Step 6Completeing the Fridge Magnet
You'll need your scissors and your strong glue again.
Take your scissors and cut away the electrical strip holding the small circuit board to the Read/Write arm. Be sure to cut it as close to the arm as possible. Do not rip off, because the strip is attached to the wires in the electromagnetic coil, and the coil will get unraveled a bit and look messy.
Take the arm and apply a nice glob of glue between the individual arms right where the arms meed the pivot. Then carefully place the arm onto the platter, making sure the Read/Write heads of the arm go between the platters like they usually would. Then just move the arm inward until the arm and the platters are joined together by the glue. you might wanna press down on the arm on top of the platter to create a stronger bond.
Add Comment
