3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hard Drive Speaker
Hard Drive Speaker
In this instructable we will make a speaker out of a hard drive.
Step 1Items Needed
Items Needed
Items needed for this project :
1. Hard Disk Drive
2. Soldering Iron
3. Wire Cutter
4. T9 Torx Screw Driver
142 comments
1-40 of 142next »
Mar 24, 2012. 1:48 PMGASSYPOOTS says:
thats annoying X_X
Sep 24, 2011. 10:25 PMfrostybob says:
Hey guys did as per instructable and nothing happens. Tried it on two HDD and still nothing on either. HELP???? and sorry.... It is possible I broke something because the reading things on the end looked pretty munted
Jul 13, 2011. 12:55 PMAce Winget says:
I just use a small flat head and you can get those torx screws to loosen. If you have a drill the you could always just drill those out. I found an image of a hard drive dis-assembly here that I found really cool and helpful. Thanks sybyabraham great info!
Jun 25, 2011. 6:34 PM_Scratch_ says:
Korn in the vid! lol
Jun 25, 2011. 6:37 PM_Scratch_ says:
Also, can anyone give me an explanation on how this works?
Apr 18, 2010. 6:40 AMJords001 says:
Very cool. Has anybody tried this as a microphone? Just curious what the quality would be like.
Feb 25, 2011. 5:17 PMcody777 says:
doesnt work well
Nov 10, 2009. 5:18 PMametz says:
I do not have a torx screwdriver or a drill press. I have all of the outside screws off by using a wrench, but the hidden screws are impossible to get to without the screwdriver. what can I do?
Feb 25, 2011. 4:38 PMcody777 says:
if you have a dremel you can cut a slit into the screw and use a flat-head, i do it a lot
Apr 30, 2010. 6:40 AMapb2390 says:
I'd say it's very hard to do that, but you can get a T9 Torx screwdriver set for 8.95 USD at a large hardware store.
Jan 2, 2011. 12:45 AMPyrice4 says:
You can follow these two all the way through the ribbon wire into the back of the main PCB so you dont have to take the arm off.
Feb 20, 2011. 2:58 PMMoglizorz says:
Yea, that's what I'm doing now. Seems alot easier soldering to the existing PCB (especially on this old 90's hard drive I'm using where the components are massive) than doing this delicate stuff.
Feb 28, 2009. 7:50 AMJoxson says:
It´s not a speaker in there. I made one for myself today. It works great!!!! Can I make so the volume is higher? Sorry for my English!
Mar 31, 2009. 2:37 PMmettaurlover says:
my suggestion: make multiples, and then solder the like ends to make the proper amount, solder wires onto those ends, and plug it in. more speakers=more sound.
Sep 26, 2010. 2:38 PMJoxson says:
Sorry for so late but a fun thing.
I wanted volume so I pushed in 130 Watt in it! HAHAHA, it starded to smoke^^
But the volume was high.
The harddrive speakers can stand aboud 110 Watt:D
Sep 26, 2010. 2:46 PMmettaurlover says:
Jun 10, 2010. 10:06 AMbioerror says:
what u do is get 2 ppl, 1 person holds the HDD down and the other uses 2 pliers and grabs the metal on either side of the magnet and pulls up with all their might!
Mar 16, 2010. 12:57 AManonymousrandomguy says:
Korn (Y)
Apr 10, 2009. 3:51 PMdakiller546 says:
mine only has three terminals :( witch do i use
Mar 6, 2010. 10:34 PMthestyrofoampeanut says:
 yes it will work
one is a ground and danymw just has a different hard drive
test out each terminal with test leads
youll find the two that work
Feb 22, 2010. 10:43 AMdanymw says:
 it won't work
Jun 10, 2007. 2:08 PMdanymw says:
are you sure? i allmost smashed my fingers with it,and broked the hdd...when connecting the wires.i'll get another one
Feb 22, 2010. 9:49 AMMr.Grinch says:
I had issues with mine also, did yours twist off, or slide off? it took me five minutes to realize that my WD drive magnet twists off, and my Seagate... doesn't
 i opened up about 10 hdd,all damaged or low memory space, but they were all different. rarely,the magnet just comes out,but usually you have to use a screw driver to remove the top magnet (after removing the screws). if you twist it, you'll hit the head or even the plates and damage the hdd,which i did once, and it's not good.
good luck
Nov 10, 2009. 6:20 PMametz says:
It wont come up... help??
Feb 22, 2010. 9:56 AMMr.Grinch says:
I had the same issue with the arm, I think he forgot to mention that there is another screw on top, where you removed the screw to get the cover off. Mine happened to be an hexagonal screw that had another screw in it
Nov 26, 2009. 7:27 PMzack247 says:
you may need a flat screwdriver to unscrew it
Jan 25, 2010. 3:25 AMShotPain says:
 i was hoping you could make a turntable out of a HDD :D
Dec 27, 2009. 5:51 PMHelder4u says:
I would not try to connect to the motor drive.. but only to the arm assembly.
That should take care of burning amplifiers and sound inconsistencies.
Apr 26, 2009. 4:10 PMbeauwalker23 says:
congratulations on making it on N4G.com!
http://www.n4g.com/industrynews/News-318009.aspx
Nov 26, 2009. 7:31 PMzack247 says:
i have a problem: did you connect the wires to the reader head, or the coil thing? (i know i sound stupid)
Nov 22, 2009. 2:46 AMmonorail says:
I made one of these just now and theres sound coming out, however the read-write head itself is not moving at all as seen in the video in this instructable. I have connected it with a speaker wire to my laptop and didn't do the spindle motor hack part. Is this why the head isn't moving?
Nov 20, 2009. 4:21 PMmae-kitty says:
 Remember. Not all hard drives are the same. ATA and IDE and Parallel Drives can all be different. Not all that you see this person doing can be of use to you. But it gives you an idea of what to expect and look for.
Oct 30, 2009. 5:42 AMpyrorower says:
Damn, now I wish I hadn't maimed my old hard drive. Nice song choice btw.
I better start keeping an eye out for computers on the side of the road now :P
Jul 16, 2009. 4:27 PMTrevor114 says:
here is my issue i don't want to hook it up to my amp because it reads 16 resistance on a meter thing and a speaker runs a 8 resistance it will blow my amp up what do i do
Oct 20, 2009. 4:17 PMmatador29b says:
actually, it won't blow.  Higher resistance is better than lower.  If your amp outputs, say 50 watts, at 8 ohms, you are sending 2.5 amps to the speakers, but at 16 ohms you are sending 1.75 amps.
A lower resistance will be a problem.
(the ideal amplifier has very high gain, very low input impedance and very high output impedance)
I think my concept is accurate, can someone confirm?
Oct 6, 2009. 2:19 AMchamp523 says:
how to run it dude
Sep 20, 2009. 9:19 AMtheteengeek says:
dude my amp almost caught on fire. What did i do wrong?
Oct 4, 2009. 4:07 AManitokyomics says:
First things first... Wattage and load... Good thing I have 2 amps with me here to work. The first one did. When I checked, it had a limit. So, prolly the HDD itself is wattage dependable. man.
1-40 of 142next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:sybyabraham
