Haptic Feedback device for the Visually Impaired [Project HALO] by polymythic
Contest WinnerFeatured
Step 6: Creating the Software
Being a software engineer, I spent a lot of my time on the software aspect of this project. My source code is available. I used Caleb Zulawski's Ping Library (http://www.arduino.cc/playground/Code/Ping). I did make one modification, however. This library uses a default timeout of the pulseIn() function of 1 second. This was causing large delays in the execution of the program so I reduced this timeout to 500ms. Things execute far faster now. I will not go into the details of the program, because not all user of Instructables are code-jockeys, but here are the main points:
Source Code (Arduino Sketch and modified Ping library) are at  http://polymythic.com/HALO_SourceCode_v8.zip
The flow of the main program loop() is:
- Fire sensor,
- Check to see if any of the motors are supposed to turn on or off based on previous range finding
- Fire next sensor.. Repeat
Other Things to Note As You Look At The Code:
There are 4 "intensities" of motor pulsing to give the person a better sense of the range, and these vary by the foot (up to 4 feet)
This is based on an state-machine model, but one of the Arduino threading libraries could be used to handle this independently.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
