Hard Drive Recovery from a Full Stop
Just the steps taken to get a harddrive back up (Maxtor in this case) from 0 rpm and no bios detection, to 7200 rpm in a few easy steps!
Step 1Get a harddrive of the same make as the failed drive
I determined that the harddrive problem was not a crash because, it wasn't making any weird noises (or any noises at all). When I plugged the harddrive in, I started feeling the components on the controller board, some of which were burning hot. (another indicator that the controller board was burnt out).
I was lucky enough to have another Maxtor of the same make, even though it was of different size, the ICs and components had the same value on the circuit board. So I thought, it couldnt hurt to try and swap the boards.
51 comments
1-40 of 51next »
Sep 2, 2006. 5:27 PMJagged Edge says:
Im glad somebody took the time to post this here :] I've actually done this a number of times with a few seagates back in the day, not to bring you down or anything but its kind of old news, idk if many people know about it but still... good stuff dude :) glad to see all the other gear heads out there.
Dec 13, 2008. 12:46 AMnokturnal says:
my girlfriend has just lost "her entire life" by dropping her external harddrive off desk while active. (I KNOW) Its a seagate ide Barracuda 7200. We cant afford pro recovery, as it costs the same as the two year herbology course she will be failling if her two year project is not rescued. The drive makes that slide click sound, which I know is the arm/stylus sliding across platter cos the last drive that did this I stupidly (in retrospect) plugged in without its casing. WILL SOME ONE PLEASE BLESS US. I have general idea of hdd internals, and am confidant I can repair, with some guidance. What is best? replace platter into new hdd, or repair/reposition stylus/arm, or is the another method. IF ANYONE CAN OFFER ANY ADVICE/ASSISTANCE, you be FIXING A LITTLE GIRLS BROKEN HEART, and helping her HEAL the PLANET with NATURES MEDICINE, her DREAM. PLEASE. (and thanx) a knight with faded armor and a deadbeat mule (creativeartmedia@gmail.com)
Feb 14, 2010. 9:06 AMjimmythegeek says:
I know it's wayy late to reply to your request, but the exact same thing just happened to my son's external HDD (Iomega 250), leaving the thing in a "click of death" state, unrecognized by either Windows or Ubuntu.  After reviewing several presentations on YouTube, there was one nugget of info that we tried --- and it worked.  We turned the drive over onto its back and used a freeware disk recovery app to scan the partitions and locate all the files (about 80,000).  Two reboots of Windows later (it ran chkdsk the first time and rebuilt the file map) and the data was all there.
Apr 13, 2011. 6:41 PMJagged Edge says:
Out of curiousity, What was the app you used called?
Apr 14, 2011. 6:33 AMjimmythegeek says:
Ach. That was over a year ago, but I'm almost certain the software was called PC Inspector. What we had to do was use the PC Inspector app to "Find Lost Drive", then "Find Lost Data", then go into Ubuntu (Linux) to recognize the disk, which advised us to boot twice in Windows to finally get it to recognize the drive again. Yeesh. But it worked! Good luck.
Jan 30, 2010. 9:51 AMzack247 says:
now i need to find a fujitsu hdd with the same circuit board... are fujitsu's even made anymore?
btw, i tried this once with a maxtor, but i transferred the plates as well, and then it never read them again... now its a speaker instead, no sense in letting it go to waste
Sep 22, 2009. 1:46 AMdario_ds says:
I have a maxtor 200gb ide hdd (6L200PO) which intermitent ly gets detected by the bios for very short time.Any idea what will help?
Jan 30, 2010. 9:47 AMzack247 says:
i had a 10 gb maxtor that had the same problem, did you try holding the power plug in it? mine would sometimes jiggle just a little bit loose and it wouldn't boot up
Mar 21, 2006. 2:30 AMgeo says:
Maeser-- How old is your drive? Sometimes the old ones have "stiction", where the head sticks to the platter and the spindle won't spin up. In this case, taking it and delivering torsional shock (usually by holding it over your head and flipping it down and stopping quickly) around the spindle axis usually unsticks it. This is an old trick, know to early SparcStation hackers, amongst others.
Aug 22, 2009. 6:52 AMdg1hunter says:
Amazing - the torsional shock method worked beautifully on my dad's dead 1998 2 GB Maxtor hard drive. (The more widely known non-torsional secret of whacking the thing on the side had already failed). Thank you.
Oct 29, 2008. 9:34 AMlooking4ideas says:
CRAPPPP
Why didn't i c this b4! I took apart my HDD this morning =( And there was no dmg on the plates. LIFE SUCKS =(
Oct 28, 2008. 1:59 PMjunits15 says:
this only works it the circutry is broken. if the platters are dammaged then it wont work
Aug 28, 2008. 12:52 PMwebbhost says:
think this is actually quite a widely done thing.. Great instructable through! My local computer shop can do data recovery, and uses this method if they can get an identical hard drive.
