3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hard Drive Fridge Magnet
This is a fun and easy way to make use of any old hard drives you have laying around.
Tools you'll need:
- A Medium sized flat head screwdriver
- A Small Phillips head screwdriver
- An Interchangeable bit screwdriver with Torx bits from sizes T10 to T5 (which sizes you'll use depends on the drive)
- Scissors
- Strong glue (something like Goop or super glue is fine, but nothing weak like white glue)
- A table vice and a pair of pliers, or two vice grips.
Step 1Taking Apart the Hard Drive
In this step you'll be taking off the hard drive lid, exposing the important parts inside.
This step will require the use of your small Phillips head screw driver, and a few sizes of your Torx bit heads.
This step is pretty self explanatory. Simply remove all the Torx screws and regular screws you come across until you're able to open the lid of the drive. The lid is sometimes a little hard to remove due to the foam insulating the seal. Take the flat head screwdriver and pry it open from the side. If taking off the lid does not require that you dismantle the circuit board on the bottom, do so anyway, because sometimes the parts inside wont come out without taking off some screws from underneath.
The end result should leave you with an exposed hard drive.
(if you've begun on this step and donno what tools you'll need, see the intro for a list)
17 comments
Apr 4, 2010. 8:02 PMmr.incredible says:
 Oops, I forgot. A lot of times. Forcing the magnet off the plate will bubble up the chrome coating or peel it off in spots. I found that soaking them first in a closed container of acetone (metal or glass) over night you can separate them much easier.
A couple of warnings...
-Don't let young kids play with them. If they swallow them they can get hung up in their intestines.
-There is suppose to be something harmful about the raw magnetic material also. I don't remember what. And I'm too lazy to look it up again. :o)
Apr 4, 2010. 7:53 PMmr.incredible says:
I find this is a much quicker way to destroy a hard drive for a customer. I use to run a drive wipe utility but that usually takes about 10 hrs to run. I love the magnets. I use them for everything. There are a couple more small neo magnets in some of them. There is usually a tiny magnet in the park mechanism.
I super-glue a slice of inner tube to one side of the magnet and trim it. Then I use your household goop glue to glue it to the dash of my truck. That glue is almost permanent. It can be removed if you want with out damage to the dash. With a small metal strip blued and glued to the back of my mobile phone I can almost throw my phone at it and it will catch and stay. No problems with road bumps either. (maybe I should make my first instructible with this topic)
May 24, 2007. 7:32 AMiPodTouchMaster08 says:
I wish a old hard drive ;(
Jul 27, 2009. 1:28 PMsanty22 says:
granted.
Jul 17, 2008. 7:17 AMPaul the Mole says:
Don't worry a new one works just as good :p
Sep 11, 2008. 8:21 AMiPodTouchMaster08 says:
I dont have any new ones :(
Mar 20, 2009. 3:21 AMjames.mcglashan says:
u can buy 1 on ebay realy cheep
Sep 3, 2008. 10:55 AMEdgar says:
Thanks! :D
Just peeled away 6 of' em, and I'll use 4 on this:
Bedini motor
Sep 3, 2008. 10:56 AMEdgar says:
Not my video, I'm trying to build me one of these.
Aug 31, 2008. 6:53 AMcompletegeek says:
Pretty cool instructable. I've been wanting to harvest the magnets from some old drives I have around, but I like the ornamental fridge magnet idea better. Good job!
Jun 6, 2007. 11:58 AMtoogood says:
man thats wird, thats how i harvested my magnets!!
May 7, 2007. 4:51 PMlemonie says:
I don't see your magenets on a fridge, but I like the pictures more. L
May 31, 2007. 2:04 PMlemonie says:
Oh yes, very nice! L
May 7, 2007. 2:24 PMWolfRune says:
Ah, excellent - another use for the ancient SCSI drives sitting in my basement. Mwaa haa haa!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Everfalling
wannabe sculpture
