Hard-Drive Sleeve DIY
1,621
17
Published
Introduction: Hard-Drive Sleeve DIY
About: Lana is better known as Lana Red from www.lanaredstudio.com. She is from the Netherlands where she studied Design. She started her blog in April 2012, to combine her love for crafts, photography and just ev...
Also have an external hard-drive that might like a warm coat?:)
Try this easy DIY to create your own hard drive sleeve!
It's really simple, and you can of course use this method for anything that might need a sleeve! :)
Step 1:
Materials needed: 4 pieces of felt in two different colors | Needle and thread | scissors
1. Cut four pieces of felt in the size of your harrdrive + 2cm.
2. Use pins to attach the four layers on one side and at the bottom.
3. Stitch the pinned sides. Place your harrd-drive in the unfinished sleeve and pin the other side. Remove your hard-drive and stitch the pinned side.
4. Cut away all the excess fabric.
5. Use a blanket stitch on the outside of the sleeve.
Step 2:
All done!
For more fun DIY's visit http://www.lanaredstudio.com
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    3 Comments
    And you could make it reversible
    You could put tiny hoes all over for it to breath
    Great idea for making a hard drive a little more attractive. I would just like to say that I wouldn't leave this cover on the drive while you are using it. Having the enclosure covered means very little or no air movement / cooling of the drive. Excess heat can cause drive failure. Just some friendly advice.
