Hard Hat Fan
9,103
30
10
Posted in WorkshopTools
Introduction: Hard Hat Fan
I install residential and commercial solar. Sometimes it gets hot when working on the roof and I wear a hard hat to protect me from the sun. The hard hat has lots of room around and above your head to allow for air to flow so it keeps me cooler than a regular hat. Having a fan that circulates air inside the hat helps to keep cooler air flowing over my head.
Step 1: Find the Materials Needed
I bought my materials from JK Electronics in Westminster, CA but I'm sure Radio Shack or a local electronics store would carry these items.
12 volt squirrel cage type fan - $5.00 (will run on any voltage from 3 volts up to 12 volts, more volts = more speed)
9 volt battery housing with switch - $2.89
9 volt battery - $1.89
18-20 gauge crimp connectors (2) - $0.25
Self adhering cable tie blocks (2) - $0.50
I got the white full brim hard hat from The Home Depot for about $14.00
Step 2: Attach Fan and Battery to Hard Hat
I used hot melt glue to attach the fan to the hard hat. Make sure you don't get glue into the moving parts of the fan. For the battery enclosure, I used self adhering cable tie blocks. The battery enclosure that I bought has the battery door on one side and the switch on the other. I need a way to replace the battery and gluing the enclosure would have prevented this. After everything is mounted, I cut the wires to length and crimped them together.
Step 3:
I have a sun shade that shades the back of my neck but still allows air to flow. A wet bandana or a Buff around your neck will also help. Stay Cool!
Update 7.1.14: After using this for a couple of weeks I can say that it does keep my head cool. I shave what's left of my hair so the air is blowing directly on my head. If you have thick, luscious, beautiful hair, this might not work as well for you. I'm going through one 9 volt battery about every 15 hours (which is one and a half work days for me). I'm going to research using a small solar panel, rechargeable battery and charge controller (maybe Arduino).
Step 4:
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    10 Comments
    Hi i am trying to build this for my husband for his birthday and i am having trouble finding the fan and the 9v batter housing i have been to an electrical supply stor home depot twice and walmart any ideas on where to get those last 2 itmes?
    Try a computer store, not Best Buy but something like Fry's or Microcenter.
    Good idea. I am making it for my uncle
    If you don't need the hard hat for actual protection, you could also drill some vent holes at the top, let the steam rise out...
    Actually OSHA is really tight about that. You'd be surprised at how little change there has been in hard hat design since the days of the original 'Hard Boiled Hats'....very few of them have any real attempt at ventilation.
    I need it for protection so I can't drill holes, it also makes a great rain hat in the winter, so the holes wouldn't be good for my application.
    Ah, well, it was a thought...
    Everyone should take safety equipment seriously
    Nice! Too bad that you have to carry those batteries.
    The 9 volt battery, fan and battery pack aren't very heavy. I can't feel the difference with them attached to the hard hat.
