frustration. The use of Arduino was required for this project. The "Happy hack" we decided to make was an installation to remotely flip the light switch.
Step 1: Materials:
1x Arduino Uno
1x Breadboard
2x servo
1x infrared sensor
11x wire
1x infrared sender (tv remove)
tape
Step 2: How to Connect:
Put an Arduino infrared receiver into the breadboard; assuming the front side of the receiver is the side with the sphere on it:
  • Connect one wire from the most left ‘leg’ to the Arduino uno port ‘6’.
  • Connect one wire from the middle ‘leg’ to the ‘-’ row in the breadboard.
  • Connect one wire from the most right ‘leg’ to the ‘+’ row in the breadboard.
Make sure a wire is between the ‘-’ row in the breadboard and a ‘ground’ port on the Arduino uno and make sure a wire is between the ‘+’ row in the breadboard and the ‘5V’ port on the Arduino uno.
Now connect the 2 servos,
  • Both with a wire from the darkest wire on the servo to the ‘-’ row on the breadboard.
  • Both with a wire from the middle wire on the servo to the ‘+’ row on the breadboard.
Now, for one of the servos connect the remaining servo wire to the Arduino uno port ‘9’ and connect the other servo to the Arduino uno port ‘10’.
Step 3: Code:
#include<IRremote.h> //
#include<IRremoteInt.h> //
#include<Servo.h> //
IRrecv irrecv(6);
decode_results results;
Servo theServo1;
Servo theServo2;
bool lightOn = false;
bool disco = false;
void setup(){
theServo1.attach(10);
theServo2.attach(9);
pinMode(6,INPUT);
Serial.begin(9600);
irrecv.enableIRIn(); // Start the receiver
irrecv.blink13(true);
void loop(){
if (irrecv.decode(&results)) {
Serial.println(results.value); // You get a different result for every button. So check in the serial monitor what your buttons value is.
if (results.value == 3772793023){ // This is our power button result (3772793023). This is probably different with your remote.
lightOn = !lightOn;
if(lightOn){
theServo1.write(65);
theServo2.write(15);
if(!lightOn){
theServo1.write(95);
theServo2.write(95);
delay(1000);
if (results.value == 3772839943){ // This is our info button result (37728).
disco = !disco;
delay(1000);
irrecv.resume(); // Receive the next value
if(disco){
lightOn = !lightOn;
if(lightOn){
if(!lightOn){
theServo2.write(90);
delay(2000);
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    • Space Challenge
      Space Challenge
