Introduction: Harley Quinn Bracelet
Picture of Harley Quinn Bracelet
Dr. Quinzel is my favorite Gotham Girl. After an evening of Arkham Origins and catching up on my comics, I decided to keep myself busy the next afternoon and make a bracelet for my wife inspired by the Animated Series' Harley Quinn. I am still in search for a large hammer and a short nose revolver charm to replace the dice with, but for now...and for what I had in the house...here it is :)
Step 1: Supplies and Tools
Picture of Supplies and Tools
Chain - You can always make your own, on this I went with chain stock I had in the tool box
Ribbon - I managed to have both red and black, so I incorporated both
Cards - I wanted to include some sort of diamond in this so I cut up a card out of my "craft deck"
Beads and charms (and Legos, YES!)
Stamping metal (you can cut your own, I purchased a bunch a while back at Hobby Lobby)
Pins and jump rings
Clasp
Tools
Hammer(s) - I used a ball ping to stamp and a 2 pounder to flatten the metal back out
Upholstery Needle
Steel Letter Stamp Set
Tape
Step 2: Threading the Ribbon Through Your Chain
Picture of Threading the Ribbon Through Your Chain
**measure the persons wrist with string and make your chain that length.
Cut the ribbon about 1.5 - 2 times longer than your chain bracelet.
Thread the ribbon through the upholstery needle and tape to secure.
Tie off the end of the ribbon that (make a few knots to make sure the ribbon doesn't slide through a ring)
I chose to thread the ribbon through every two links so the chain still had "meat" to it.
Once you reach the other side of your chain bracelet, tie it off with multiple knots as close to the chain as you can.
I went from the clasp end to the loop end with red, and then opposite with the black.
After both are through, tied, and cut. I tied off each end again with black and red ribbon together to clean it up.
Step 3: Making and Spreading Out the Charms
Picture of Making and Spreading Out the Charms
As I only had a few red and black charms, I decided to use a playing card, red and black die, a Lego dynamite, some random other black beads, and the stamping metal.
After adding loops and jump rings to each of my charms, I arranged them around the chain to see how I'd like to attach them.
When I was pleased with the lay out, I added the jump rings to the chain.
Step 4:
Picture of
Using the two different sized steel stamps, I hammered the name "MR J".
I did the J twice to make it look like she fixated on it a little.
Step 5:
Picture of
ruffles626 (author)2014-05-19
made for my girlfriend... she loved it so much
Bellie14 (author)2013-11-15
Really cool!!
burntorange (author)Bellie142013-11-15
Thanks Bellie!
Penolopy Bulnick (author)2013-11-11
Beautiful! Love all the details and how you were able to incorporate a real playing card :) These are probably still too big, but it would be cool if you could find legit tiny cards!
Oh Yea! That would be awesome, I know I've seen tiny cards before...hopefully I'll run across some again and add them. Thank you for the compliment :)
About This Instructable
3,720views
122favorites
License:
Bio: I started out ripping apart shoes and adding "James Bond" features to them when I was about 7....the rest is Tinkering History!
More by burntorange:Under Cabinet Lighting made easy :) With Tons of Colors!Harley Quinn BraceletEasy To Use Chopsticks Trick (less than 1 min)
Add instructable to:
