Have someone hopelessly lock them self in a room! BEST PRANK EVER!
In this Instructable, I will be showing you how to make someone lock them self in a room!!!
The cool thing about this prank is that once it is set up, you can leave it and walk away. The victim unknowingly activates the prank themselves. Once the person enters their room and shuts the door behind them, the torture has begun!
The concept is simple, you have a room or bathroom with one of those push button or twisty locks, like shown in the picture. You take off the door knob assembly and put it back on, but backwards! This leaves the locky part on the outside of the room, where the prisoner cannot access it to free them self from their newly found prison cell. Now most locks do indeed have a little hole or something that you can shimmy a paper clip into to unlock the door. I will show you how to easily disable this feature, temporarily so that this prank will be perfect.
I want everyone to be aware that THIS WILL NO DOUBT LOCK THEM IN WITH NO ESCAPE!!!!! This system is dangerously foolproof and will lock someone inside a room or bathroom with no escape! Don't pull this prank if it's possible that an emergency could arise where a person would absolutely need to exit the room, because they will not be able to until someone comes and turns the knob on the outside. Please be responsible but also have tons of fun cuz it's April Fools!!!!! :P
Good Luck and remember to
VOTE FOR ME!!!
VOTE FOR ME!!!
VOTE FOR ME!!!
VOTE FOR ME!!!
VOTE FOR ME!!!
Step 1Tools
Tools
You will need:
- A room with a door knob with a twisty or push lock
- A phillips screwdriver to unscrew the door knob
- A BB or pellet, something about that size to block the outside unlock mechanism
- About 3 minutes
175 comments
1-40 of 175next »
Jul 9, 2009. 7:40 AMscrued1992 says:
Good prank. One suggestion to pull off the instructible a little more professionally (and don't take this the wrong way - it's something I've seen on eBay as well): consider reflective surfaces and wear appropriate clothing.
Aug 31, 2011. 8:55 AMchrisphan1308 says:
LOL
Aug 22, 2011. 10:52 PMgshore says:
Good one!
Jun 28, 2011. 9:22 AMblackboard says:
COOL NOW I CAN GET BACK AT PEOPLE MUNANANA THANKS
Jun 4, 2011. 11:59 AMSirStokes says:
"hahahahaha n00b" lol
Apr 3, 2011. 6:45 PMvascanj says:
OMG... does this prank remind ANYONE of the movie Amelie? Or is it just me? I started to LAUGH OUT LOUD when I saw someone posted an instructable for this!
Mar 29, 2011. 11:43 AMjamwaffles says:
"VOTE FOR ME!!!
VOTE FOR ME!!!
VOTE FOR ME!!!
VOTE FOR ME!!!
VOTE FOR ME!!!"
No. If you want votes, make stuff worth voting for. I'm not saying this is a bad 'ible by any means at all, but please don't beg like this :-( it ruins things.
May 17, 2010. 9:23 AMMr. Grumpus says:
See the tiny hole in the non-lock side of the handle?
Straighten a metal hanger and push into the hole...the door unlocks.  Any small, relatively straight object will do it.  Ballpoint pen, little metal loop that holds the chain for the bathtub plug, etc.
Mar 27, 2011. 12:12 PMcodongolev says:
he shows how to disable it.
Mar 27, 2011. 3:26 AMspartancaver says:
I think the poster says it best himself.
"Don't pull this prank if it's possible that an emergency could arise where a person would absolutely need to exit the room, because they will not be able to until someone comes and turns the knob on the outside. "
It is called an emergency because it is happening quickly and is possibly life threatening. a.k.a. accident as in I didn't mean for it to happen like this.
The idea is funny but best done on a TV show where a camera crew is in the room with them.
Jan 29, 2011. 4:57 AMKyky Rocks1 says:
no iam
Oct 7, 2010. 9:52 AMmr. robot skull says:
no i am
Sep 30, 2010. 4:06 PMvenom1539 says:
I'm the last person to comment!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Aug 16, 2010. 6:19 PMJohnJY says:
Does this damage the door knob?
Feb 26, 2010. 12:52 PMknex gun enthusiast says:
 on some bathroom doors you can lock people in without reversing the lockset. on older door knob sets putting an object into the outside hole thing actually disconnects the inside door handle from the rest of the mechanism, that way the person inside can't hold the door handle manually. If you put a thin dowel into this slot and use an elastic to hold it there the person inside can spin the handle on their side as much as they want but it won't do a thing. pushing the little button will push the dowel out on the other side but the door handle will still be disconnected.
if you are ever in this situation you can empty(partially) a toothpaste tube and use the end to push back the latch. (like credit carding a door). It's usually easier than taking off the hinges as inside door frames are usually quite tight.
