This is a steam engine that requires no machining of parts, and everything you need you can buy at a hardware store. I made two of these about 2 years ago but I didn’t take any pictures of the build. So this is my third one, I built it this morning.
What you will need:
½ brass test plug .625” O.D.(piston) http://www.grainger.com/Grainger/Rod-Stock-2ABJ4?Pid=search
½ copper repair coupling 12” stick (cylinder and other components)
½ copper pipe.
½ copper cap 2 Qty
¼ copper line
Wood for a base
Epoxy
3/16 brass rod (connecting rod)
5/16 bolt and Nut to fit
3/16 steel rod
Caster wheel (flywheel)
Miscellaneous hardware as needed
Remove these ads by
Signing UpStep 1Base and Flywheel Stand
2) Now you need to pull the caster wheel out of its bracket assembly. you don’t have to cut a relief in the base for the flywheel to sit beyond flush, I just like it because it keeps the center of gravity low.
3) Cut out two posts from the ½ copper pipe for the fly wheel stand. Drill two pilot holes in the post (leave under size, will ream full size once post are cured to the base)
4) Drill two 5/8 holes in base for flywheel stand.
5) Mix two part epoxy and bond the post to the base, put a rod through the pilot holes and make sure rod is set perpendicular to the base as the epoxy cures.
the test plug is expensive and hard to find.
im way to obsessed with this instructable.
http://youtu.be/c2TAccSxQJk.
I put a sequence on my blog.
http://hansmeevis.blogspot.com/
For what it's worth......
Check out http://youtu.be/HhAkS0vWsEo
And just for interest sake, I put up a tut on my blog yesterday, unrelated to engines but concerning jewellery .
I have a lot on my website http://meevis.com/jewelry-making-class-list.htm
Nevertheless, It was your original tut that started all this (grin)
My wife has been heard muttering things like second childhood and senile...etc.
Cheers, Hans.
I just finished a machine based on your instructions. Thanks, very cool and very well done. I had been looking around for something like that and yours fited the bill perfectly. I posted a video of it running on you tube http://www.youtube.com/watch?v=nmRI4YB7VCA My user name is gemhund. Thanks again,
Hans
@myakka:if you soldered it right it shoud hold up pretty good.I made my flywheel from a nut and 6 bolts and tested it with a drilling tool and it remained intact during and after the spinning.
Btw: you solderd six bolts to a nut? I realy hope those dont break off... Or even 1 of them ... It wold shake itself to peices
Dan
It would be nice to be able to charge a smart-phone with burning wood ^^
pls xplain
On Number 1 instruction. It says drill through both pipes. Since the drawing shows only the pivot pipe, I will interpret it as a through hole from one side to the other. Is this correct?
