Hawking 7dBi Wifi Antenna free boost
I discovered the Hawking 7dBi Wifi Antenna has a flaw. By removing the flaw I got a signal boost for FREE.
the part number of the antenna is HAI7SIP.
Before this modification I had one bar of signal that sometimes dropped died completely. After the modification I now have two bars of signal. Most importantly no dropped signal anymore!
Step 1Dissasembly
Dissasembly
Peel back the rubber on the bottom and remove the 4 screws. Now use a putty knife or thin flat tool to pry the two parts of the actual antenna apart.
8 comments
Jan 21, 2012. 5:35 AMtc998hot says:
WiFi Signal Amplifier Booster Manufacturers
http://www.powermicrowave.com
http://www.powermicrowave.com/2wen/2w-en.html
http://www.powermicrowave.com/en/4w-en.html
Feb 27, 2009. 9:13 PMaskjerry says:
Just a guess, but I think they wanted the plastic case very thin so they designed it with the thin coaxial cable. The problem is that the cable looses much more signal per foot than the thicker cable. They made a compromise and used both cable types, the circuit board is likely just a place to solder the two wire types to for a secure connection. This connection likely has a loss of 1dB or so in addition to the coaxial loss of the thin cable. By giving up flexibility, he likely gained about 2dB of signal. (Every 3dB is 2x signal strength.) The shorter the cable the less signal loss. Higher frequency means more loss too... and this is in the GHz range so it is very lossy. Good simple fix.
Feb 19, 2009. 10:01 AMrhackenb says:
What's a PCB and why is this the problem. I don't understand the principle here. Also, I would suggest that you rotate the photo on step 4 to vertical. Finally, you go to all this work to go from one bar to two? What is the max number of bars possible? Five?
Feb 19, 2009. 1:44 PMcyrozap says:
A PCB is a Printed Circuit Board (the green thing in the picture for step two). I also do not know how that is a problem. If it's there, the designers put it there for a reason.
Feb 19, 2009. 2:47 PMrhackenb says:
You seem to indicate that the PCB is the problem: "Take the PCB and the wires out of the shell. The green PCB is the flaw! We must remove it." I figured you knew what it did.
Feb 19, 2009. 2:52 PMcyrozap says:
I didn't write the instructable so I don't know. I don't even own one of these!
Feb 19, 2009. 7:28 AMLftndbt says:
That is fantastic! Could you contact me with further details?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:bensmith8302
