Introduction: Hard Drive NeoPixel 3D Printed Clock
Picture of Hard Drive NeoPixel 3D Printed Clock
The hard drive clock will display
the time via the NeoPixels that are located on the hard drive platter area. This project is designed around utilizing a discarded notebook 2.5” hard drive.
The hard drive is mounted to a 3D printed enclosure. The hard drive clock utilizes (1) Adafruit Metro Mini 328 Arduino compatible controller, (1) ChronoDot - Ultra-precise Real Time Clock, (1) NeoPixel Ring - 12 x WS2812 5050 RGB LED with Integrated Drivers, (1) NeoPixel Ring - 24 x WS2812 5050 RGB LED with Integrated Drivers and (2) Momentary (on)-off-(on) SPDT Up-Down Rocker Switches. A complete parts list along is provided at the end of this “Instructable”.
The .stl files for printing the clock parts, Arduino code and wiring diagram are located here. The clock was printed on a Lulzbot mini with HIPS filament.
Step 1: Components - Arduino Based Adafruit Metro Mini 328 Controller
Picture of Components - Arduino Based Adafruit Metro Mini 328 Controller
Step 2: Components - ChronoDot Real Time Clock
Picture of Components - ChronoDot Real Time Clock
Step 3: Components - NeoPixel 12 Ring
Picture of Components - NeoPixel 12 Ring
Step 4: Components - NeoPixel 24 Ring
Picture of Components - NeoPixel 24 Ring
Step 5: Components - Socket and Servo Cables
Picture of Components - Socket and Servo Cables
Step 6: Components - Power Supply
Picture of Components - Power Supply
Step 7: Components - Filament
Picture of Components - Filament
Step 8: Components - Wire
Picture of Components - Wire
Step 9: Components - Liquid Electrical Tape
Picture of Components - Liquid Electrical Tape
Step 10: Components - Lacquer
Picture of Components - Lacquer
Step 11: Components - Mounting Screws
Picture of Components - Mounting Screws
Step 12: Components - Bumpers
Picture of Components - Bumpers
Step 13: 3D Printing - Clock_Base.stl
Picture of 3D Printing - Clock_Base.stl
Step 14: 3D Printing - Clock_Base.stl
Step 15: 3D Printing - Clock_Cover.stl
Picture of 3D Printing - Clock_Cover.stl
Step 16: 3D Printing - Clock_Cover.stl
Step 17: 3D Printing - Assembly View Back
Picture of 3D Printing - Assembly View Back
Step 18: 3D Printing - Assembly View Front
Picture of 3D Printing - Assembly View Front
Step 19: Construction - Hard Drive
Picture of Construction - Hard Drive
Step 20: Construction - Hard Drive
Step 21: Construction - Mark NeoPixel Ring Drilling Points
Picture of Construction - Mark NeoPixel Ring Drilling Points
Step 22: Construction - Drill NeoPixel Wire Holes
Picture of Construction - Drill NeoPixel Wire Holes
Step 23: Construction - File Slot for the NeoPixel Wires
Picture of Construction - File Slot for the NeoPixel Wires
Step 24: Construction - Solder Wires to NeoPixels
Picture of Construction - Solder Wires to NeoPixels
Step 25: Construction - Test Fit NeoPixel Rings
Picture of Construction - Test Fit NeoPixel Rings
Step 26: Construction - Place Tape on NeoPixel Rings
Picture of Construction - Place Tape on NeoPixel Rings
Step 27: Construction - Apply Liquid Electrical Tape
Picture of Construction - Apply Liquid Electrical Tape
Step 28: Construction - Install NeoPixel Rings
Picture of Construction - Install NeoPixel Rings
Step 29: Construction - Install Circuit Board
Picture of Construction - Install Circuit Board
Step 30: Construction - Countersink Base Attachment Holes
Picture of Construction - Countersink Base Attachment Holes
Step 31: Construction - Sand Clock Base and Cover
Picture of Construction - Sand Clock Base and Cover
Step 32: Construction - Solder and Attach Time Set Switches
Picture of Construction - Solder and Attach Time Set Switches
Step 33: Construction - Solder and Attach Time Set Switches
Step 34: Construction - Attach Hard Drive to Cover
Picture of Construction - Attach Hard Drive to Cover
Step 35: Construction - Mount Components to Base
Picture of Construction - Mount Components to Base
Step 36: Construction - Attach Wires to ChronoDot and Metro Mini 328
Picture of Construction - Attach Wires to ChronoDot and Metro Mini 328
Step 37: Construction - Attach Base to Cover
Picture of Construction - Attach Base to Cover
Step 38: Construction - Apply Spray Lacquer to the Clock
Picture of Construction - Apply Spray Lacquer to the Clock
Step 39: Construction - Apply Spray Lacquer to the Clock
Step 40: Construction - Wiring Diagram
Picture of Construction - Wiring Diagram
Step 41: Construction - Attach Base / Bumpers
Picture of Construction - Attach Base / Bumpers
Step 42: Construction - Program Adafruit Metro Mini 328
Picture of Construction - Program Adafruit Metro Mini 328
Step 43: Construction - Make Power Connection
Picture of Construction - Make Power Connection
Step 44: Time Set Switches
Picture of Time Set Switches
Step 45: Time Displays
Picture of Time Displays
Step 46: Time Displays
Step 47: Time Displays
Step 48: Parts Listing
Picture of Parts Listing
bighurtx (author)2017-12-18
Sorry - I found it in the clock wiring pdf. Thanks - great job
Please Can you post the code in a pdf?
TerryT5 (author)2015-12-29
Really nice instructable. Well done!
gg2inc (author)TerryT52016-01-03
Thanks!
martianable (author)2015-12-21
Kudo's to you gg2inc ! this is a fantastically detailed Instructable !!!! It's exactly the kind of detail that can help those who are unsure of where and how to get the materials to do this kind of a job - wow ! I'm doing this one soon - Your patience and detail in this are noteworthy - good job & I'll send photos when I'm done ! thank you !
gg2inc (author)martianable2015-12-21
Thanks, I appreicaiate the feedback.
About This Instructable
4,860views
26favorites
License:
More by gg2inc:Stargate Inspired DHD CenterpieceHard Drive NeoPixel 3D Printed Clock3D Printed Back to the Future TIme Circuit Clock
Add instructable to:
