loading
Use your fingernail to tell the difference between hard and soft wood. Hard woods are useful for making sturdy long-lasting constructions and produce more heat when burnt. Soft woods are light, easy to shape and are useful for making objects that float or fly. Is the wood your are using suitable for your project?
NOTE: This Instructable is to assist people who work with found wood, or are new users of wood. For the purposes of this Instructable taxonomic distinctions between hardwood and softwood will not be considered. These classical distinctions have little or no bearing on wood density and appropriate usage. I use the terms soft wood and hard wood to reference density; in contrast to hardwood and softwood which refer to traditional taxonomy.
Step 1: Soft Wood
When you press your thumbnail against soft wood and pull it along the surface it leaves a scratch mark. The deeper the mark - the softer the wood.
<p>Good and effective way to use.</p>
Woods are classified by their 'density'! Each timber has a 'Specific Gravity' value and 'calorific index'. The higher the SG and CI are the harder the wood! But the 'hardness' of a timber would be determined in simple terms by how much it grows during a year relatively. It's about the absorption of carbon from the atmosphere being deposited into the wood! Deciduous trees have relatively denser wood than evergreens generally and so the wood is termed 'harder'. However a 'hardness value' isn't much good unless one looks at the 'working properties' of the wood!
Hardwood or softwood, Yes Balsa is a Hardwood, and Yes its very light and buoyant, does anyone remember from school the boat named “KON TIKI” made from Balsa wood, so why classify and what is the difference, basically the cell structure is different between hard and softwoods, hardwoods tend to have long egg shaped or rice shaped cells, while soft woods tend to have more circular type or bubble shaped cells. The area inside the cells is larger on softwoods and its within the cell that cellulose is stored and its cellulose that woodworm and other wood boring creatures like to eat, so your soft woods are more prone to infestation than hardwoods, so if you simply forget about the density of a timber and simply consider the cell structure you can make more informed choices. For example a window frame or cill can be made from a treated piece of pine [softwood] when treated the cellulose is replaced in the external layers of the timber by an insecticide, now this timber will be as long lasting as a piece of hardwood. John
&nbsp;the treatment you put on timber to stop woodworm will only soak into the timber a short way and its only when the insect burrows its way in and lays its eggs but the worm itself will eat its way out of the timber eating the treated timber which will kill it.<br /> <br /> yeah you cant tell timber by just the hardness grain is important and also smell weight.<br />
<p>aup JOHNNY!!!!!!!! WE ARE MEMBERS!!!!!!!!!!! w00p w00p :)</p>
The Kon Tiki was awesome!!! (I'm reading the book)<br /><br />
david arter-borkwood is reading it as well it is beastie
you have a book on wood ^o) coz ur cool :)
china
i bet wood on the picture is hardwood. am i good or what<br />
Ok, I had to sign up just to comment on Sgt. Waffles's comment... Take a read through that wikipedia link you posted... it clearly states in the last paragraph: "Despite being very soft, balsa is classified as a hardwood, the softest commercial hardwood."
Sgt. Waffle said "Balsa IS a soft wood". He's right. Balsa is a soft wood. Balsa is, however, classified as a "hardwood". It's a soft hardwood. Makes me wonder if there are any hard softwoods?
Wikipedia say "yew" is a hard softwood.
&quot;you&quot; is definately a hard wood
&quot;you&quot; is a hardwood
The Monterey Pine is a<strong> hard softwood</strong>. They often use it to make grain-end cutting/chopping boards, who last well.<br />
Arboreally, hardwood and softwood are classified by the way a tree grows. In general, broad-leaf deciduous trees are hardwoods and needle-bearing conifers are softwoods. Generally, hardwoods are harder than softwoods but there is plenty of variation up and down the scale in each category. In woodworking, a when considering a hardwood or softwood, it often has more to do with permeability and resistance to rot. Hardwoods, regardless of their actual hardness, are usually more resistant to water and less prone to rot.
yup. look at balsa. that's a hardwood
LIAR its a soft wood actually (Y)
I wouldn't bet money on that Harwoods are more resistant to rot thing - more importantly, I wouldn't bet a bunch of hours of work on a project I was going to leave out in the rain. White oak is incredibly rot resistant. Red oak rots with glee! Cypress and cedar are both highly rot resistant despite the fact that they are soft woods. If you go to a store that caters to woodworkers you will tend to find lumber divided something like this: Hardwoods: Oak (white and red), maple, walnut, cherry (Plus some others like ash and hickory depending upon their selection and location) Softwoods: White Pine, Yellow Pine, Cypress, Fir Exotics: Most Everything Else (Red Heart, Ebony, Zebra Wood, etc.) A lot of the things that would be debated get lumped in with the exotics.
don't forget poplar, the 'softest hardwood'.
Balsa is one of the lightest, least dense woods there is, but it is considered a hardwood because it's an angiosperm. This is not useful knowledge unless you are buying a load of unspecified hardwood in tropical South America and also, may get you nicknamed "The Village Idiot" if you distrubute said knowledge at the more popular small town redneck bars. So speak it with caution.
