Hardware Disc Golf Basket by Orange Guy
Featured
Step 13: Making the Basket
Time to assemble the top of the basket. Loosen the hose clamp on one of the 1-1/4-inch to 1-1/4-inch rubber coupler halves and slide over the pole with the hose clamp side toward the top. Tighten enogh to hold in place, you'll fine tune the placement later. Now see if the PCV piece with the eyehooks will fit. You may need to sand/file/grind a bit out of the smaller end to make it fit on the fence post. Slide it down the fence post to rest on the rubber coupler. Next, place the grill grate assembly on the post with the flared end of the galvanized floor flange resting in the PVC part. Loosen the hose clamp on the remaining rubber coupler and slide on the post with the hose clamp facing down. Tap the 1-1/4-inch PVC cap into place on the top of the fence post.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
