Please note, this method has only been used on a flowering garden. If I was growing herbs or vegetables, I would not use this method. If you are growing food, you still may find some benefit in using the sunken pots that are mentioned later.
This method uses recycled roof guttering to act as an irrigation channel in your garden. Your garden will thrive without wasting precious drinking water. All the water is delivered to the root zone which means it is going straight to where it is needed. Water restrictions are becoming more common, so with a little bit of work now, you can still have a healthy garden and feel good about doing your bit for the planet.
I have had this system in place for 4 1/2 years. The soil is a little bit clayey. I was never dedicated to watering and my plants wouldn't thrive and would be lucky to even survive. With this system, the plants get a lot of water with no effort. I thought it would be too much water, but everything is fine so far. No effort has been made to use special shampoos. Just the regular stuff. And the fact that shower water is hot has had no effect.
If your house is on a concrete slab then this instructable is not suitable for you. You may still be able to make your current system of watering more efficient by using the sunken pots.
Remove these ads by
Signing UpStep 1Materials
PVC pipe and fittings compatible with the pipes carrying the waste water from your shower. This is likely to be 50mm-2 inch wide pipe.
Small soft drink bottle. (Optional)
19mm-3/4 inch garden irrigation poly pipe. (Optional)
Length of old roof guttering the same length as your garden and similar length of gutter guard.
Old plant pots approximately 18cm-7 inches wide at the top.
Drill, drill bit about 8mm-5/16 inch.
In a big barn type hardware store, the agi pipe was much cheaper in the builder's section than in the garden section. And wider too, about 2 1/2 inches/65mm which suited me. From memory the builders pipe was about the same price as the garden pipe but twice the length.
Good luck with all your ideas.
http://chemistry.about.com/library/weekly/blsapon.htm
Here are some precautions to take to keep the grey water from hurting your plants: http://vric.ucdavis.edu/pdf/fertilization_Householdwastewater.pdf
And here is an article explaining how sodium is a type of water pollutant:
http://www.lenntech.com/water-pollution-FAQ.htm
Anyway, of all the waste water you could pour onto plants, the shower water is probably the most dilute sodium, and if you begin to see your plants burning, you should go back to the pure filtered water.
You're probably thinking of phosphates, as phosphorous is one of the main elements used by plants. But the phosphate runoff into ground water, lakes and streams causes a condition called eutrophication, which is described here: http://www.water-research.net/Watershed/phosphates.htm
and eventually it kills fish and aquatic organisms.
We're also on a water meter, so making double use of water we pay for by the litre is good sense.
As for detergents, mild solutions of soap (sometimes with other ingredients) are often recommended as less harmful bug sprays, often within the organic philosophy. Depending on quite *what* people are using in their showers, the water should be helpful in the garden rather than a problem, even on food. I'm finding it hard to think of anything I would consider putting on the outside of my body that I would object to having on the outside of my veg in even more dilute quantities. If you're that worried, making your own soap, shower gel or shampoo is fairly simple & opens the door to some wonderful experiments - even my silver-haired mother does it, her cinnamon & rose shower gel is my favourite.