According to "The Complete Book of Woodworking" (ISBN 1-890621-35-8): "Botanically speaking, trees are categorized as either hardwoods or softwoods. Here's a simple way to distinguish the two: hardwoods are deciduous (broad leafed), generally losing their leaves in late fall and reproducing with flowers and fruits or nuts. Softwoods, on the other hand, are coniferous; they retain their needle-shaped leaves in the winter and reproduce by spreading their seed through open cones. The terms 'softwood' or 'hardwood' have nothing to do with whether the wood is physically hard of soft."
Spot on! <br /> <br /> Hardwood seeds have a cover when they fall off the tree: apple, cherry, wallnut etc. and grow a new plant close to the parent tree. <br /> Softwood fruit still hangs on the tree when their seeds escape from the cones and are distributed over a wide area.<br />
you guys are so sad :)
i agree:)
Anyone know if it is possible to determine whether a piece of burnt wood was hardwood or softwood?
Yes, but only if there is enough unburned wood left to put under the microscope to determine the cell structure of the piece of wood. If it is only charred coal which is left, I do not have enough exprience in burned timbers, but maybe experts can still decipher what it was.<br />
I prefer to test the wood with my carving knife, which is a modified Mckay stitcher. What I do that I shave off a few chips with the grain in order to test its natural &quot;resistance&quot;. In this business (woodcarving), it is vital to know the grain pattern first because interlocking may provide &quot;hard&quot; samples even in known &quot;softwoods&quot;. By the way ,here is a great link to a site that explains woods growing in Puerto Rico (my location) Although, it is written in spanish, it contains useful and information for any woodworker or exotic wood collector. <br/><a rel="nofollow" href="http://maderaspr.uprm.edu/Maderas%20de%20Puerto%20Rico/index.html">http://maderaspr.uprm.edu/Maderas%20de%20Puerto%20Rico/index.html</a><br/>
I know how to determined hardwood and softwood.. it easy when we just use finger touch.. But if our look into the cell in the wood use example microscope image analyzer, i still cunfuse how to differ that..
thats commom sense
Ummm, is it just me, or is this common sense?<br/><br/>Also, to dispel the rumors, Balsa IS a soft wood:<br/><br/><a rel="nofollow" href="http://en.wikipedia.org/wiki/Balsa">http://en.wikipedia.org/wiki/Balsa</a><br/><br/>Second paragraph, first sentance.<br/><br/>OWNED!<br/>
Same article thirth paragraph, first sentence: Despite being very soft, balsa is classified as a hardwood, the softest commercial hardwood.
Yeah, i just realized &quot;hard wood&quot; and &quot;soft wood&quot; have nothing to do with the hardness of the wood, but the tree either being coniferous or deciduous. Learn somehthing new every day, huh?<br/><br/>However the person who posted this:<br/><br/><strong>technically balsa wood is a hard wood... try cutting an equally small piece of oak and try to snap it... you'll see what i mean...</strong><br/><br/>Is wrong. Oak is MUCH stronger than balsa wood, and i know that for a FACT!<br/>
So scientific, I've seen hard softwood and soft hardwood. Hahahaha at Sgt.Waffles being owned by his own wiki pasting. "Despite being very soft, balsa is classified as a hardwood, the softest commercial hardwood." Jesse said "part of me wonders why we would be so silly as to distinguish between hardwood and softwood for any other reason than density." Rightly so but that's how it is and this method is incorrect, unless your fingernail can work out what type foliage the wood used to have.
Thanks for the semantics clarification. However, part of me wonders why we would be so silly as to distinguish between hardwood and softwood for any other reason than density.
Well, if you're telling us that 'hardwoods' are hard and you can tell this by seeing how hard they are with your fingers this is svery obvious. As has been pointed out repeatedly, strict definitions of hard and soft woods are not neccesarily related to their mechanical properties, this is where being able to tell the difference would be of some value (perhaps?) L
European fixation. Most (with exceptions) trees fall into the hardwood-leaf and softwood-needle categories.
Hard wood is wood that is hard. Soft wood is wood that is soft. Hardwood is "wood from broad-leaved ... or angiosperm trees." Softwood is "the wood from conifers..." Note the space. Hardwood is a specific term meaning a specific thing. Hard wood, with the space, means wood that can be described as "hard. Same with Softwood and soft wood. Balsa is a soft wood that comes from a hardwood tree.
Thank you, this is a good explanation. I am no longer so perplexed.
Please, explain me that "...technically balsa wood is a hard wood..." I believe balsa is a very soft wood.
La balsa (Balsawood) por una definición del libro es una madera dura, no de tacto (touch) y de peso ......Is balsa raft in Spanish ? Sorry the border Spanish again
by what jesse hensel said... it qualifies by his test
"Hardwoods Generally one of the botanical groups of trees that have broad leaves in contrast to the conifers or softwoods. The term has no reference to the actual hardness of the wood." -- Wood Handbook, Wood as an Engineering Material, USDA Forest Products Laboratory, Agriculture Handbook 74 I knew this book would come in handy some day.
About This Instructable
74,417views
34favorites
License:
Bio: Perhaps I am the heretical harbinger of the New Archaic, perhaps I just like wood.
More by jesse.hensel:Fire Polished SpoonWoven TetrahedronCuboctahedron
Add instructable to:
