3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hardwood shelves
Hardwood shelves
When you graduate from milkcrates, but cannot bring yourself to buy disposable Ikea furniture for ethical, environmental, or repressed-childhood-memories-of-parents-who-loved-the-Swedish-crap reasons, build some hardwood shelves. Woodworking is often relaxing, and you'll end up with hand-made furniture you can be proud of.
Step 1Get Lumber
Go to a nice lumber store and get some hardwood. In the Bay Area I go to PALS and buy certified hardwood. Certified means that the wood was grown and harvested in a sustainable way.
The wood will be measured in board feet. Roughly, a board foot is a measure of volume equal to 144 cubic inches; however, as with any trade specific measurement, it's not quite that simple. Rounding errors need to be dealt with properly.
31 comments
Jul 4, 2010. 11:07 AMrapidprototyping says:
Hear is a good well built book shelf set your standards high
Nov 27, 2006. 8:33 AMpfred1 says:
You should have gone with rabbits and a dado for the center shelf it'd have aided you greatly in your assembly. Both joints are self aligning. You wouldn't have ended up with that gap in the center of the shelf like I see in step 11 with a dado either. Proper joint selection is the most important step in any woodworking project to me. Oh, and as for dented wood try wetting the spot, then heating the spot with an iron it should steam the absorbed water expanding the cells and raise the wood. Your router is your friend, leave that biscuitter for kitchen cabinet carcasses like it was intended to be used for!
May 9, 2009. 10:29 AMforced_to_make_an_account says:
Those joints would compromise the appearance, though. To keep the same clean look but use self aligning joints would require stopped dados on the shelves (easy enough but still much more work than the biscuit) and a mitered mortise and tenon for the corners -- much harder to do! More work + more opportunities to mess up.
Jul 24, 2006. 11:58 AMSeverious says:
Wait, let me get this straight... You have a Powermatic tablesaw with extension table, but you don't have a tickness planer?? Wow...
May 9, 2009. 9:54 AMforced_to_make_an_account says:
Huh? Wouldn't a person normally get a table saw before getting a thickness planer?
Feb 21, 2009. 6:18 PMFirebang says:
Take your wood to the local high school, they might have a thickness planer for you to use.
Jan 2, 2009. 10:00 PMmynameisjonas says:
"I skipped this step because I don't have these tools." a problem that comes up all to often in my woodworking projects.
Jun 12, 2006. 8:28 PMulyssespdx says:
A *jointer*? a *thickness planer*? *biscuits*? those are tools for experienced woodworkers, man, not for casual readers who want to knock together a bookshelf in a day. neverind that you also need a biscuit jointer to make holes for biscuits. seriously. plywood, screws, some 1x for facing--that's a simple project.
May 29, 2008. 4:42 PMaliceownsj00 says:
lol not that experienced, I took a year in set design and building in highschool and I know what those all are... just watch Yankee Workshop on PBS for a day and you'll know what they are lol But yeah, it would be hard for some of us to get those tools, they can break bank sometimes.
Dec 11, 2007. 5:49 AMAustringer says:
You are going to so love my "how to make a stub spindle shaper cutter" instructable. You only need two tools for that. A metal lathe and a shaper. After that will be "build a front door with through tenon joinery".
Jan 5, 2008. 7:16 AMcamp6ell says:
hehe!
Sep 9, 2007. 3:09 PMDarkshot says:
hey man it may be a little too "experienced" for some but the finished result will hold up better with heavy books and will actually look better so you have bragging rights to it dont dis it cuz of the biscuts and all that other junk you said this is really a cool project and im gonna try and make it but im gonna modify it :\
Apr 15, 2009. 8:38 PMflio191 says:
it's so true, working with wood is so nice, and the physical effort and focus you delegate to each task makes the finished produce the more worthwhile. :]
Jan 5, 2008. 7:19 AMcamp6ell says:
this is great. it's good to have projects for different skill levels.
Nov 29, 2007. 5:40 AMSharad says:
Can you please explain what is biscuit joint ?
Nov 19, 2005. 6:19 PMhatsix says:
This is great for woodworkers! (however, I'm not one... any chance this could be done on an Ikea budget, since I don't have room for, and can't afford a table saw? I have a hacksaw and a strong arm! )
Sep 30, 2007. 10:37 PMstatic says:
Much Quality furniture and homes have been constructed with good old hand tools. Start attending auctions and garage sales to start filling your tool box with proper wood working tools if you desire to work with wood. Often lumber yards do have hardwoods milled to standard easy to work with sizes. Yes with even buying new handsaws etc. you should be able to do it on an ikea budget. Your tool investment should last a life time.
Nov 22, 2005. 3:17 PMmixman says:
hatsix - if you're on an Ikea budget but want a nice sturdy bookshelf, try down grading this project some. It's beautiful and no doubt done right but definitely a professional job done with a lot of pro tools. On a buget, I would: a) use 3/4 plywood b) upgrade your hacksaw (sorry ;o) to a decent circular saw with a metal straight edge guide and clamps to make your cuts c) blow off the the beveled edges and keep to straight cuts d) sand all surfaces with 120 grit before assembling e) use gorilla glue and trim nails before any finish is applied f) if a router is handy, I like to use a 1/4 round on plywood edges (unless using a veneered edge, that's stepping back up) to keep them from splintering as plyood tends to do important for side-to-side ridgedity is the two inch (or larger) backboards For a finish, use a thick sandable primer. This will seal the wood and the end grains. Sand to your liking and paint. It probably won't be a heirloom like the example but can turn out to be a nice solid and attractive peice of furniture if you spend some time on it. If you are or have an artist friend, a artsy paint job can make it an original. Good Luck!
Sep 9, 2007. 3:12 PMDarkshot says:
wouldnt plywood break so darn easily?
Sep 9, 2007. 3:29 PMcharper says:
not really... think about your roof, it's plywood
Sep 30, 2007. 10:19 PMstatic says:
These days many roofs are deck with OSB products. But that's getting away from the point plywood is plenty strong.
Sep 9, 2007. 5:19 PMDarkshot says:
very true...and WOW are you fast at replying
Sep 9, 2007. 3:31 PMcharper says:
oh yeah - and cheaper floors
Dec 11, 2007. 5:45 AMAustringer says:
I would steer clear of using just plywood for this. Your roof has what, two overlapped shingles on it? Whereas a linear foot of books is "beat someone to death with" massive. Shelves made from plywood will sag in no time. even if they don't fail. That being said, you can get away with plywood ( and still have something that looks good) if you put a solid cleat across the front and back, preferably with a rabbit cut out of it so you can get a face / face glue joint with the plywood. It won't be as strong as solid hardwood but won't break the bank.
Apr 4, 2006. 7:00 PMwaka2007 says:
I like the origamis how do you make them?
Mar 4, 2007. 9:52 PMLostMachine says:
I was admiring the Polyhedra on the shelves as well.
This should help you
http://www.korthalsaltes.com/
Jul 19, 2006. 1:26 PMakathewb says:
This is great! I also don't have the tools, but this was a good introduction into using them, and it gives me somthing to consider in the future. Nice bookshelf by the way!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
702
Author:ewilhelm
Eric J. Wilhelm is the founder of Instructables. He has a Ph.D. from MIT in Mechanical Engineering. Eric believes in making technology accessible through understanding, and strives to inspire others ...
more »
