3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hard Drive Parts Generator and Theory Tester
This is a device built out of hard drive parts and a piece of wood that simulates the action of a windbelt. I built this because I think this way of producing energy could be used differently With this I can be anywhere and not need wind to power it while I think of a different way it can be used.
These are the final pics. The pictures I took weren't very good while I was building this but, it is built the same as the other generators of this type on instructables.com. One end is built on a scrap piece of wood. The hard drive parts were given to me by a really nice man of a local computer store near my home. I tried various different rubberband combinations to connect the two arms. I used three.
I also have a video of it posted of it working.
With just one magnet above and below the coil I am able to hold 2.0VAC for a few seconds strumming on the end of the other hard drive arm.
12 comments
May 2, 2010. 6:03 AMValduare says:
if your looking for a way to generate power from waves,
just stick a tube into the waves vertically. and funnel it down on top to your generator blades.
Sep 18, 2008. 12:58 AMwheatstone says:
One could use an old riding lawn mower gas gauge that reads e-f on top. it has a cork screw on the tank side that turns the gauge indicator (On top) from e-f. it has a cork for a float that slides up and down with the level of the gasoline inside the gas tank. For your water generator/ tide / up dn motion...etc. get the drift...Robot humor
Jul 20, 2009. 8:06 PMwheatstone says:
The cork could hold the magnuts, or coils which ever way one would build it. Then spiral the mags or coils in a spiral running up a tube. the stem on the float is twisted and the cork would turn and generate as it passes the magnuts or coils. more twists on the shaft the more it would turn. Thats my theory and I'm sticking to it. lol. good luck to you...
Jul 27, 2008. 2:26 PMFred82664 says:
humm how about the pendulum driven by water current say like as in the seas with there tides swinging the pendulum
Jun 3, 2008. 5:32 AMKiteman says:
So, you twang the right-hand end and extract power from the vibrations? Where do you think it could find applications? Maybe a small version in the bottom of a brief-case to charge a commuter's mobile?
Jun 3, 2008. 6:42 AMstonehenge360 says:
would it be possible to turn this into one of those harmonic wind generators?
Jun 3, 2008. 12:43 PMdentsinger says:
Would it maybe work acting as a pendulum. Maybe mount 2 next to each other with magnets attached to the middle of the rubber bands. Then let the magnets bobble back and forth to each other til of course equilibrium is reached.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:FullyInvolvedScientist