Mar 23, 2009. 3:54 PMover-rev says:
never mind its not awesome they can just take the hinges off and the bb thing did not work
Feb 5, 2010. 6:24 PMlivesteamfan says:
 That may not be possible. Most doors close over the hinge so all you can see is the barrel where the pin is which is normally locked in somehow.
Aug 27, 2009. 10:01 AMMarrock says:
Just take the door off the hinges, that's what a good pair of boots is for. Is someone ever tried this, so-called, joke on me he'd better hope he can run faster scared than I can pissed off.
Dec 27, 2009. 10:54 PMknex_mepalm says:
ALWAYS have a swiss card or swiss knife in your pocket, you never know how it will serve you. Mine has saved me from uncomfortable situations and lethal situations 36 times
Aug 4, 2009. 10:39 AMstruckbyanarrow says:
Ahhh the leatherman wave.... i've taken off 2 doors with that baby... (and its on my belt at all times)
Apr 16, 2009. 1:44 AMnecropolian says:
i got screwdrivers, epoxy, a swiss pocket knife, a morning star, and a sword in my room. all of the handy in some cases.
Apr 20, 2009. 10:02 AMstapledpants says:
What the heck is a morning star? Is it some kinda ninja thingy?
Apr 26, 2009. 1:41 AMnecropolian says:
no sorry, i meant a flail. read this: The flail is a medieval weapon made of one (or more) weights attached to a handle with a hinge or chain. There is some disagreement over the names for this weapon; the terms "morning star", and even "mace" are variously applied, though these are used to describe other weapons, which are very different in usage from a weapon with a hinge or chain, commonly used in Europe from the 13th century to the 15th century. In construction, the morning star and flail have similar, if not identical, spiked heads. Thus, morning star is an often used name for this weapon, especially as the name "flail" is also used to describe a style of whip used for flagellation. perfect to smash in a door, or wall!
Feb 6, 2010. 5:12 PMfoxtrot4697 says:
or someones face in
Feb 10, 2010. 3:34 AMnecropolian says:
"I will always be puzzled by the human predilection for smashing other lifeforms with high speed velocities."
Which quote did I parodize?
Apr 16, 2009. 2:16 AMzimmemic25 says:
u have them in your bathroom?
Apr 17, 2009. 5:51 AMnecropolian says:
no, in my bedroom. but i keep various other tools everywhere.
Jun 25, 2009. 4:48 PMStephen D. Alverez says:
Now, where in the world would you get a flail / morning star!!!???
Jun 26, 2009. 12:12 AMnecropolian says:
simple. there are many historic sites where they sell decorative swords, like the Mons Saint Michel in France. last time is was there, three shops sold swords, and other stuff. I bought a sword in a fortress somewhere in Germany, a month ago. the flail, i got mine from my uncle, but there are flails at those historical sites too.
Sep 6, 2009. 6:02 AMmatstermind says:
or garage sales, you'd be surprised at what i've found a them
Sep 8, 2009. 9:13 AMnecropolian says:
around here, most people don't do garage sales. actually, they do nothing. you'd be suprised if you saw how many children are out to 'trick or treat' at halloween. i'd say, two per square mile. but thanks for the idea...
Mar 25, 2009. 7:00 PMDIY Dave says:
I actually have tools in my bedroom.
Jan 23, 2010. 6:08 AMsmattman22 says:
same
Mar 25, 2009. 9:15 PMlukeyj15 says:
I keep screwdrivers in my bedroom
Mar 27, 2009. 10:12 PMblugyblug says:
I keep hacksaws in my bedroom, and electric drills....
Sep 26, 2009. 2:49 PMharley_rly says:
i keep vice grips, hacksaw, screw drivers, wire cutters, and an AK-47 in my room...so i definitely wouldn't want to use this room lol
Mar 25, 2010. 7:22 PMvenom1539 says:
Why would you want an AK-47 in your room? Whats the point?
Mar 25, 2010. 8:42 PMharley_rly says:
i had it standin up by my bed for home security purposes, but about a month ago my dad was talkin bout sellin it(it's his)so i took all the shells out and put them in my SKS, and sat it back where the AK was
Dec 27, 2009. 10:57 PMknex_mepalm says:
 I have 4 chemical grenades a M-16 and a sword from the 16th century in my room. Also a gas mask... hehehe and a radiation suit.
1-40 of 175next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:DuFFxP93
