3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hardware Store Steam Engines (no machining required!)
****** FULL INSTRUCTABLE GO HERE http://www.instructables.com/id/Hardware-Store-Steam-Engine-full-instructions/!*****  STEAM ENGINES!!!!!! and you dont need a machine shop.
I built these a while ago not intending to post on instructables so unfortanly i have no photos but i have videos
fly wheel = steel caster wheel
piston= brass plumbing plug
cylinder = copper pipe
where the steam inlet is theres a small hole drilled on the inner copper pipe, as it rotate this hole opens on the power stroke, and then closes on the back stroke
just the oposite happens for the steam outlet  it closes on the power stroke and then on the back stroke it  opens to let pressure out.
if i ever build another one i will make sure i take lots of photos!
GOOD LUCK! ask if you have any questions.
35 comments
May 11, 2012. 5:43 PMElectronics Man says:
WOW this is great, how did you make the piston?
Oct 15, 2011. 9:21 PMFlameHazard says:
AWSOME DUDE, Just awsome!
Feb 24, 2011. 3:49 PMdmat257 says:
Really cool, I love steam engines, very powerful. I was wondering how to build the boiler for this project, or where to find it here?
Mar 6, 2011. 5:15 PMjj.inc says:
You can use just about anything for a boiler, just get a metal pipe, fill it with water, attach a hose, and put a heat source under it.
Feb 17, 2011. 6:49 PMLapin1 says:
Your design is really neat. I'm just guessing, but the inner pipe openings should look like this:
Feb 17, 2011. 9:21 PMLapin1 says:
I never could come up with such a nifty valve system. You're a genius!
I gather some pipes and give it a try. This should not prevent you from building another... and ible it.
Feb 25, 2011. 8:10 AMFishDaddy says:
Very cool - How about greater detail where the Air/Steam enters the piston tube?
Feb 19, 2011. 3:17 PMBongmaster says:
u done wat i have been wanting to do for a ling time :) i have no machine shop either XD, a butane torch and a dremel copy is my best bet x3
Feb 17, 2011. 2:39 PMrandofo says:
Those are very cool. Why do you have two inlet valves?
I'd be very interested to see a full build if you ever make another one.
Feb 17, 2011. 2:57 PMNachoMahma says:
.  Looking at the videos, they appear to be forward and reverse.
.  I would most definitely like to see more, especially how the valve is constructed.
Feb 24, 2011. 2:27 PMDieCastoms says:
I would love to see you use this same principle to make a double acting engine or a multi cylinder engine. I have no idea how you would sort the valve, however.
I wish I had ANY 'machinery' or metal tools. I left everything behind when I had to move in a bit of a hurry...
Mike.
Feb 23, 2011. 11:43 AMharmonbill34 says:
When drilling for the valve holes. What is the relationship of the crank to the piston?
Do you drill the inlet with the crank in the 12 o'clock position and then the outlet with the crank in the 6 o'clock position?. If it was a vertical engine would it be crank at 3 o'clock and 9 o'clock?
I was thinking you would drill the inlet when the piston is at top dead center and then the outlet when it is at bottom dead center. That is the only thing I am having a hard time understanding with this build. Thanks for the great ible. Your valve idea is brilliant and I want to make one of these. Luckily I work for Lowe's so I can get my materials at a dicount:)
Feb 21, 2011. 3:51 PMtechno guy says:
Can you get the parts from the home depot or lowes?
Feb 17, 2011. 2:36 PMKiteman says:
Oh, please, please write up a proper Instructable on these engines!
Please!
Feb 18, 2011. 11:35 AMmman1506 says:
do you have to weld the inlet pipes could you use jb weld or something similar
Feb 18, 2011. 6:32 PMmman1506 says:
Ok i thought it was welded (pretty stupid come to think of it) I have a 60W iron which should work
Feb 19, 2011. 2:50 PMLectric Wizard says:
AWESOME !! Can't wait for the ible ! Very original idea ...
Feb 19, 2011. 12:11 PMGhost Wolf says:
Amazing I have never seen this before! Are you going to have it drive something like a fan or a mixer for coffee or tea?
Feb 17, 2011. 9:36 PMBongmaster says:
awesome :) please ible this engine :D
Feb 18, 2011. 11:05 AMAzeem-Naseer says:
great work
Feb 18, 2011. 6:44 AMroshan sharma says:
really great idea
Feb 17, 2011. 8:40 PMNostalgicStone says:
Yes this is very neat, Make a full Instructable!
Plz?
Feb 17, 2011. 7:48 PMcpotoso says:
This is very nice! Can you add a diagram and list of items needed if one wanted to reproduce, please?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
40
Author:kcbford1
