3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hard Drive After Life
So your aging hard drive can't hold its data any longer and you replaced it with a new one. Instead of letting it die by the hands of the recycling undertaker, you force it into a new life as a musical noise maker. A dying hard drive makes all kinds of grunts and groans as it starts up. The sounds it makes can be musical and percussive.
This project uses a homemade PIC midi interface to allow sequencer software (Anvil Studio free) to turn on and off eight hard drives. Midi signals are serially transmitted by the sequencer software as sets of 3 bytes at 31,250 baud. A PIC 16F877 has been programmed to receive these bytes to turn on and off solid state relays. Each hard drive needs 5 volts and 12 volts to run. Two SSRs are used to turn on and off the hard drive. I tried leaving on just the 12 volts, then switch on 5v to start the drive up. This worked well for awhile until one smoked up. So I use two SSRs to switch on both 5 volts and 12 volts at the same time. A modified PC power supply is used to supply power.  A guitar tuner pickup and computer soundcard amplifies the sounds, making the point that something went horribly wrong with those drives.
Step 1The Power Supply
The Power Supply
You probably upgraded you computer in the past with a larger power supply and its just sitting in your garage getting dusty.  You can use that power supply (if its still working) to power this project. Start by locating the +5/+12 connectors that would normally connect to the hard drive.  Cut off the connectors and run the wires to a terminal block to make wiring easier. You can get some new connectors at a place like Fry's Electronics to wire up the drives. Black is common (the negative connection), red is +5 and yellow is +12. Below I added a second set of connectors (toward the left) so I can detach the power supply from the project. You will also need a minimum load through the power supply to get it to turn on.  I used a 30 ohm/20w and 50 ohm/20w power resistors across the 12 volt output and a 10 ohm/10w across the 5 volt output. A 12v and 6v auto tail light bulb will also work as a load
25 comments
Dec 18, 2011. 4:02 PMbuilding_boy says:
That is cool! love the concept!
Nov 7, 2011. 11:16 AMspaceman874 says:
thats quite awesome i say
Aug 25, 2011. 9:41 AMjakethegreat98 says:
You could make a real cool sampler with one of these. Or maybe just with hard drive sounds in general
May 5, 2011. 5:41 PMbishopdante says:
sounds like stockhausen or schaeffer
Mar 31, 2010. 5:52 AMSyko Pyro says:
Be super hyper mega careful with this... One speck of dust (and I mean just one) and when the drive spins up, the entire platter will literally explode with similar effects to a grenade, shrapnel wise. Just warning, we made one explode in our AIT class by doing this. ;P
Apr 9, 2011. 11:44 AMTheDutchOwner says:
That depends on the drive. If you use a Hitachi/IBM Laptop drive that could happen because those are glass platters. This doesn't happen to non-glass ones.
Dec 12, 2010. 10:45 PMkool1zero says:
I want diagrams of that hard drive rack. add some clear plastic on it and it looks like a perfect raid enclosure to me. maybe mount some fans on it ad drill some ventilation holes.... sounds quite plausible
Mar 14, 2010. 11:46 AMrusky says:
Nice job! Reminds me of an Amiga demo that made music by manipulating the stepper motor on the R/W head of a floppy (or 20MB HDD if you were mad enough to run it on your A590!)
Apr 5, 2010. 1:37 PMTreknology says:
The Osbourne portable (sewing machine style) used variable speed floppy drives, as the head moved toward the outside, the RPM was reduced to keep a constant linear speed for the data writing--there was a challenge to get someone to use this variable speed effect to play a tune on one or both of the drives, but I never heard of a result.
Mar 18, 2010. 1:39 AMalbylovesscience says:
  this is a really good green project. i find the sound of HDD's to be ambient
Mar 6, 2010. 2:30 AMPlasmana says:
I would never thought of using dead(ish) noisy harddrives as musical instruments, amazing idea!
The only problem is where can I get my hands on the drives? They are so hard to get as people are worried about the data left on the drives... :(
Mar 6, 2010. 8:58 AMPlasmana says:
I did when to a few computer shops and asked for HDD's, no matter how much they want to give me the HHD's to help me with my projects, but they can't. Because they said they had already register HDD's to the recycling logbooks, once it is done, it cannot be undone and the computer stuff must be given to the recycling guys.
Instead, they gave me an old broken PC lappy and a unwanted 250W PSU which is not registered! :D
They also said it is illegal to give their damaged stuff away. The Health and Safety law really, really do my head in!!
Mar 4, 2010. 8:15 PMBlackDidThis says:
You have GOT to be joking!!!
I can not believe the amount of dedication you have set to realize a wacko idea that came to your mind "I do not know how" :)
But it's just so cool!
Sadly for some reason I am incapable of opening/downloading the link for the recording. Is the address correct?
Mar 5, 2010. 1:05 AMBlackDidThis says:
Oh no... :)
I may have sent the message across in the wrong manner. Guess it's my way of showing my love :p
I am totaly for your doing... and it is just so amazing to have come up to such a conclusion AND result!
I mean making those hard drives "Sing for me Baby!" is way off the roof in being creative.
I recall he had quoted something more like "Does a baby have any?" when asked "what use does this have?"... Though  I may have read a version lost in translation... yes have heard such a story.
Sooo where's your baby gonna grow into?
Mar 4, 2010. 12:11 PMjdubbullyoo says:
Can you upload a sample of some of your audio for us?
Mar 4, 2010. 10:59 AMBeta_Orionis says:
This is an impressive Glitch instrument. Great job!
Mar 1, 2010. 8:10 PMxSphinx says:
I don't understand the point of this, it didn't sound like anything to me.
Mar 4, 2010. 7:01 AMAzayles says:
I love the idea of the tree with a harddrive at each branch, that'd look SOO good, very artistic! The sound of these brings back so many memories xD
Mar 1, 2010. 4:50 PMplokko says:
a 7.1 hard disk surround system was way better!
Feb 27, 2010. 5:04 AMluvit says:
 this may sound almost as goos as a 1984 casio keyboard
Feb 26, 2010. 10:32 PMthe_burrito_master says:
Wow you've been through a lot of hard drives. 0_0
The project is awesome I cant believe you were able to accomplish that.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
68
Author:botronics
I like to tinker and experiment with electronics, robotics, programming, and photography
