3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Harry Potter - The Weasley's Burrow Gingerbread House
Step 4Rolling out and making your gingerbread pieces
Preheat the oven to 350 degrees F and put parchment paper on  2 large cookie sheets. As the pieces are really big for this, you will need large cookie sheets.
Sprinkle a bit of flour on to your dough rolling surface, find two pieces of anything that can be your thickness gauge on your gingerbread. ( I used some leftover foam core) Stick them on either side of your roller, so that you don’t get any thinner than that thickness with your roller, a nice even surface pays off in the end.  Split your dough up and start rolling it out.  Use the foam core pieces from the model to create your gingerbread shapes. I used a very sharp paring knife to do all of my cutting and it worked out really well.
This is also where I added in some detail on the gingerbread, I took the template off, then I added in wooden slats on to the surface of the gingerbread, I used a dull butter knife to add grooves into the gingerbread which would give it a bit more detail once it’s baked.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:mezcraft(A can of crafty curiosities)
I am a propmaker in Canada, with a penchant for the geek. I play ukulele, I have a Scotty Dog and I am usually found with a smile on my face if I am building something!
