Hard Drive Sander
9,889
172
11
Posted
Introduction: Hard Drive Sander
Use a old hard drive as a sander.
Step 1: Hard Drive
Remove all the screws to reveal the inside. And then take out all the components. Leave the bottom plate on if you have one.
Step 2: Sanding Disk
Get your sandpaper and trace the platter onto the sandpaper.
Step 3: Glue and Cut
Add super glue and glue the platter to the sandpaper. After the glue dries cut out the platter with a knife.
Step 4: Finish
Put the sanding disk back on.
my hard drive needed the rw arm on to work so i left it there.
Plug in the power to start it up.
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    11 Comments
    '' Plug in the power to start it up.''
    Were?
    How?
    How to plug this pls.
    With amps?? Because 12 volt uses on hdd
    Use a standard 12 v supply. The sander should be able to self regulate current.
    I meant sata power or molex
    Good idea, but is the power enough for a sander? Maybe you could demonstrate in a video?
    It spins at very very high speeds so there is enough force to sand. You can search up hard drive sander
    Hard disks normally have 5400 rpm for old drives and 7200 rpm for the newer ones.
    Ive done this before and its a pretty handy little tool to have around in the DIY toolchest.
    I will say though that not all hard drives are the same and you will have to find a drive that will continue spinning with the read/write head disconnected. (Thats what I did to mine)
    After I removed the read/write head, I potted all connections not used and the pcb from any access with hot glue so its all sealed and makes it a lot more robust.
