Harry Potter Golden Snitch Leather Sandal
5,080
106
24
Published
Introduction: Harry Potter Golden Snitch Leather Sandal
About: A person who enjoys making things!
Seeking a new pair of shoes? I was, so I decided to make a pair of leather sandals inspired by the golden snitch from Harry Potter (One of my favorite things!)
When I wear these I'm wicked fast and damn near impossible to see : )
Step 1: Mocking Up the Sandal
The first step was to mock up the sandal, I had a rough sketch / idea of how I wanted these to look, so to create them I started by examining a pair of existing sandals that fit me perfectly.
I traced around the sole to create the pattern and referenced the sandal to figure out where to put the straps and how long they should be. Then I started making some mock up strap designs out of scrap pieces of vinyl until I got the right shape. It took a few times but I finally got the right fit.
I fine tuned the pattern in Illustrator based off my mock up from actual fabric, since I was going to use real leather I wanted to make sure everything was perfect.
If your want to create this exact sandal, I have attached the pattern I created, it is for a size 7 1/2 : ) Enjoy!
Step 2: Create the Upper Leather Soles
Supplies Needed:
Tools:
  • Heavy duty shears or utility blade
  • Pencil
  • Foam Brush
  • Paper Towels
Materials:
  • Leather ( I needed a 11 "x 7" for a size 7 1/2" shoe) - I purchased mine at Tandy Leather
  • Leather Stain - I used Eco-Flo Professional Waterstain in Medium Brown, you can find it here
  • Leather Finish - I used Eco-Flo Super Shene Leather Finish, you can find it here
  • Pattern for the sole
To create the upper leather soles I used a thick piece of unfinished leather.
I marked out the sole pattern on the leather, including the hole markings for the straps.
I cut out the soles and holes for the straps using some heavy duty shears and a utility knife. The holes for the straps took some time to cut out but I have also seen people use a chisel to hammer out the holes which I might try next time.
Next I added a brown stain to the soles to give them a nicer look. I applied the stain to the top of the soles using a foam brush and applying it in circular motions. After I finished coating the entire top I buffed it out using a paper towel and let it dry. I applied 3 coats to achieve my desired color, allowing about 15 minutes drying time before applying each coat.
To seal the stain I added a gloss finish using a foam brush.
And to complete the leather uppers I added a topstitch around the entire outer edge to give it a real sandal look.
Step 3: Create the Bottom Rubber Soles
Supplies Needed:
Tools:
  • Utility Blade
Materials:
  • 5mm Brown Rubber ( I needed 11" x 7" for a 7 1/2" shoe) I purchased my rubber from a local shoe repair shop.
  • Sole Pattern
To create the rubber soles I traced out the sole pattern onto the rubber excluding the hole markings for the straps, you don't need those for the rubber bottom.
The soles were carefully cut out using a utility blade. Since the rubber was 5mm thick this took some patience but they cam out great. The edges came out clean so I did not need to do any sanding to finish them off but you can definitely sand the edges down as needed.
Step 4: Construct the Straps
Supplies Needed:
Tools:
  • Scissors
  • Pencil
  • Binder Clips
  • Sewing Machine
Materials:
  • Gold Leather - I purchased mine at Tandy Leather
  • Strap & Gold Snitch Pattern
  • Gold 5mm Studs
  • Gold Thread
Since these sandals were inspired by the golden snitch, I used gold leather to create the straps. I have been waiting for a project to use gold leather on so I was very excited when I decided to make these : )
I marked out my pattern pieces on the gold leather using a pencil and cut them out using fabric scissors.
I started assembling the pieces by attaching the wing detail to the straps. I used binder clips to keep them in place, then top stitched them down.
Next I added some gold 5mm studs to give them some extra bling!
Step 5: Sew the Snitch
Supplies Needed:
Tools:
  • Sewing Machine
  • Binder Clips
Materials:
  • Golden Snitch leather pieces
  • Gold Thread
  • Gold 5mm Studs
For the snitch I created a round base and added leather applique details to the front to resemble the golden snitch.