Jun 3, 2008. 11:03 PMsachou says:
This is wierd. I'm actually surfing on my spare computer for an identical hard drive to my old western digital which literally fried-a chip on the board completely melted, but the platters and such should all be intact. I was going to find a new one in a desperate attempt to salvage the data by doing exactly what you did.
Didn't think it would work, but I thought it was worth a try.
Good too see someone had the same idea as me and it actually worked _.
Jun 3, 2008. 12:08 PMchristophor says:
Awesome. I've been doing this for years. Its gotten me out of many a jam. Back when I first started this job, I suggested we do this trick. The other techs scoffed, then later took credit for the idea when the VIP expressed undying gratitude for his rescued data. Now they do it all the time. Great job!
May 21, 2008. 7:05 AMMouserz says:
tried this but still didnt work, so i guess its something else.
Jun 3, 2008. 12:14 PMchristophor says:
You might try dropping the drive from a few inches off the desk. If the bearings are seized, it might knock them loose. Of course its not good for a healthy drive. Also, I've taken the guts / platters from one drive and moved it to donor drive, however, that kills both drives in the end. But if you really need the data, what have you got to loose? Good luck.
Jun 2, 2008. 7:46 PMlittlechef37 says:
.... YOU STOLE MY IDEA... i just never put it on instructables... lol (npi) I did this awhile ago with a fujifilm hard drive. But I had no success.... :(
Nov 22, 2007. 6:17 PMsbaxter117 says:
I never new that a hard drive could be fix.THANKS DUDE!!!!!!
Nov 2, 2007. 3:39 PMroyalestel says:
Spiffy! Never thought of that!
Sep 21, 2007. 3:52 PMRobbo_roberto says:
Ahhhrggg. Had the same problem with a Western Digital drive. Incredibly, had two drives that were the same but the firmware version on the second was different and the controller board from the other drive wouldn't communicate witth the drive that had the failed controller board. WD wouldn't sell me a replacement controller board! Bstrds! No more WD drives for me. Two dead 250G drives in less than a year! All my digitised video. It's all there but can't get at it!
Nov 1, 2007. 6:38 AMmoonlightcomputers says:
Go to www.myharddrivedied.com and find the instructional videos regarding logic board replacement. If you watch the videos you will find a "hot swapping" technique that might just fix your problems.
Mar 9, 2007. 6:01 PMxfirexstarzx says:
sorry to go off topic... but does anyone know where I can go to get a cheap hard drive? my computer needs a hard drive. The old one was smashed with a hammer... long story
Sep 4, 2007. 6:58 PMTheOneEyedHobo says:
Go to newegg.com
Jul 4, 2007. 1:29 PMrhino says:
You are welcome. Thank you for this instructable.
Jul 4, 2007. 4:39 AMrhino says:
Here is where you go for new logic boards.
hard drive logic boards
Sep 2, 2006. 5:30 PMJagged Edge says:
what MsWiz said. This makes me quite happy, glad the infromation is out there for the public.
Mar 20, 2006. 1:43 AMMaeser says:
I've got a Western Digital in the sam situation...however when I swap the boards and power it up, it just clicks three times then powers down...any suggestions?
Jul 26, 2006. 6:24 PMredline says:
Did you ever fix this problem Maeser? My WD 160gig just did the same thing spins up clicks 3 times then spins down... i hope its not too serious... i had all my school work on there =*(
Jul 7, 2006. 8:56 PMcompudude86 says:
i assume its a maxtor diamondmax (9100? possibly 80GB?) i have one of those, it came to a dead stop because the spindle motor finally seized as most of them do, and i lost half my lifes work, back up your maxtors people!!!
Jun 18, 2006. 5:10 PMCapitolCrime says:
Also, before doing any of this, try this trick that I learned at the FBI's Regional Computer Forensics Lab. If the drive is not spinning up, put it in a non-static bag and place it in a freezer for about 15-30 minutes.
May 15, 2006. 2:17 PMDiGiTALMADDOG says:
im having the same problem right now with a seagate 160 gig hd for some reason the computer would see it but would not activate it-- same for the hacked up usb box for hooking up drives --- it acts like it need to be formatted but i dont want to do that because ill loose all my data on it any clue as to waht to do!!!
May 15, 2006. 3:51 PMDiGiTALMADDOG says:
im not that far into linux to do that yet --- i had thought about it but i have to find another machine to try it on!!!!
1-40 of 51next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:nak(AboveSoBelow)
Twitter: @uberscientist
