First, if you've got a wood shop and tools, then you're golden, I don't so I drove to my parent's house to use theirs, plus, they have a built in baby sitter for my 1 year old, so that's a bonus.
ETA after trial and error I found that lining the holes is essential and keeps the bees happy and, well alive!
Remove these ads by
Signing UpStep 1Things to swipe
Babysitter (if applicable)
Piece of dry, untreated wood, (I used a log intended for a fireplace)
Chop saw or chainsaw to cut wood
two pieces of flat wood for the roof
drill press or hand drill
Screws
nail gun
water sealer
Dremel tool
bee cocoons
Sun
Danica's design using lenths of raw logs is not such a bad one actually and could be designed into a pretty funky Bee house. (I've already got some ideas). One thing I've read about this type of design is how difficult cleaning and keeping your little ones safe over the winter is. As Vlatro says, yes cutting a paper bag and lining the holes is a good idea and much cheaper than buying paper tubes. But I read that using Bakers parchment paper is even better for keeping everything dry and removing your Bee cocoons to save for the next year. This particular blogspot has some excellent information on cleaning and preserving cocoons. http://frogpondphotography.blogspot.com/2007/10/mason-bees.html
I have my own ideas for Mason Bee houses and plan to start production this winter and will post the process. Cheers.
Althought a drilled block of wood/log is fun and simple, it winds up becoming a mason bee cemetary after a few years due to pest build up.
For those who disagree, mark across each filled hole and see how many holes actually open up in the next season.
What's much better is to be able to harvest the cocoons in the fall. (October).
Our website, www.crownbees.com, has step by step instructions with pictures. Cedar has natural pesticide built into it... it's not a good thing to use.
We also have extensive "how to's", Question & Answers, as well as science paper summaries that we feel are vital to commercial mason bee pollinators.
Honey bees are vital to pollination. Native insects may become more necessary in the near future if the challenge continues.
Dave
This will be our first year housing mason bees and my 10-year-old son is beside himself with excitement! :)
I don't work for them, just to be clear :) I did a lot of research on mason bees and in all that I sorted through, their information was very clear and Gord Hutchings has contributed quite a bit to the discussion of bee housing on Gardenweb.
Mason bee systems - different styles, good and bad
Thank you
PaleoDan
If you're bent on waterproofing, you might be able to do so with paraffin or beeswax. Melt some and place the cut ends of the log in the liquid. Should wick it right up.
I've got some scrap ply that's been outside for a while and it looks terrible.
Also, I know honeybees tend to avoid hives made from ply (something to do with the adhesives I believe) - whether or not this would mean masons would stay away I don't know but it might.
I'd suggest using solid wood of some kind.
I'll be making some of these to go on my allotment reasonably soon. Not quite 15 acres (it's just over 1100 square feet of land rented from the city to grow food - that's 0.025 acres) but I'm putting up some habitat/housing for bugs anyway.
- How thick is the slice of the log?
- Did you drill the holes all the way though? If not, how deep do you recommend?
- Any recommendations of where to get the bee cocoons?
Great idea. I have been looking at these ones made of bamboo and thought they seemed easy enough to make something suitable for less.
Great stuff! :)
In most parts of the norther hemisphere, mason bees of one variety or another are common, so there should be little need to buy the bees. However, there are certain species available for purchase online, through garden catalog, or a garden supply stores. You should select a type of bee suitable to the plants you want them to pollinate. The bees that work well for apple orchards often emerge too late to pollinate cherries, and go dormant before the can pollinate winter flowers. So wild bees from your area will typically be hardy and active earlier and last longer, but specific species may be better suited for your needs, so do some research with regard to which species are available in your area.
Attracting bees to the nest requires a few other things. Make sure they have an ample supply of mud (for mason bees) and tender, non-oily leaves (leaf-cuter bees). They will also need food at times when your fruit trees are not flowering, so a variety of flowers blooming all season long (March-November) will make sure they don't wander off or starve. Honeysuckle and English lavender are a favorite for nearly all bees, hardy in most regions of the US, and keep their flowers for a long time. Putting these plants just beyond the nest will ensure they move in quickly.
Never use pressure-treated wood when constructing a bee house, and avoid using copper-sulfate on trees, as it will kill the bee's larva.
Cleaning the nests is also very important. There are a variety of mites and parasitic nematodes that prey on bee larva. After the female bees emerge (1-2 weeks after the first males come out), remove any debris from the holes and flush out with a light bleach solution. Hole liners make this easy. Just cut up a paper bag, and roll it in to tube that are just a bit longer than the hole, and insert them. At the end of the season, you can simply discard the empty liners and replace them, effectively discarding any parasites at the same time.
Ideally, you want around 500 bees per acre for fruit orchards. 1 hole 5-6" deep will house about 5 bees, usually 3-4 males, and 1-2 females. One female bee will lay about 20 eggs per season, filling about 4 holes. So 100 - 200 holes per acre will be ideal, but you can always use more, the excess will wander off and colonize neighboring areas.
Tip: If you have blonde or red hair, these bees will hover around your head for a while, you look like a big flower to them. Fragrant hair spray or conditioner will also attract them. They won't hurt you, but wear a hat to keep them from buzzing around your head. You learn to ignore it after a while, but it's unnerving to some people when a bee lands in you ear.
@kNexFreek:
Just an FYI, mason bees almost never sting. These nests won't attract honey bees or the Africanized hybrids. Don't be scared of something 1/10millionth of your size, I'm pretty sure you'll win in a fight with them.
Bees are in serious trouble. Great post, thanks.
glad someone cares about bees around here:p
