Introduction: Hard Drive Speaker
In this instructable we turn a hard drive into a speaker.
Step 1: Items Needed
Items needed for this project :
1. Hard Disk Drive
2. Soldering Iron
3. Wire Cutter
4. T9 Torx Screw Driver
1. Hard Disk Drive
2. Soldering Iron
3. Wire Cutter
Step 2: Disassemble the Hard Disc Drive.
Disassemble the HDD.Use the T9 torx screw driver to remove the screws.Some of the screws are hidden under the label on top of the cover.
Step 3: Remove the Magnet on the Top.
Remove the magnet on the top. First remove the screw that holds it in place and lift the magnet out slowly.
Step 4: Remove the Lock of the Head.
Remove the lock of the head.
Step 5: Remove the Head of the HDD.
Remove the contact terminal (the plastic thingy) shown in the first picture.Then turn the head off the platter and lift it straight up(second picture).
Step 6: Now for Some Hacking.
Solder a piece of long wire on to the terminals shown in the picture. (sorry about the blurry picture) This is the wire to be connected to the amplifier.
Note: The thinner the wires are, the better, because then the read/write head will have enough room to move freely.
Step 7: Spindle Motor Hack.
Connect another piece of long wire to the spindle motor terminals (at the bottom of the HD)
This step isn't necessary but adds to it.
Step 8: Reassemble the HD.
Now put all parts together except the head lock and the top cover and Don't forget to screw the read/write head back on.
Step 9: Completed.
The mod is complete. Connect the wires to your amp. Mine is 30w x 2 so that i can connect the spindle motor and the read/write head seperate and each of them gets 30w = 60w total.