I used binder clips to keep the applique pieces in place and top stitched them down.
After I finished sewing on the details to the top base piece, I attached the backing. I cut slits in the backing where I could insert the straps through which holds the snitch in place on the front of the shoe.
Then I added some stud details to make them look like the real thing!
Step 6: Attach the Buckles
Supplies Needed:
Tools:
  • Leather Hole Punch
  • Sewing Machine
Materials:
  • Left & Right Inner Strap Pieces
  • 2-3/8" gold buckles - I purchased mine here
  • Gold Thread
The next step was to attach the buckles. I positioned the buckle 1” in on the longest strap and used a leather hole punch to create the hole to slide the buckle through.
I inserted the buckle through the hole and folded over the end of the strap to close it.
To secure the buckle I sewed the strap closed using binder clips to keep it in place.
Step 7: Attach the Inner/ Outer Straps
Supplies Needed:
Tools:
  • Sewing Machine
  • Binder Clips
Materials:
  • Both Pairs of Inner & Outer Straps
  • Gold Thread
To prepare the strap pieces to be ready to attach to the soles I started by sewing together the inner and outer straps at the center toe. I layed the outer strap on top of the inner strap and stitched them together at the center toe using binder clips to keep them in place.
Step 8: Slide on the Snitch
Supplies Needed:
Materials:
  • Left & Right Straps
  • Both Snitch Pieces
To attach the snitch, I slid the front end of the inner/outer straps through the slit in the back of the snitch piece and positioned it where the front straps intersect.
Step 9: Attach the Straps to the Leather Upper Sole
Supplies Needed:
Tools:
  • Small Brush
Materials:
  • Left & Right Leather Upper Soles
  • Contact Cement
To attach the straps to the leather upper sole I pushed the straps through the corresponding holes in the sole.
I gave them a 1” over lap on the back and secured them in place using contact cement.
Step 10: Attach the Leather Upper Soles to the Rubber Soles
Supplies Needed:
Tools:
  • Paint Brush
  • Clamps
  • Paper Towels
Materials:
  • Left & Right Rubber Soles
  • Left & Right Sandals
  • Contact Cement
  • Vinyl Fabric
To attach the leather upper soles to the bottom rubber soles I started by applying a base coat of contact cement to both surfaces and allowed the glue to get tacky for 15 minutes.
After the glue was tacky I applied another coat of contact cement to both surfaces and and sandwiched them together using clamps. ( A lot of clamps! ) I used scrap pieces of vinyl to protect the shoe from getting damaged by the clamps, I didn't want any scuff marks on the leather sole. I allowed the shoes to dry over night to make sure everything was secure and firmly attached.
Once my shoes were completely dry I added the holes for the buckle to
slide through on the outer strap pieces, you can add this at any time but I waited until the end so I could see how everything fit.
Step 11: Wear and Enjoy!
The last step is to take your new shoes out for a stroll and enjoy!
Leatherworking Contest
Runner Up in the
    • Spotless Contest
      Spotless Contest
    • Flowers Challenge
      Flowers Challenge
    24 Comments
    Can you make a template for size 9 1/2? I couldn't seem to get it right.
    Thanks so much for checking them out! It was easy! Standard book of spells chapter 7 : )
    Only recommendation I would have is to stitch the upper and lower together instead of using it as a design element only. Very creative and professional results.
    Thanks for the feedback! That would have definitely been a great touch, just need to invest in a heavy duty sewing machine! : )
    Super cute! I'm really impressed that you built them from scratch rather than modding an existing pair.
    Thanks! I wasn't sure how hard it was going to be but it was a lot easier than I expected! : )
    Thanks! She must be a Harry Potter fan ; )
    Awesome! I thought you just modified some existing sandals...but a brand new build is amazing! And of course, the snitch kicks it up another notch! Great! :)
    Thanks! Glad you like the project, it was a fun one! : )
