3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Harry Potter - The Weasley's Burrow Gingerbread House
Step 13Decoration: The Sprayed Shreddies Roof
Now that all the main Gingerbread pieces were on I could start to decorate!  I used Shreddies Cereal as my roof Shingles.  I laid out a large piece of Tin Foil then spread out the Shreddies flat along the entire surface of tin foil. I then used Spray Red Food colouring ( I believe it's often used on cupcakes) To dye my shingles red.  I started gluing them on with icing from the bottom and worked my way up making sure to break the bottom of each shingle just a little bit so it looked older and a bit more aged.
On the corners of the roof, I put a line of shreddies down to hide the seam.
Once they were all on and dry, I used a bit of black and brown icing and a paint brush to paint in shadows and dirt.
1 comment
Apr 20, 2012. 12:16 PMBruce1212 says:
This is the coolest use of shreddies I have ever seen. I am a big fan of the shreddies.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:mezcraft(A can of crafty curiosities)
I am a propmaker in Canada, with a penchant for the geek. I play ukulele, I have a Scotty Dog and I am usually found with a smile on my face if I am building something!
