"Hasty" Workbench Light Mounting
Published
Introduction: "Hasty" Workbench Light Mounting
I found a telescoping fluorescent light with no mount/base for it.  So, I figured out a way to mount it to my work table and give it full functionality.
Basically, take a wide wood bit, drill it perfectly straight into the corner of  the table and insert the light into the hole.
Quick. Easy. Free.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    2 Comments
    Mine isn't a rigid fix (i only had 1 size bit) but it works and I'm not constantly moving the light around. I suppose if I had to stiffen up the light I could wrap the anchor point in duck tape.
    I use a similar set up in my garage shop.
    I took a 6"/15cm 2x4/5cmx10cm piece of scrap and drilled a hole for the tab at the base of the light.  I put the lamp in the scrap then I clamp the scrap wherever I need the light.
    It was originally just a quick and dirty improvisation that I intended to replace but it works so well and is so flexible that I just left it as is.
